This thread is privately moderated by Robert May, who may elect to delete unwanted replies.
Old Jun 22, 2012, 02:27 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
I glad to see you are back on this!
RGinCanada is offline Find More Posts by RGinCanada
Old Jun 23, 2012, 01:34 AM
Robert May is offline
Find More Posts by Robert May
Joined Apr 2002
Thank you RG
I normally wouldn't be indoors modelling at this time of the year but this is a very wet Summer, over 100mm of rain this week alone! With most of the jobs done around the house, The Waveney is a better option than watching;Tennis, Football and in a few weeks time the Olympics.
Robert May is offline Find More Posts by Robert May
Old Jun 23, 2012, 09:09 AM
JerryTodd is online now
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Amen
Welcome back Bob!
JerryTodd is online now Find More Posts by JerryTodd
Old Jun 29, 2012, 09:07 AM
Joined Apr 2002
Thank you Jerry
With the mast blank saved from being a useful stick I decided to turn a button for the mast head. I don't have a small woodturning lathe so with a scrap of Beech, (cut to an appropriate size hexagon) glued onto a dowell, whole lot was mounted in the rechargable drill, a Scapel blade mounted at centre height and I had a makeshift lathe.
Old Jun 29, 2012, 09:23 AM
Joined Apr 2002
Gaff jaws
The introduction of GRP for boats 27-34 into the fleet also bought about a Mk11 Gaff Jaw, Kingcup gets a MK1 but the challenge of moulding the elegant MK11 in aluminium looked like a fun project in itself.
The MK1 is galvanised "C" shoe with a stitched leather jacket
Old Jun 30, 2012, 02:18 PM
Joined Apr 2002
Parrel Beads
The Gaff jaws on the Waveney are secured by a piece of rope with 22mm (7/8ths) wooden Parrel Beads to act as runners. A scout through the bead box and shops in town drew a blank for anything close to a 3.6 mm bead.
Back in the workshop a redundant watchmakers screwdriver was soon modified into a chisel with the correct bead diameter sharpened into it. Worth noting, after a few modeller's experiments showed that if one leg of the chisel was left a fraction longer than the other it formed a useful parting tool to cut the bead off the dowel.
The 1mm drill acts as a fixed centre when turning the bead and also stops the bead from escaping once it is parted off.
Old Jun 30, 2012, 04:09 PM
Joined Apr 2002
Gaff Jaws ready for the Gaff
A bit of boot polish, a bit of scuffing and removing the galvanizing where the halyard eye rubs and the Jaws are weathered in a bit.
Old Jul 05, 2012, 06:51 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
My goal in life is to build just one model with the same attention to detail that you have afforded this one.
Old Jul 05, 2012, 10:50 AM
Joined Apr 2002
Thank you RG, my goal is to try to finish just one too, this one! I think the luxury of having time in the workshop means that each little fitting or component becomes a model in itself and therefore deserves to be my best effort.
Have you got a model in mind?
Old Jul 05, 2012, 12:00 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Yes.. and no.
A planked steam launch, but I haven't chosen the launch or the steam plant yet. I have two or three other builds that I want to use a training projects to gain the skills that I don't yet realize I don't have
At the rate I work, I need to live a very long time. It is all part of my master plan.
Old Jul 05, 2012, 05:03 PM
Joined Apr 2002
A planked steam launch? Nice! A model engineer friend has a part complete marine steam plant and boiler which he says I can have if I want to finish it off, he has started on a V8 and has lost intertest in the a steam engine. He previously built a model V.W air cooled flat 4 which now powers his bicycle. Now those are skills I wish I had.
Old Jul 05, 2012, 05:35 PM
Joined Apr 2002
Bowprit shoe
I know I should be planking but while the metal kit is out for the mast fittings I have decided to run up against the problems of the Bowsprit shoe, a very distinctive and prominent fitting on the foredeck.
I have tried carving out a plaster mould to "ingot" pour molten bronze into, that works after a fashion but the quality of the casting means a lot of time with a file, There is nothing wrong with that but this seems like a good excuse to play with lost wax casting. Lost Wax or investment casting is a standard method of making Jewellery and IF I ever decide to kit the GRP model, fittings will need to be available. A rubber mould taken off a wooden plug gives me the option of a single Shoe or the chance to make more wax models if the first experiment doesn't work.
Let the photos do the talking
Old Jul 05, 2012, 06:11 PM
Joined Apr 2002
Does anyone know why this thread is "stickied"?
Old Jul 05, 2012, 08:45 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
A craffty Man...
Tim B. is offline Find More Posts by Tim B.
Old Jul 06, 2012, 05:23 PM
Joined Apr 2002
Well the first experiment failed, it seems that Acrylic spray primer will not stand 160 deg C.
Today has been a case of trial and more than a few errors but with lessons learnt I am hoping that when I get up tomorrow I will have a rubber mould for making wax plugs. I do have servicable system and have made a few reasonable plugs but having chanced on Jerry's "Pride of Baltimore" thread decided that I shouldn't put up with reasonable. Fantastic work Jerry! I think if I had seen that thread before now I would have been inspired to pull my finger out a bit sooner.
Anyhow here is a photo of Lesson 1 from early this morning.
Discussion Waveney One Design 1/6th scale Robert May Scale Sailboats 118 Mar 24, 2015 09:10 AM
Discussion AstroFlight ASW 17 1/6th scale plans? rmantoo Scale Sailplanes 5 Jun 04, 2010 10:03 PM
Help! R/C Tiger 1 Tank Late Ver. 1/6th Scale HeavyMetal USA - District V 0 Nov 27, 2009 08:59 PM
Discussion Ercoupe 1/6th scale Build2fly Scale Fuel Planes 13 Nov 15, 2009 04:31 PM
AerodromeRC 1/6th scale Fokker EIII and GWS powered 1/12th scale Fokker DR.1 AerodromeRC Scale Kit/Scratch Built 1 Aug 23, 2005 08:30 PM
