Old Nov 18, 2009, 03:47 PM
JohnAsaPrice's Avatar
Joined Sep 2006
Need Airframe for my Rclander 68mm 3s EDF unit
Hey guys, I'm retiring my GWS A-4 and have a good RCLander 3s EDF unit that I would like to put in a new, light, airframe.
Any suggestions for a good airframe for this 68mm EDF unit?
I currently fly with a 2X 3S 2200 mah battery configuration (4400 mah)
John
JohnAsaPrice is offline Find More Posts by JohnAsaPrice
Old Nov 18, 2009, 08:58 PM
Team White Llama!
gundamnitpete's Avatar
Hp f-16?
gundamnitpete is offline Find More Posts by gundamnitpete
Old Nov 19, 2009, 05:47 AM
Joined Sep 2006
Is that the Phase 3 F-16?
Old Nov 19, 2009, 05:53 AM
Team White Llama!
Yes, i think it would work quite well (only the 4400 might be a little heavy)
Old Nov 19, 2009, 07:54 AM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
Do you want to build or buy?
Here's a pretty cool one (with or without the thrust vectoring).
The "MiniFan" size one should be good for your fan.
Just have to cut and glue some 6 mm foam...
http://www.rcgroups.com/forums/showthread.php?t=509363
http://www.parkjets.com/X-31.html
perttime is offline Find More Posts by perttime
Old Nov 20, 2009, 01:45 PM
Joined Sep 2006
I'm not interested in doing the airframe from scratch (yet) so, Phase 3 f-16 sounds promising.
I have the RCLander 68mm 3S fan
(which is a little on the heavy side)
this fan wants to draw heavy wattage, so I prefer to run with a 4400 mah setup
Has anyone tried this config before?
Discussion What airframe/kit can I use the Lander 3S 4375KV EDF with and still fly fast? fooyukvoon Foamy EDFs 14 Oct 03, 2009 11:41 AM
Discussion RCLander 3s EDF Unit questions JohnAsaPrice EJF/EPP 1 Aug 10, 2009 09:27 PM
Sold RCLander 70mm 68mm - Aluminium EDF + 2185 kv motor (6S LiPo) SkylineFlyer Aircraft - Electric - Jets (FS/W) 6 Jun 16, 2009 08:21 AM
Sold SOLD - HC EDF Unit 2.68inch / 68mm - SOLD henkvdw Aircraft - Electric - Jets (FS/W) 1 Jun 01, 2009 05:23 PM
Sold RCLander 68mm Aluminium fan unit NEW Jet Dreams Aircraft - Electric - Jets (FS/W) 5 Apr 21, 2009 02:00 PM
