Old Nov 24, 2009, 12:26 PM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
This radio is onsale this black Friday for only $350. Comes with a 7ch receiver. Hobby People item number 751747.
Steph280 is online now Find More Posts by Steph280
Old Nov 24, 2009, 10:29 PM
cptsnoopy is online now
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Hey Mike, very clean! Hope it works as well as it looks.
Charlie
cptsnoopy is online now Find More Posts by cptsnoopy
Old Nov 24, 2009, 10:40 PM
Noel Robbins is offline
Find More Posts by Noel Robbins
*Read*Rise*Return*Repeat
Noel Robbins's Avatar
USA, TX, Austin
Joined Nov 2009
Mike, that is brilliant. How did you "drill" the long openings for the teflon tubes? Also, where does one buy such tubing if one wants to pilfer your idea?
Thank you for taking the time to photo and post this! Fantastic!
Noel Robbins is offline Find More Posts by Noel Robbins
Old Nov 25, 2009, 02:35 AM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
Have you range checked that setup yet. Looks cool, but that seems like a lot of carbon(d-box) in front of the antenna for instance when you are low and far away. I saw George's Concept this weekend and it looks like a great airframe.
Good luck Mike!
Clay
ClayH is offline Find More Posts by ClayH
Old Nov 25, 2009, 07:39 AM
Goinav8n is online now
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Clay
It looks like the feed line is the only part in the carbon. The last 3cm is the antenna and it sticks out into the kevlar part
Jeff
Goinav8n is online now Find More Posts by Goinav8n
Old Nov 25, 2009, 09:22 AM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Mike nice job.
rcgeorge is offline Find More Posts by rcgeorge
Old Nov 25, 2009, 10:15 AM
ClayH is offline
ClayH's Avatar
92840
Joined Mar 2003
I realize that. But if you were doing a range check from 30 paces and the plane was level with the nose pointing towards you, the signal has to go through the dbox, right? Just askin'.
Clay
Old Nov 25, 2009, 01:16 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Clay, my middle name is range check! And of course you are right. The weak part of the range is with the model pointed directly back at me. But even in that orientation, the signal was just lost at 30 paces..... All other orientations are beyond min. specs.
Also note that one tube runs along the upper skin, and one along the lower skin. Since the tubes have a slight curve to them, it was easy to rotate them to get this desireable configuration. I have flown it a couple times now at medium ranges so far without issue. We'll see how it performs at extreme ranges as necessary.
Noel, I simply used a piece of 1/16 wire, and hand twist drilled a hole throught the shear web. For the leading edge, I used my dremel with a 1/16" bit, then slightly enlarged the hole so I could work with it. It ended up being abot 3/32" dia.
The tubing was purchased a long time ago from a guy that lost his shop due to fire. He supplied teflon tubing to be used for pushrod housings for the XP series type gliders when we were all using small diameter carbon pushrods. I am sorry, but I do not know where to get it now. Others on this list will likely remember. I am sure that Bruce, Denny, Oleg, or Phil would know where to get the stuff these days.
Cheers all.
FLY F3B is offline Find More Posts by FLY F3B
Old Nov 25, 2009, 03:57 PM
dlgdude is online now
Find More Posts by dlgdude
2013 US F3K Team Manager(ret)
Newbury Park, CA
Joined May 2005
Originally Posted by cody303 View Post
Airtronics will also be coming out with a full range 6 and full range 5 channel RX which will be super light and perfect for DLG. There will also be some cool new servos for DLG.
Cody
Hey Cody, will the new receivers be FHSS-3 or FHSS-1?
-l
dlgdude is online now Find More Posts by dlgdude
Old Nov 26, 2009, 03:57 AM
USA, TX, Austin
Joined Nov 2009
Thanks Mike for the information and pics, and everyone else as well... -Noel
Old Nov 26, 2009, 10:20 AM
cody303 is offline
Find More Posts by cody303
cody303's Avatar
Louisville, Colorado
Joined Nov 2003
-l
They will be FHSS-1 like the 7 channel RX.
Cody
cody303 is offline Find More Posts by cody303
Site Sponsor
Old Nov 26, 2009, 12:39 PM
Newbury Park, CA
Joined May 2005
Cody
Too bad. They need to come out with a FHSS-3 receiver that is smaller than the 10 channel...
Old Nov 26, 2009, 12:50 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
+1, although the 10 channel is pretty small.
You don't own a Dlg it wont fit in.
djklein21 is offline Find More Posts by djklein21
Old Nov 26, 2009, 12:56 PM
Newbury Park, CA
Joined May 2005
True the 10 will fit in everything, but I'd rather have a lower priced, FHSS-3 receiver, and only need 4 channels...
-l
Alert How to properly charge Airtronics SD-10G GravityGun Radios 11 Jan 19, 2010 09:29 PM
Sold New Airtronics SD-10G...$425.00 kman400 Aircraft - General - Radio Equipment (FS/W) 5 Nov 09, 2009 02:13 PM
Airtronics SD-10G Manual -- first version Garret H Non R/C Items (FS/W) 0 Sep 06, 2009 10:24 PM
For Sale Airtronics SD-10G >> NEW << $399 !! old_dude Aircraft - Sailplanes (FS/W) 7 Sep 03, 2009 01:46 PM
Discussion Airtronics SD-10G manual now available!! cody303 Multi Task F3X 10 Aug 27, 2009 02:57 PM
