Old Nov 20, 2009, 12:10 AM
Noel Robbins is offline
Find More Posts by Noel Robbins
*Read*Rise*Return*Repeat
Noel Robbins's Avatar
USA, TX, Austin
Joined Nov 2009
Thanks for all the advice ya'll. I am now heavily leaning towards using this radio. Thanks!
Noel Robbins is offline Find More Posts by Noel Robbins
Old Nov 20, 2009, 12:59 AM
bjue is offline
Find More Posts by bjue
NorCal
Joined Nov 2009
How much does the 10ch receiver weigh without the case?
Brian
bjue is offline Find More Posts by bjue
Old Nov 20, 2009, 11:05 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Mike Smith told me that the 10ch receiver without the case weighed less than the 7/8 ch receiver with the case. Somewhere on the order of 6 grams.
djklein21 is offline Find More Posts by djklein21
Old Nov 20, 2009, 02:52 PM
kcaldwel is offline
Find More Posts by kcaldwel
"Where are they?"
kcaldwel's Avatar
Joined Jan 2007
I posted this in Noel's Hitec thread, and I think he wanted me to cross post here. I'll add some links to the reports on the Assan stuff, so it isn't identical:
If you must have 2.4 right now, but don't want to spend a fortune before the dust settles on the various systems, there is always the Assan module with 2 Rx for $85. Rx are $20 to $28 ea, and are quite small (8g and less with the case). The Rx come with various length antennas. If you have a module Tx already, it is a real easy, low cost alternative.
It seems to work quite well, although I'm sure there will be comments about cheap radios in expensive planes. Seems some expensive radios in expensive planes aren't fairing all that well either.
http://www.hobbycity.com/hobbycity/s...W/_Module_&_RX
Kevin
http://www.rcgroups.com/forums/showthread.php?t=723343
http://www.rcmodelreviews.com/assanv2review.shtml
Assan has been actively posting on RCGroups, fixing problems, and listening to input on their system, unlike the other Chinese systems.
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 22, 2009, 11:46 AM
Bob McGowan is offline
Find More Posts by Bob McGowan
NorCal
Joined Oct 2003
Just checked and the 10ch rx is 8 grams exaclty without the case. Very light. If you nees less weight in the nose than that, remember with Airtronics you can run on a single cell lipo which I do in 5 of my DLGs with no problem.
It works great for DLG. Regarding the launch preset switch, I took it one step further and added a push button on the back of the TX.
Having 5 flight modes available on the 10G is great. Naturally the first 4 you'll use for launch, cruise, thermal, and land. I have the 5th set up as a "come home from down wind" mode. On the Drela foiled planes, I have the camber set between launch (reflex) and cruise in this mode or about 1mm down. I think the high speed legs are better at this setting than in either reflex or cruise. I also have the throws way detuned in this "come home" mode becouse when you are a speck out there trying to run home fast, it is way too easy to upset your fight path with a little stick input and lose your speed and heading.
Yes, the 10G is a great radio for DLG and more.
Bob McGowan is offline Find More Posts by Bob McGowan
Old Nov 22, 2009, 12:30 PM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Bob
I have a very tight fuse on my DLG. Is this reciever comparable to the 6250? Im thinking of using one in my Salonit. The size is really my concern
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Nov 22, 2009, 01:53 PM
NorCal
Joined Oct 2003
10CH size
Originally Posted by Goinav8n View Post
Bob
Jeff
Sorry for the poor phone pics, but it will give you the idea. As you can see, the connector block is the only bulky part to really worry about. The reciver itself is very thin.
.503 inch x .937 at the connector block.
2.808 long from the tip of the connector pins to the back of the PC board. Note you need a little more leangth in install for the servo connectors themselves and the antenna exit.
Bob
Old Nov 22, 2009, 02:25 PM
shawnc is offline
Find More Posts by shawnc
The ground's the limit.
shawnc's Avatar
Boulder, CO Area
Joined Aug 2008
That 10 channel rx is huge! My seven channel is buried deep in a glider, but here are a couple pics of the case.
shawnc is offline Find More Posts by shawnc
Old Nov 22, 2009, 07:18 PM
scootertrash340 is offline
Find More Posts by scootertrash340
Mark Gauding
USA, MO, Wentzville
Joined Apr 2002
Bob,
I just got my new SD-10G and was fondling and going through the manual and was wondering what the Data port is used for on the 10 ch receiver?
Mark
scootertrash340 is offline Find More Posts by scootertrash340
Old Nov 23, 2009, 01:08 AM
cody303 is offline
Find More Posts by cody303
cody303's Avatar
Louisville, Colorado
Joined Nov 2003
Hey Guys,
We have done a lot of testing with the Airtronics 7 channel in full carbon fuses in our
F3J models using the whisker technique and it is 100% solid. I have had the 7 channel specked out, low down and far out, and with a lot of other 2.4 systems running and it is all solid. There is no reason not to use it in the DLG's.
Airtronics will also be coming out with a full range 6 and full range 5 channel RX which will be super light and perfect for DLG. There will also be some cool new servos for DLG.
Cody
cody303 is offline Find More Posts by cody303
Site Sponsor
Old Nov 23, 2009, 02:02 AM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
Originally Posted by cody303 View Post
Hey Guys,
Cody
Hi,
whisker technique? Not really understand your meaning...Can you please ellaborate this and your installation?
Thx
/Jonas Ekman
oakman7004 is offline Find More Posts by oakman7004
Old Nov 23, 2009, 12:08 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Hi Jonas...
Whiskers means to let the last 20mm of the 2.4 antenna stick out the sides of the carbon fuselage. When two short antennas are sticking out in this manner they look like two little silver whiskers (like a cats whiskers)
On my Concept, I actually installed two small diameter teflon tubes through the leading edge, and through the shear web. When I put the wing on, I can load the antennas into these tubes very easily. This allows the antennas to rest out beyond the carbon D-box leading edge, and receive clear 2.4 signal in almost any orientation. Nothing sticks out in the wind. No whiskers for me....yet.
Cheers,
FLY F3B is offline Find More Posts by FLY F3B
Old Nov 23, 2009, 11:02 PM
USA, TX, Austin
Joined Nov 2009
Pics?
Mike,
Would it be possible to get a look at how you installed those antennae tubes? I am new at this and am having a hard time picturing it. Do you have pics possibly?
Noel
Old Nov 24, 2009, 12:15 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
Originally Posted by Noel Robbins View Post
Mike,
Noel
Sure, I will try to get some pics of the install.
Old Nov 24, 2009, 01:13 PM
USA, TX, Austin
Joined Nov 2009
I sure do appreciate it. Once the Airtronics tx gets here I will remove the case from the 10ch rx that comes with it and install it into an Avenger DLG that I bought from a local pilot. The Avenger I bought is several years old with a number of repairs in its past; if I screw up the 2.4GHz install and smash up the plane it will not hurt as bad as one of the finer kits I got coming the first of the new year. By then I hope to have a little building, installing, set-up and flying experience.
Alert How to properly charge Airtronics SD-10G GravityGun Radios 11 Jan 19, 2010 10:29 PM
Sold New Airtronics SD-10G...$425.00 kman400 Aircraft - General - Radio Equipment (FS/W) 5 Nov 09, 2009 03:13 PM
Airtronics SD-10G Manual -- first version Garret H Non R/C Items (FS/W) 0 Sep 06, 2009 11:24 PM
For Sale Airtronics SD-10G >> NEW << $399 !! old_dude Aircraft - Sailplanes (FS/W) 7 Sep 03, 2009 02:46 PM
Discussion Airtronics SD-10G manual now available!! cody303 Multi Task F3X 10 Aug 27, 2009 03:57 PM
