Old Nov 17, 2009, 02:46 PM
dmajchrzak is offline
Find More Posts by dmajchrzak
dmajchrzak's Avatar
USA, NH, East Merrimack
Joined Feb 2006
Spectra 2.4 installation question
Hi,
First off, I've installed my Spectra 2.4 in my Optic 6 and have Optima7 RX's in 3 different planes. Electrically, it works awesome. Planes fly great.
BUT, I can't seem to get the antenna mast to mount correctly. When I installed the plastic antenna mast into my Optic 6, I can only get it to loosely 'click' in. It does not screw into the threaded post at the bottom of the antenna hole. Looking at the mast, it seems that the threaded socket is in-set. What am I doing wrong? Just slipping the antenna mast over the threaded post is really too loose for my comfort. FYI, I didn't have to adjust the length of the mast, it was preset for my Optic 6.
Dave
dmajchrzak is offline Find More Posts by dmajchrzak
Old Nov 18, 2009, 06:50 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Spectra Pro Antenna Mast fitting.
Originally Posted by dmajchrzak View Post
Hi, First off, I've installed my Spectra 2.4 in my Optic 6 and have Optima7 RX's in 3 different planes. Electrically, it works awesome. Planes fly great. BUT, I can't seem to get the antenna mast to mount correctly. When I installed the plastic antenna mast into my Optic 6, I can only get it to loosely 'click' in. It does not screw into the threaded post at the bottom of the antenna hole. Looking at the mast, it seems that the threaded socket is in-set. What am I doing wrong? Just slipping the antenna mast over the threaded post is really too loose for my comfort. FYI, I didn't have to adjust the length of the mast, it was preset for my Optic 6.
Thanks, Dave
With pre release items (prior to manual) we were advised the antenna mast would be a simple push/pull fit into the Optic and Eclipse. The attached photo shows the "O" ring locking device and existing nut.
However, manufacturers always reserve the right to make improvements along the way and factory may have substituted the existing 10 mm bolt which holds the original Antenna into the Eclipse and Optic with a 15mm bolt for current 2.4Ghz versions. (An easy retro fit or perhaps the "O" ring could be tightened a fraction more). Using as is in both my Eclipse and Optic 6, it is easy to transfer between TX with simple push/pull. Please refer to the bottom of the 2.4Ghz mast extension which fits down into the transmitter. Two small screws hold an adaptor plate onto the bottom. Remove the two screws, an "O" ring will be released and the threaded nut will be exposed at the bottom of the mast extension. this will thread firmly into your Optic (or Eclipse) transmitter, provided the nut (just pressed in) is secured into the base with some contact adhesive or similar.
Later:
Spectra Pro Antenna Mast DIY Remote TX Mounting for 2.4GHz Antenna (Dual Std & 2.4) - pictorial
Spectra Pro Antenna Mast - Single Mount For Multiple Antennas On Optic 6 etc pictorial on alternate fittings.
Aurora 9 - Dual Frequency - DIY easy fit/remove 2.4Ghz Antenna holder. Photos and details for DIY plastic support which mounts on whip antenna.
23Nov10.
Aurora A9 & Buddy/Slave - Easy Link Method to Same Plane Either Standard or Promo AFHSS 2.4Ghz modules can be swapped between Teacher/Student TX to avoid need for re-linking. (Aurora, Eclipse, Optic 6, Prism 7X and Futaba as listed) with pictures of modules.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Last edited by A.T.; Jul 23, 2011 at 05:18 PM. Reason: add .jpg of full mast assembly.
Old Nov 18, 2009, 07:53 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Ok, so what's the adapter, 2 screws, and o-ring for??
Further and mentioned elsewhere. The NUT is wrong for 9C but may be fine for Hitec. Also pulled out as I didn't see the glue required. If you meant change the bolt, I have no intention of modifying even the slightest regarding the TX. When it is said it works in a 9C I expect it to work unless there is a qualifier.
You know I'm almost certain to buy an Aurora soon but almost $500 and I need to glue something in a TX part!!??
Spektrum is no better since the original module mast and replacement cracked at the base to release their threaded part, so I ca'ed them.
4*60 is offline Find More Posts by 4*60
Old Nov 18, 2009, 08:08 PM
A.T. is offline
Joined Aug 2002
To quick, please refer to amended original post with better explanation and photo.
regards
Alan.
Old Nov 19, 2009, 08:13 AM
dmajchrzak's Avatar
Joined Feb 2006
A.T. Great info. Thank.
Old Nov 19, 2009, 12:53 PM
A.T. is offline
Joined Aug 2002
Hitec AFHSS Spectra 2.4Ghz Module - Antenna Mast fitting.
Ok, so what's the adapter, 2 screws, and o-ring for?? Further and mentioned elsewhere. The NUT is wrong for 9C but may be fine for Hitec. <snip>.
Mast screws firmly down into the Aurora.
As mentioned previously, the "O" ring device is a simple locking device for multiple fittings. Allows mast to be used in other TX with different size/threaded bolts,(Futaba use two different size threads) the ring grabbing onto the antenna holding bolt in a similar manner to many hose fittings. Provides rapid easy change of antenna/module for the many who will continue to use old rx for some time.
The mast used as provided, with just the "O" ring engaged, is well braced within TX and has no effect on actual transmission, is secure and will not fall out.
Antenna Mount - suggested alternative fitting.
Regards
Alan.
Post Script:
Spectra Pro 2.4Ghz is also compatible with other Module Type Transmitters that use the same Futaba/Hitec module shape/size/pin slots. e.g.:
5UAF, 5UAP
7UAF,7UAFS, 7UAP,7UAPS, 7UHF,7UHFS, 7UHP,7UHPS
8UAF, 8UAFS, 8UAP, 8UAPS, 8UHF,8UHFS,8UHP, 8UHPS
(8FGA, 8FGH as non-module radios can not be accomodated).
9CA, 9CH, 9CAPS, 9CAFS, 9CHPS, 9CHFS
10CH, 10CA
(10CAG or 10CHG as non-module radios can not be accomodated).
Old Nov 21, 2009, 03:25 AM
4*60 is offline
most exalted one
Joined Aug 2002
Trust Futaba and I get the "different" size.
Question My 9C is now 2.4! Antenna question DiabloKid Radios 3 Sep 24, 2009 05:16 PM
Discussion Question about 2.4 Spectrum Recievers? lacofdfireman Radios 3 Sep 14, 2009 05:53 PM
Discussion JR Spektrum 2.4 Question Aero12 Radios 3 Aug 26, 2009 02:22 PM
Discussion JR 2.4 Installation in a carbon weave Electric Graphite Fuselage Bruce T. Sailplane Talk 0 Mar 22, 2008 10:12 PM
