Old May 29, 2010, 08:28 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Originally Posted by jbfoamy View Post
Very nice! Looks great!
Thanks.
Did you figure it out how the gyro cube comes together. Otherwise look at picture of new gyro board...Notice how each gyro is parallel to the axis it dampens. Gyro cube is put together same way - so that there is a gyro parallel to pitch, yaw and roll axis.
I have made new much smaller gyro boards that will fit inside housing from HK401 to use with the TH board I am getting from Niall. IŽll populate them tomorrow and post some photos then!
JussiH is offline Find More Posts by JussiH
Old May 29, 2010, 09:33 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Yep.: "* Type: Counter Rotating Matched Set"
Cheers,
Jim
Thanks Jim,
I used your mega link and found the quadroufo site. Here is the link to the props http://www.quadroufo.com/product_inf...0ii6vuajo06fs7
The way I read this, if I buy this I get one CCW and one CW prop? Am I reading this correctly?
jesolins is offline Find More Posts by jesolins
Old May 29, 2010, 10:55 PM
jbfoamy is offline
Find More Posts by jbfoamy
Cleveland, Ohio
Joined Jan 2006
Originally Posted by 420RcPilot View Post
Thanks.
Sounds good! I am getting the same board so, this will be perfect!
jbfoamy is offline Find More Posts by jbfoamy
Old May 29, 2010, 10:56 PM
jbfoamy is offline
Cleveland, Ohio
Joined Jan 2006
Cheers,
Jim
Thanks Jim!
I know where to buy now.
Old May 30, 2010, 04:11 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Reflowing is way cool. I am probably not gonna go that route though...that paste is also very expensive, but perhaps you have a good, cheap source?
But I was wondering if a "crashbang" aproach to soldering the TQFP package could be to use hot air combined with a light coat of normal 60% solder on pads and pins? I was thinking it might offer some of the benefits of reflowing (alignment, primarily).
Yep, I am going to just pre solder the pads and add flux.
Thanks for new Quad firmware.
One observation. I have been flying V1 tricopter and 4.1 quad. I use JR X9303 and Ar6100 RX (Spektrum DSM2).
If I turn of transmitter in tricopter V1 software (signal lost) motors just turn of regardless of throttle stick position. If I do this with Quad V4.1 I am seeing very irratical behavior of motors, including going full throttle....
That could potentially lead to situation where quad either just flies up and away and eventually crashes out of control and with all four props going at full RPM....and potentially not only just hitting someone but also carving the flesh out of their bodies.....
I would much prefer in the event of signal lost, that all motors goes to zero throttle and craft just "drops out of the sky". That seems much safer and manageable to me!
So did you build failsafe into the tri software that can explain the difference in behavior? Is this included in new 4.2 quad version?
No, there is no failsafe into any of the software versions. The RX's failsafe would override my failsafe, since they still output a valid PPM signal when signal is lost.
I think you have different failsafe settings on those RX'es
For RX'es without failsafe (the old FM system), counting illegal PPM pulses (less than 1mS or more than 2mS) and have it to shut down if there is more than a certain amount in a given time period, would be possible. But where to set the limit? Having it to shut down and fall out of the sky due to a few glithces is no fun. And having a large limit would cause a long delay before it shuts down and it probably would have hit the ground or mauled one's face already.
People who is concerned about safety should only use a radio link with error checking (FASST, DSM2 and probably some other) and properly set failsafes. They should also use heli program with a trottle cut switch or airplane program with a mixed in throttle cut switch and only turn it off when ready to lift off.
And finally remove the propellers when programming the chip ot testing new set ups.
I am not very concerned with loosing signal, though. Mine and other peoples tests with that RX and TX shows that reception is consistant to at least 5-600 meters and I never fly that far away.... for larger craft and FPV ship I would of course use a full range receiver with 1 or 2 satellites. But as they say, "st happens".....
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 30, 2010, 06:31 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Hi Guys. I have set up a basic home site for the project which is under construction. Please everyone put in your 2c in comments on how you would like to see the site develop.
www.kkmulticopter.com
If anyone would like to help with the step by step guides, that would be great.
Cheers,
Niall
Niall is offline Find More Posts by Niall
Old May 30, 2010, 06:38 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Cheers,
Niall
Nice, clean design
Next forum is really needed?
Here is best place to exchange informations IMO...
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old May 30, 2010, 06:40 AM
Niall is offline
Joined May 2010
Noted and fixed. It now links to this thread on RCgroups.
Cheers,
Niall
Old May 30, 2010, 07:05 AM
TigerPilot is offline
Find More Posts by TigerPilot
Joined Jan 2005
Cheers,
Niall
I can hardly read the main page. The background is black and the letters are gray. The letters should have more contrast to the background, and if you can, make the background not so dark. It's much more friendlier when it is bright.
Yoram
TigerPilot is offline Find More Posts by TigerPilot
Old May 30, 2010, 07:22 AM
cyborgcnc is offline
Find More Posts by cyborgcnc
The Drones are Coming!!!
cyborgcnc's Avatar
New York, NY
Joined Feb 2010
Cheers,
Niall
AWESOME Design!! Love Joomla!!
Good Job on getting this done, the site looks really nice!
cyborgcnc is offline Find More Posts by cyborgcnc
Old May 30, 2010, 07:49 AM
Niall is offline
Joined May 2010
Yoram
OK I changed the text to white instead as changing the background and all the images would have been a real mission.
Cheers,
Niall
Old May 30, 2010, 12:22 PM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
Looking good.
Is it asking too much to have an old version firmware archive and revision notes?
Eric
ergocentric is offline Find More Posts by ergocentric
Old May 30, 2010, 12:34 PM
monkeyking is offline
Find More Posts by monkeyking
Joined Jun 2006
Hi to all!!
Where can I get the PCB?
I want to buy one!
Please, let me know!
Thanks!
M.-
monkeyking is offline Find More Posts by monkeyking
Old May 30, 2010, 12:37 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Looks awesome!!!! Keep up the good work Niall!! Going to be checkin this out alot.
braindead4554 is offline Find More Posts by braindead4554
Old May 30, 2010, 12:48 PM
Niall is offline
Joined May 2010
Hehe... I still have some TH PCB left if you need one, PM me.
I will put up a shop in due course where KKmulticopter fans can put up their completed units for sale if they want. Like a classifieds kind of thing.
Please chip in with constructive criticism so we can make this the best multicopter site on the net.
I will work on an old firmware repository.
Cheers,
Niall
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
