Old May 25, 2010, 08:45 AM
ta2cba is offline
Find More Posts by ta2cba
United States, NY, New York
Joined May 2009
AVR Programmer
Hi Guys,
This AVR programmer http://www.mikroe.com/eng/products/view/6/avrprog2/
is very reliable and problem free.I am using it for sometime and find it easy to use. Just a thought.Hope it helps.
Cheers,
BA
ta2cba is offline Find More Posts by ta2cba
Old May 25, 2010, 08:56 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Originally Posted by Scorpia View Post
Fast, thats awsome, i was told that europe would probably be 7-10 days, looks like it was 6 including the weekend. AWSOME.
I hope it works for you. some build pics would be great.
I will post photos....shipping time took me by suprise as well...so the last components will arrive in a day or two....But I will probably start build with components from HK401 and XM401....
Am also deep into quadbuild, and the tri needs repair as well - so guess IŽll be burning the midnite oil....
JussiH is offline Find More Posts by JussiH
Old May 25, 2010, 09:48 AM
ben123 is offline
Find More Posts by ben123
NW England
Joined Jul 2005
Hello. I'm back from my holiday (during which I got to see the Atlantis space shuttle launch - amazing) and here is my finished but untested board!
The first picture shows the through holes I did. I drilled with a 0.6mm bit, put a piece of wire through, soldered both sides then filed it a little to make it flatter. Alignment was only off about 0.1 - 0.2mm on one plane... lamintor technique really impresses me.
The last 3 pictures are of the completed board: top, bottom and side. I slung in a penny for scale (pretty much the exact same size as a 1 cent coin). I'll weigh it tomorrow I hope as someone said they'd bring their digital scales into work for me
My motors, escs, radio gear also arrived during my holiday so lots of playing around in store for me to see if I can connect it all up!
Ben.
ben123 is offline Find More Posts by ben123
Old May 25, 2010, 11:53 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Ben.
Looks like a piece of art!! I rreally like your board layout and how you incorporated the gyros into it. Great work!!
braindead4554 is offline Find More Posts by braindead4554
Old May 25, 2010, 12:31 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by kapteinkuk View Post
Here is the new TriCopter version, It has faster yaw response.
Awesome flying Kaptein!!!
The control and response of your tri-copter is really fast and solid.
I'm building a tri-copter now, hopefully to use your new code soon
One question: the tail arm with servo and motor is a little longer due to the servo & twisting arm assembly, so should I cut the tail arm down a bit to make the tail motor at the same distant from the center of the tri-copter as the other two arms? Or should I just move the battery up to get the CG at the middle?
-Thanh
thanhTran is offline Find More Posts by thanhTran
Old May 25, 2010, 12:40 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
The board looks really great Ben!
Are those pots 2mm in size? I found some 2mm pots from Digikey, they look similar to the one you have there.
I'm building a board X-Y-Z MEMS gyro board (using 2 ST gyros). Hopefully I will then be able to use those gyros with your 2 layer edition. Should make a very small, thin & light board.
-Thanh
Old May 25, 2010, 12:51 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by bob4432 View Post
i was looking at that and had a question - do you build an additional board w/ the a socket for the type of chips you are going to program? kind of like a zif socket for a cpu? or are those, i guess possibly a breakout board it could be called, be purchased for the different chips?
Instead of using a ZIF socket, remove the unused pin receptors from a normal socket. Makes it easier to insert and remove chip.
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 25, 2010, 12:55 PM
Quad Whisperer
Joined Jul 2008
What "C" rating batteries are you using? I was thinking that 2200Mah wouldnt give enough current to run 4 motors. but i guess a high C rating might work.
Also what ESC are you using?
I use 2200mAh, 20C
Esc is Turnigy Plush 25.
Old May 25, 2010, 01:05 PM
Quad Whisperer
Joined Jul 2008
-Thanh
Cut the arm down to get equal distances, and move the battery forward to offset the weight of the servo.
Old May 25, 2010, 02:09 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Ben.
That is one nice piece of work!
What is the board dimensions - looks to be way smaller than 50*50 mm....?
Old May 25, 2010, 03:32 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
OK guys here are the pics of the Through Hole PCB.
Niall is offline Find More Posts by Niall
Old May 25, 2010, 04:59 PM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
very nice, congrats!
Bob
Ben.
bob.titus is offline Find More Posts by bob.titus
Old May 25, 2010, 05:05 PM
Scorpia is offline
Find More Posts by Scorpia
Australia, VIC, Narre Warren
Joined Apr 2010
I use 2200mAh, 20C
Wow, thats good news.
I thought that a 20c wouldnt cut it. So then current draw must be under 10amps per motor under normal flying. very nice.
Peter
Scorpia is offline Find More Posts by Scorpia
Old May 25, 2010, 05:11 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
I'm using 5000mAh 15C (75A max) on rather large quads (2200g) without any issue.
As long as your max amp draw does not exceed the battery capacity to deliver amps, it's ok.
If you draw 15 amps max per motor, that's a total of 60 amps. With a 4000mAh at 15c you can deliver 15x4A = 60A so you are good. Anything below could be a problem.
FWIW,
Bob
Old May 25, 2010, 06:07 PM
ben123 is offline
NW England
Joined Jul 2005
Thanks guys Just hope it works or is easily fixed or else its just a paperweight with an interesting story!
Thanh:
The pots are around 4mm square and are these ones :
http://uk.rs-online.com/web/search/s...duct&R=177-223
I'll post the final, fully tidied-up Eagle files once I know it works
420RcPilot:
It's about 3.2x3.7cm at the moment but could be smaller with a bit of trimming I think. I wish I'd used thinner copper-board... I see it comes in thinner sheets. But maybe wouldn't help vibrations?
I've been playing around with the tx and rx tonight. The set didn't come with any instructions :s It's the 6 channel Hobbyking 2.4GHz set... it has six channels labelled ch1-ch6 but I'm not sure which channel corresponds with which function so I'm a little confused but I'm sure a little Googling will sort that
I bought some thin carbon fiber plate and hollow 3mm diameter carbon fiber tubes to construct a frame. Will be fun trying to bodge something together that won't rattle itself apart on its maiden flight/crash
I'm going to build this ISP programmer to program my atmega48. Anyone ever used it?
http://www.mytutorialcafe.com/Microc...er%2089S51.htm
Ben
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
