Old May 05, 2014, 07:05 AM
Armagan is offline
Find More Posts by Armagan
Joined Apr 2014
firmware
I'm not sure to be honest, its whatever came with the board
Armagan is offline Find More Posts by Armagan
Old May 06, 2014, 05:53 AM
adyach is offline
Find More Posts by adyach
Joined May 2014
KKMulticopter roll pot does not work
Hello everyone!
I have a problem with reversing the gyros on KKMulticopter.
I had the pre-uploaded firmware when I bought it. I don't know the particular version of the firmware but the seller says it is 2.3 version. Set it up without any issues: escs callibraction, centring, gyros reversing but now I uploaded 2.9 version throught the use of the kkmulticopter flash tool (Thanks to author!) and I can not reverse the gyros. When I set the the roll pot to 0 (CW) the led does not flashes several times. I also tried to set roll pot CCW. Nothing happens. The centring and escs callibration works fine.
Could someone tell me, please, what my problem is?
Thank you in advance!
adyach is offline Find More Posts by adyach
Old May 06, 2014, 08:06 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by adyach View Post
Hello everyone!
You have no problem. I noticed this long ago and asked Minsoo Kim about that. And he answered me this.
Dear Sir
Thank you for your interesting.
it isn't need the gyro reverse after v2.2.
Thanks & Best regards
Minsoo
Subject: Gyro reverse process
Dear Minsoo,
I figured out that the gyro reverse process is broken for blueboard
firmware newer than 2.2. Or did the process change?
Best Christian
Christian
LazyZero is offline Find More Posts by LazyZero
Old May 06, 2014, 08:45 AM
adyach is offline
Joined May 2014
How interesting... Thank you very much!
Should I use Yaw trim to reduce rotations? Or is there any other way to escape Yaw rotations?
Old May 06, 2014, 09:09 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Only thing is to build your copter according to the motor layout of Minsoo.
Old May 06, 2014, 10:19 AM
adyach is offline
Joined May 2014
Sorry for interrupting you again!
I have followed this manual to set up the motors but without any success it still rotates.
Could you, please, tell me what else I can do?
UDP: I went back to 2.2.
Old May 06, 2014, 02:11 PM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Yes That manual should work for the firmware.
Old May 07, 2014, 03:10 PM
Armagan is offline
Joined Apr 2014
calibrating throttle
Can you guys help me, I've been stuck on this for ages trying to calibrate the throttle.
I turn on the tx, set to full throttle. Turn on the quad. Board flashes 3 times, receiver is on, the escs start to beep.
When I push the throttle down to tell it the lower end of the range. The esc should acknowledge it but does not seem to. Instead they go into programming mode. When I try to set battery type it does not acknowledge my stick movement.
So my question is when you set the throttle range should it include going into programming mode or is it meant to just set the lower range?
Any help appreciated
Old Jun 01, 2014, 09:34 AM
Remco_NL is offline
Find More Posts by Remco_NL
Remco_NL's Avatar
The Netherlands
Joined Dec 2013
KK 2.0 forgets self level settings in flight :-(
Hello everybody ,
I have a question.
My tricopter flying in self level mode forgets it's level Settings after a few minutes of flying.
After acc calibration it flies perfect, a few minutes later it just takes of forward and to the right..
I just dont get it .. What am i doing wrong?
Tricopter 1000 grams including lipo
980 kv sunnysky motors
Afro 30 amp esc
Kk 2.0 1.6
Graupner 9x5 eprops
Best,
Remco
Remco_NL is offline Find More Posts by Remco_NL
Old Jun 01, 2014, 01:56 PM
caboom is offline
Find More Posts by caboom
Joined Jun 2014
Hello,
I am trying to track down a datasheet for the gyros on the kk multicopter board V3.0. Any help would be appreciated(including their series which I cannot read of them).
Thanks.
caboom is offline Find More Posts by caboom
Old Jun 02, 2014, 07:17 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by Remco_NL View Post
Hello everybody ,
I have a question.
Afro 30 amp esc
Kk 2.0 1.6
Graupner 9x5 eprops
Best,
Remco
Wrong thread.
er9xuser is offline Find More Posts by er9xuser
Old Sep 14, 2014, 05:42 AM
barttheys is offline
Find More Posts by barttheys
Joined Feb 2013
Is there somewhere an overview, how-to , tutorial about creating or modifying the code for the KK2 board ?
barttheys is offline Find More Posts by barttheys
Old Dec 12, 2014, 10:35 AM
Skyman8555 is offline
Find More Posts by Skyman8555
Joined Dec 2014
KK Black Board help
I am new to muticoptors and have built a hexacoptor with the KK Blackboard. I have read the sites setup procedures but I am totally confused. I apply power to the board through the esc's and I hear them power up and the board led flashes blue then goes out the ESC's continue to beep and slowly. I tried to calibrate the radio but nothing works. Please help
Skyman8555 is offline Find More Posts by Skyman8555
Old May 01, 2015, 07:31 PM
Tech554 is offline
Find More Posts by Tech554
Joined May 2015
Help with Coding
I'm trying to follow up with the flight controller, but I have trouble coding. Atmega328p is what I am using, can I use the codes provided to program the chip with an Ardunio Nano.
Tech554 is offline Find More Posts by Tech554
Old May 11, 2015, 04:25 AM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Hello, I got an old KK board V3 from HK I bought ages ago. My question is : is the KK board able to handle brushed ESC? If so, how? I haven't seen anything related to this on the manuals. Thanks!
Teckos is offline Find More Posts by Teckos
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
