Old Dec 10, 2012, 08:23 PM
Henry. is offline
Find More Posts by Henry.
Chilled and served
Henry.'s Avatar
Sweden
Joined Mar 2005
Just so i donīt make a mess the first time i fly; if i push the direction stick full in any direction will the quad then continually spin around that axis or will it stop at a certain degree or so and not spin and just going forward?
Im so dam scared that it will spin around its axis and crash so i havenīt dare tried it out yet.
Henry. is offline Find More Posts by Henry.
Old Dec 11, 2012, 01:27 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
It will continue to spin on its axis.
Steveis is offline Find More Posts by Steveis
Old Dec 11, 2012, 03:10 AM
Henry. is offline
Chilled and served
Henry.'s Avatar
Sweden
Joined Mar 2005
I just remember that i have read somewhere that it in some mode would it stop at 45 degree or so to prevnet this for beginners or so or i might have mixed this up with something else?
Old Dec 11, 2012, 04:13 AM
rcimports is online now
Find More Posts by rcimports
South Africa
Joined Oct 2005
The normal KK doesn't have ACC, so it doesn't know it's angle, it will continue to spin, ACRO mode
Dion
rcimports is online now Find More Posts by rcimports
Old Dec 11, 2012, 02:56 PM
Henry. is offline
Chilled and served
Henry.'s Avatar
Sweden
Joined Mar 2005
Ah that was sad. I thought it could be calculated from the gyros, but ok.
Old Dec 13, 2012, 06:59 PM
anlpereira is offline
Find More Posts by anlpereira
Joined Dec 2012
Hi, I have a problem with my KK board, I can't reverse my yaw gyro. After put the roll pot to zero position I turn on the board but the led doesn't blink for 3 times. Does anyone face this same problem?
Thank you
anlpereira is offline Find More Posts by anlpereira
Old Dec 14, 2012, 03:04 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Thank you
Try the other way.
er9xuser is offline Find More Posts by er9xuser
Old Dec 16, 2012, 09:02 PM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
I am having issues registering on the kk website.. tried 3 different browsers, 3 different computers, 2 different connections and OS.. same issue, after clciking register I just ge ta blank screen.
Tried sending a message via contact tab and got same issue..
Mick Molloy is offline Find More Posts by Mick Molloy
Old Dec 23, 2012, 06:58 PM
IIIBonesAirForce is offline
Find More Posts by IIIBonesAirForce
Grounded Pilot
IIIBonesAirForce's Avatar
USA, MN, Rochester
Joined Jul 2007
Aluminum Frame for KK FC
check out my 41" frame. In the process of building my second one with 1"X1" aluminum frame. Frame weight is 18 Oz, The first one has KK 1.2 flies great and on the large 41" aluminum frame I am going with RC Timers 650 KV motors. It is a work in progress.
IIIBonesAirForce is offline Find More Posts by IIIBonesAirForce
Old Jan 18, 2013, 11:27 AM
UAVJOE is offline
Find More Posts by UAVJOE
Sr. Ext. UAS Pilot, NMSU FTC
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
When I try to arm my KK board the blue LED lights up and then just beeps slowly and I never get motor control. What is the issue?
UAVJOE is offline Find More Posts by UAVJOE
Old Jan 24, 2013, 10:33 AM
cweeks0515 is offline
Find More Posts by cweeks0515
United States, AZ, Surprise
Joined Jul 2011
try arming from the other direction -- i think mine arms with left rudder but if you reverse the rudder it arms from the right ??At any rate, on one direction the board disarms, in the other the board arms.
cweeks0515 is offline Find More Posts by cweeks0515
Old Jan 25, 2013, 02:42 PM
XPFTP is offline
Find More Posts by XPFTP
Joined Apr 2007
am lost
hello.. i have the KK Compatible Multi-Rotor Control Board (Blue Ver. 2.5 Firmware)
http://www.valuehobby.com/multicopte...rol-board.html
Support standard KK firmware (With Atmel 168 MCU)
Latest KK firmware pre-installed: Version 2.5 (Blue Board)
Three pre-installed configurations available: Quadcopter, Xcopter, Tricopter
i got this board as it stated it did single .. wanted to try gettin it on my heli for the fun of trying..
issue is iam unable to get the software AVRstudio and the http://lazyzero.de/kkflashtool software...
any good manual for this ? or step or setup site ?? i get errors of fuse and unable to contect to the board..
any help would be awsome thank you
XPFTP is offline Find More Posts by XPFTP
Old Jan 26, 2013, 04:09 AM
XPFTP is offline
Joined Apr 2007
will one less person goin to quads .. seems no company will support there hardware and none out there welling to help with this .. seems if i was goin to run quad probley ..
o will
Old Feb 01, 2013, 07:21 AM
South Africa
Joined Oct 2005
I'm missing what you are trying here?
Old Feb 11, 2013, 11:31 PM
Henry. is offline
Chilled and served
Henry.'s Avatar
Sweden
Joined Mar 2005
The 168 needs a refrence voltage for the gyros according to the schematic, what would be the optimum voltage? I think itīs under 2V but i have understood it need to be quite exact.
Anyone knows?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
