Old May 19, 2012, 07:54 AM
nimic is offline
Find More Posts by nimic
Joined Dec 2011
How do i do that?
nimic is offline Find More Posts by nimic
Old May 20, 2012, 07:26 PM
mcashatt is offline
Find More Posts by mcashatt
mcashatt's Avatar
United States, AZ, Gilbert
Joined May 2012
KK Spider??
Hi KK,
I would like to modify your code for a spidercopter. Can you tell me what IDE and Language I need as well as the location of the codebase?
Thanks!
Matt
mcashatt is offline Find More Posts by mcashatt
Old May 21, 2012, 02:25 AM
Minsoo Kim is offline
Find More Posts by Minsoo Kim
Joined Apr 2008
Hi All
this board is supporting the kkcontroller
To be added to the Navy Board firmware v 2.1 features introduced have prepared a airfight.
FlyCam Naviboard II - Airfight (3 min 52 sec)
The video includes as below
1. Fun XCopter with the naviboardII and XCopter with only a black Board airfight.
2. Fun XCopter with the naviboardII and the plane airfight.
3. front and back on the firecracker Fun XCopter with playing fireworks at high altitude.
GPS position hold and maintain altitude move only with the rudder in place while the Xcopter is rotating and are fireworks
Here's a wireless electronic switch on the transmitter to the OFF/ON by manipulating the Xcopter has LED suddenly appears and reappears
FlyCam MultiCopter Airfight and Fireworks (4 min 37 sec)
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old May 21, 2012, 02:44 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
The shoot-out was awesome hehe
Kris... is offline Find More Posts by Kris...
Old May 27, 2012, 01:32 AM
justk1w1 is offline
Find More Posts by justk1w1
Joined Apr 2012
HK v3 KK board
Originally Posted by Hman :) View Post
Just finished the board and tried to program it, but I keep getting an error :/
This is what it says:
Flash the firmware from repository.
C:\Users\Chhokar\Desktop\kkmulticopterflashtool_0. 61\lib\avrdude\windows\avrdude.exe -C C:\Users\Chhokar\Desktop\kkmulticopterflashtool_0. 61\lib\avrdude\windows\avrdude.conf -p m328p -P usb -c usbasp -B 8 -e -U lfuse:w:0xe2:m -U hfuse:w:0xd9:m
avrdude.exe: set SCK frequency to 93750 Hz
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude.exe: Device signature = 0x1e9514
avrdude.exe: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude.exe done. Thank you.
Error during setting the fuses.
Flashing of firmware aborted.
Double checked with a multimeter and the programmer is correctly connected to the chip. With no short circuits.
This is the chip I used.
http://www.protostack.com/microcontr...icrocontroller
Newbie to Multirotors - have the Talon V1 frame with the HK V3 board setup in Quadcopter config. I have been having heaps of issues, but the first hurdle I would like to get past is:
Trying to flash a HK ver 3 kk board
I'm having the same issues as listed in this post and I have tried both version 0.65 and 0.53, but get the same error.
Also having the same issue with a lazy #4 motor - hence why I was trying to flash the board
justk1w1 is offline Find More Posts by justk1w1
Old May 27, 2012, 01:39 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
What controller did you select in the flashtool?
The hk V3 board should be atmega328p and not this problem.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old May 27, 2012, 01:44 AM
justk1w1 is offline
Joined Apr 2012
Best Christian
Selected the hk v3 which has the mega 168pa
Old May 27, 2012, 01:47 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Sure you have a V3 board? The blue V3 has a 328p not 168pa. Sound like you have a V2.1.
Best Christian
Old May 27, 2012, 01:51 AM
justk1w1 is offline
Joined Apr 2012
Best Christian
Well that's a little embarrassing .. you are correct its a 2.1 .. will try again .. thanks
what would be the correct firmware version to flash for a quad config. I just want a non aggressive learner and where could I find a setup document.
Old May 27, 2012, 04:10 AM
Hman :) is offline
Find More Posts by Hman :)
Joined Nov 2009
This might be helpful:
http://www.rcexplorer.se/Educational...e/kkguide.html
Hman :) is offline Find More Posts by Hman :)
Old May 27, 2012, 03:06 PM
RootCanalGuy is offline
Find More Posts by RootCanalGuy
RootCanalGuy's Avatar
Joined Aug 2010
Manual
I have loaded this firmware on my tricopter (FPV Manuals) however, I have not been able to locate a manual; is there a manual for this ?
2.0 is about one year old. 2.5 is the latest firmware from Minsoo for generic kkboards.
Best Christian
RootCanalGuy is offline Find More Posts by RootCanalGuy
Old May 27, 2012, 03:14 PM
Joined Aug 2010
Anyone using version KK firmware 2.5 on tricopter successfully? I am about to give up on 2.5
Old May 27, 2012, 09:14 PM
scottflight is offline
Find More Posts by scottflight
scottflight's Avatar
Arvada, CO
Joined Aug 2004
Howdy, which FW do you guys prefer for a x type quad. I've tried the minsoo, the xcopter, and I'm about ready to try out the quadcopter version. The first two worked once I figured out the trimming and motor arrangement. I have a small quad with 19g motors and I'm running a 3 cell, 12 amp HK speed controllers and I've got the v3 board.
She seems really sensitive to the P trim pot, I've got it near zero. I've probably got too firm a connection of the board to the frame, 2 layers of foamtape. 22" motor to motor diagonally for frame size, 15" motor to motor on the square. 7x3.5" props.
Anyway, which FW do your prefer for just cruising around.
thx
scottflight is offline Find More Posts by scottflight
Old May 28, 2012, 04:42 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
thx
V4.7 x from kapteinkuk
er9xuser is offline Find More Posts by er9xuser
Old May 28, 2012, 02:28 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
RootCanalGuy, my KK board came pre-programmed with MK 2.5 (Minsoo Kim) firmware and that seemed to work fine. What problems are you having with it?
I flashed KK v1.6 tricopter not long after and liked it better so I'm still using it.
mattcro is offline Find More Posts by mattcro
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
