Old Feb 02, 2012, 03:58 AM
tomytomiak is offline
Find More Posts by tomytomiak
Slovakia, Bratislava Region, Bratislava
Joined Jun 2010
Originally Posted by er9xuser View Post
I think you can fly with non programable ESC's.
No, quad will fall down. Try to remove one esc from board and you will see.
I failed with calibration of ESCs. They starts in different time. I tried to use described calibration, but there is no two beeps as it should be... When the ESCs are in calibration mode and I move stick down (it seems I tried everything), they starts in the same time...
ok, what a pity
tomytomiak is offline Find More Posts by tomytomiak
Old Feb 02, 2012, 09:22 AM
scott page is offline
Find More Posts by scott page
Left RCG because of Trolls
Joined May 2009
Unfortunately, those links are not working for me. I get 404 on them.
EDIT: I used the product number in the link to identify the ESC you are using: I found this information:
To program this controller you have to move transmitter throttle to full position.
Now connect battery to controller.
Wait some seconds, than you hear:
*peep* - *short pause* - *peep*
*pause*
*peep*peep* - *short pause* -*peep*peep*
*pause*
*peep*peep*peep* - *short pause* -*peep*peep*peep*
*pause*
this sequence will repeat...
When you want to use NIHM cells, you have to move throttle to off position when you hear the first *beep*beep*. Than you have to wait for a longer *beeep* and a short *beep*. That's all. You can disconnect battery now.
When you want to select LIPO mode, start from the beginning (throttle full, connect battery, listen to the beeps)
At the time when you hear the first single *beep* move throttle to off and wait for
*beeep* and *beep*.
When you want to switch Brake On or Off, start from the beginning, then wait for the first *peep*peep*peep* within one sequence and put throttle to off. Wait for *beeep* and *beep*.
Note: When you connect battery and throttle is in off position you will hear a long *beeeep* when LIPO-mode ist selected or a short *beep* when NIMH-mode is active.
Originally Posted by tomytomiak View Post
ESC calibration problem and Question about general stability...
I have just finished my Q4+ based on kaptainKUK.
My ESCs do not start at the same time. I have this one
http://www.hobbyking.com/hobbyking/s...idProduct=6457
which is simple product without basic programmable possibilities.
1. My question is how does it work in source code? Will it really help if I buy this one:
http://www.hobbyking.com/hobbyking/s...idproduct=6548
or
http://www.hobbyking.com/hobbyking/s...idproduct=6458
2. My second question concerns of general stability. If Q4 loses one propeler will be Q4 able to land, or will it crash?
thankx to anybody for reaction
scott page is offline Find More Posts by scott page
Old Feb 02, 2012, 09:37 AM
Joined Jun 2010
To program this c.....ep* - *short pause* -*peep*peep*peep*
*pause*
W.................*beeeep* when LIPO-mode ist selected or a short *beep* when NIMH-mode is active.
Thanks Scot. Of course I have already downloaded manual for HK SS ESC, tried to calibrate, but without success. More directly by email.
thank you.
Old Feb 02, 2012, 10:04 AM
Joined May 2009
thank you.
In another thread -- Christian requested that we with motor 4 issues flash the NORMAL quad 4.7 rather than the X configuration - and check the motors. How about you do that and see if the problem goes away. Of course you'd have to rotate the board 45 degrees left in order to fly -- but with the results your having you should notice the difference right away -- if there is one.
Latest blog entry: Making my own tray
Old Feb 02, 2012, 10:12 AM
Joined Jun 2010
Could you send me a link of that thread? Thank you. I will try, of course, there is nothing to lose.
Did they use ESC HK SS nonprogrammable and does Q4 work?
thanks
Old Feb 02, 2012, 10:23 AM
Joined May 2009
thanks
http://www.rcgroups.com/forums/showthread.php?t=1458663
Old Feb 03, 2012, 12:59 AM
Tomf35 is offline
Find More Posts by Tomf35
Joined Jun 2011
Tittle : A Swarm of Nano Quadrotors
A Swarm of Nano Quadrotors (1 min 43 sec)
Have a look the above video.
Tomf35 is offline Find More Posts by Tomf35
Old Feb 03, 2012, 02:25 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
http://www.youtube.com/watch?v=YQIMG...ature=youtu.be
This video needs its own separate sub-forum.
slim1357 is offline Find More Posts by slim1357
Old Feb 03, 2012, 07:59 PM
MOTOSTEIN is offline
Find More Posts by MOTOSTEIN
Joined Sep 2011
Kk blows goats
dude kk stands for KRAP KRAP LEWARN HOW TO MAKE SOFTWEARE U RETRARDS I HATYE UR GUUTS UR KRAP
\T BL;OWES
MOTOSTEIN is offline Find More Posts by MOTOSTEIN
Old Feb 03, 2012, 10:46 PM
slim1357 is offline
slim1357's Avatar
Joined Dec 2010
\T BL;OWES
Please elaborate
Old Feb 03, 2012, 11:39 PM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
\T BL;OWES
Hey man. Drink some schnapps and then tell us what is the problem
er9xuser is offline Find More Posts by er9xuser
Old Feb 04, 2012, 12:01 AM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
probably lazy 4-th motor. LOL.
man1024 is offline Find More Posts by man1024
Old Feb 04, 2012, 12:59 AM
slim1357 is offline
slim1357's Avatar
Joined Dec 2010
I think we need to speak his language, here let me try.
M0T0$tEIN i$ N00B TIMES A MILLIUN HE COULDUNT FLY A PAER AIRPLANE!! LERN TO FLIY DUMA$$ MOTOR 4 PROBLEM IS FOR LOOSERS.
Old Feb 04, 2012, 02:19 AM
dompower is offline
Find More Posts by dompower
Flying like a bird!
dompower's Avatar
Saudi Arabia, Riyadh Province, Riyadh
Joined Feb 2010
Hi friends,
I hope my summary will help all.
1. For Quad copter make four sets of Motor and ESC and mark them as I,II,III,IV
2. Make Throttle Range Calibration for each set. Connect the ESC and to Rx and make throttle calibration. ( fix the Max, Min throttle range. Repeat this for every set of Motor and ESC) make the ESC programming as per KK recommendations and ESC guides.
3. Once you install the FC (flight controller board) , ESC and motors ..again make Throttle Range Calibration by the procedure mentioned in KK manual.(in most of the KK's turn yaw pot to zero, and turn on Tx , Throttle Stick to full, after ESC confirmation beep, lower the Throttle Stick to bottom)
4. Throttle range calibration is very important for any multicopter system. It is needed to start all the Motors evenly. Though controlling each motor will be taken care of the FC board, initially all the motor starts from the same Throttle Stick Position. After the calibration setup, try to move the throttle stick from zero to max. All motors must start evenly. If not, the ESC is not calibrated or... ESC or motor has problem)
5. Since there are many KK variants, we have to be careful in propeller directions. Pls check propeller directions before you are ready to fly.
for example: in Hobby King KK, the directions for + or X mode are… M1 (Front) = CCW, are M2 (Left) = CW, M3(Right)=CW, M4(Rear) = CWW
Note: be sure the sockets are connected in the correct order. From FC board M1 to Motor 1’s ESC …. M4 to Motor 4’s ESC. Pls double check this.
I keep dots as shown in the attachment to identify the correct orders.(My photo is for OpenPilot CC FC...just to show how I mark them by dots)
Also I hope my attachment will help for the the powerline wiring.
Dominic
Saudi Arabia
dompower is offline Find More Posts by dompower
Old Feb 04, 2012, 05:48 AM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Can someone show me the connections to the FC for the esc's?
I have a hexa are all the wires (black, white and red get connected to the M1,2,3,4,5,6) or just the signal wire?
bcollydas is offline Find More Posts by bcollydas
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
