Old Nov 18, 2011, 03:39 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Sources for 1.7 are closed.
aeroplane Firmware in general is closed.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Nov 18, 2011, 03:57 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Christian
Can you tell me where it can be downloaded the 1.7 ?
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 18, 2011, 04:11 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
I have uploaded the Versions 1.6 - 2.1 to my homepage you can find them here:
http://lazyzero.de/_media/modellbau/...plane_v1_6.zip
http://lazyzero.de/_media/modellbau/...plane_v1_7.zip
http://lazyzero.de/_media/modellbau/...plane_v2_0.zip
http://lazyzero.de/_media/modellbau/...plane_v2_1.zip
Best Christian
Old Nov 18, 2011, 05:13 AM
ChiKung is offline
Find More Posts by ChiKung
Joined Aug 2011
Does that aeroplane firmware work with HK's Quad Copter control board V2 (Atmega 168PA) ?
Or maybe with older one with Atmega48PA? If not, is it possible to somebody who has access to source to convert it suitable for Atmega48PA ?
ChiKung is offline Find More Posts by ChiKung
Old Nov 18, 2011, 05:19 AM
e_lm_70 is offline
Austria
Joined Jan 2004
You have a very nice page LazyZero
Actually I got yesterday a cheap USB AVR programmer, and I had to re-invent the wheel ... I see somebody did the same in July ... anyhow, I was using some 1 pin female 2 female jumper, but thanks to your page, I just reconfigure the 8pin 2 8pin cable, for adapt the position ... and it works nice ... and I free my jumpers in this way
Tchuss
e_lm_70
ps: A aeroplane firmware sound the most simple firmware ... strange nobody did open it up already ...
Old Nov 18, 2011, 05:31 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I'm afraid they don't fit inside the Atmega48 ... all these firmware are just a bit over the 4KB ...
If you can find the source code ... it is not difficult to make them slim .. as well is not a big issue to make your own ... I may will do one day ...
I have the HK KK old board too ... the bad thing is that it has only 4 output, and it need soldering for add the 2 missing ...
Tchuss
e_lm_70
Old Nov 18, 2011, 05:42 AM
ChiKung is offline
Joined Aug 2011
Iv added one sketch in previous page. Im not that familiar with asm, so dont know if it works. The point for that pseudo code is to show a bit different calibration sequence for no-motion calibration.
Ps. The reason for the need for source code is that later I want to add gain control from air speed sensor. Also I would like to add a servo rate limiter for flaps. Those are optional, but I would like to get a working source code for testing.
PPs. avr studio 5 is annoying..
Old Nov 18, 2011, 06:04 AM
e_lm_70 is offline
Austria
Joined Jan 2004
It is ASM what you posted before ...
I hate ASM ... it is faster start from 0 with C.
From Quad Open Source, you can read how to handle servo in and out , and how to read the Gyro and the Pot .. the Eprom, etc etc. ... All is needed is to add some logic for aeroplane .. it could be done in a weekend of coding, even less ... but not sure I want to do this in any coming weekends
Tchuss
e_lm_70
Old Nov 18, 2011, 06:40 AM
ChiKung is offline
Joined Aug 2011
Yep. I used the V4.0 quad code for that (gyro/servo reversing is not needed while the code must be converted anyway). I guess the main con with asm is the low level code, but that is prolly not the major problem when modifying already working code. Main loop itself seems to be pretty simple.
Old Nov 18, 2011, 08:35 PM
NightRunner417 is offline
Find More Posts by NightRunner417
Fly Like A Thing Posessed!
NightRunner417's Avatar
USA, FL, Fort Myers
Joined Nov 2010
Hi all,
Does anyone have good experience with these props?
http://www.rctimer.com/index.php?gOo...7&productname=
I'm interested in cost effective alternatives to the APC 10x4.7 slow fly props. My bird is an X-copter with four RC-Timer 2630/13 850kv motors. AUW is 1.4KG if I use my big 4000mAH pack, and that's absolute maximum. I have some GWS 10x4.7 or something slow fly props (just no counter rotating versions so I can't test fly them) and they seem awfully flimsy compared to the APCs, and they do look like the ones on that webpage... I'm concerned that my quad's weight will break them if they're too weak.
Any opinions would be really appreciated.
Rick NR417
NightRunner417 is offline Find More Posts by NightRunner417
Old Nov 18, 2011, 11:15 PM
sovit is offline
Find More Posts by sovit
Украина, Запорожская область, Запорожье
Joined Jun 2011
my motors of DT750 destroy them at high speed. It is very weak propellers .
these will be better:
http://www.hobbyking.com/hobbyking/s...3pc_Each_.html
sovit is offline Find More Posts by sovit
Old Nov 19, 2011, 06:03 AM
ConWolf is offline
Find More Posts by ConWolf
Joined Aug 2010
Problem with Roll-Gyro
Hello,
Unfortunately there is a problem with my roll-gyro. If it tilts over to the left side, the left motors speed up und work right. But if it tilts over to the right side, there is no reaction of the motors and gyro.
Any idea?
Thank you!
Con
ConWolf is offline Find More Posts by ConWolf
Old Nov 19, 2011, 07:57 AM
ConWolf is offline
Joined Aug 2010
Edit: Flashed with H6Copter V2.3
Blackboard V5.5
Old Nov 19, 2011, 08:06 AM
USA, FL, Fort Myers
Joined Nov 2010
Blackboard V5.5
I'm just really getting started with my own quadcopter so I don't know much, but I did have big problems with her at first and they turned out to be firmware related. Maybe try a different firmware?
Rick NR417
Old Nov 19, 2011, 08:08 AM
USA, FL, Fort Myers
Joined Nov 2010
Found this on Wikipedia while researching motor tilt angle for quadcopters that have all props spinning the same direction:
Lol I didn't know that such a thing existed, especially that long ago. :-)
http://en.wikipedia.org/wiki/De_Bothezat_helicopter
Rick NR417
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
