Old Jun 15, 2011, 03:30 PM
rinatka7 is offline
Find More Posts by rinatka7
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
Originally Posted by Gaza07 View Post
You shoud try this KKmulticopter Flash Tool it is what I use and will download whatever firmware you select
Or click on the copy below
I download KKmulticopter Flash Tool.
I didnt see two diff. version firmware v.4.5 (for X mode and + mode), only quadrocopter (V4.5 [m48] kkmulticopter.com).
XCopterV1_1.zip where do you get it? May i have a link for it?
It is not a very very old and simple firmware?
rinatka7 is offline Find More Posts by rinatka7
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
Originally Posted by Mike Barton View Post
if copter goes out of trim, it's usually because of gyro drift, and the drift depends on the gyros used.
The piezo murata ones are known to drift. I was flying yesterday and continually had to re-calibrate the gyros after only a few minutes flying
Supposedly it's because of temperature changes...
Mems gyros are alot better but most boards don't use them.
I'm using the blue card from kkmulticopter...
it seems to me like I have to trim if I land in a slope, I'll test this in next flight!
Foskje is offline Find More Posts by Foskje
Old Jun 15, 2011, 03:32 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
V1.1 is the highest version for X on a Atmega48
v4.5 is +
Gaza07 is offline Find More Posts by Gaza07
Old Jun 15, 2011, 03:48 PM
rinatka7 is offline
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
v4.5 is +
Thank you very much for help!
If it is possible could you please give your skype name for PM? If yes - send it to my PM!
Old Jun 15, 2011, 03:51 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Your welcome anytime but I dont use skype but you could always pm me here as I lookin every day and sometimes use MSN if you want my MSN then I could pm you that
Old Jun 15, 2011, 03:55 PM
rinatka7 is offline
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
I dont use MSN lie you dont use skype! ))
I see in you profile email ....@hotmail.co.uk maybe we will use email?
Old Jun 15, 2011, 03:58 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Yes you can use that email it is also my MSN ive never used skype
Old Jun 15, 2011, 04:04 PM
rinatka7 is offline
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
i make a mistake: I dont use MSN liKe you dont use skype! ))
my English is very poor!
Old Jun 15, 2011, 04:07 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Yea I worked out the K was missing but did wonder when I first read it
Old Jun 15, 2011, 04:42 PM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
this is it so far
kristjane is offline Find More Posts by kristjane
Old Jun 16, 2011, 01:04 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
You don't need to download the XCopterV1_1.zip it is already included in the flashtool. It is the high lighted one
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Jun 16, 2011, 06:39 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Check out the best value KK board:
http://www.rcgroups.com/forums/showthread.php?t=1445151
dt8666 is offline Find More Posts by dt8666
Old Jun 16, 2011, 11:54 AM
Flyingfool is offline
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Hey Christian,
I sent you a PM with what your program is telling me and the contents of the log file from when I try to flash my KK blue board as you asked me to.
Just wondering if when I plug my programmer in are both lights supposed to light up as I don't remember if they did the first time I flashed my board.
They are both lighting up when plugged into the usb.
Randy
Flyingfool is offline Find More Posts by Flyingfool
Old Jun 16, 2011, 12:51 PM
rinatka7 is offline
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
Hello.
I have a new problem.
Pitch gyro reaction is very low. I mean when i tilt quad to forward reaction is very quick, but when i tilt quad to right or left(in + mode) i didnt hear motor speed up(if i manually hard move a pitch gyro then i hear motor speed up). All pots in a central position. What is this?
I didnt glue gyro yet, so i can move it in their direction.
Old Jun 16, 2011, 01:02 PM
jorgen is offline
Find More Posts by jorgen
Joined Jun 2010
Here's the settings for my quad. It might help someone else like me who does this for the first time...
Settings on the Spektrum DX6i:
D/R&Expo:
All INH
Travel Adjust:
Thro: 125%
Aile: 50%
Elev: 50%
Rudd: 100%
Sub trim:
all 0
Mix 1 & Mix 2:
INH
Differential:
Inhibit
Model Type:
Acro
Reverse:
Thro-N
Aile-R
Elev-R
Rudd-R
Thro Cut
Inh
Wing tail mix
Inh for all
D/R combi
Inh
I've Turnigy Plush 25A ESC and I've programmed them like this:
Brake: off
Battery type: NiMH
Cutoff mode: Reduce power
Cutoff threshold: Low
Startup mode: Normal
Timing: Low
Then I had to reverse the pitch gyro on the KK board.
Currently it is in + configuration (more or less because I don't know yet how to put it in X-config).
Motor 1 is front. Motor 2 is left. Motor 3 is right and motor 4 is back if seen from above.
jorgen is offline Find More Posts by jorgen
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
