Old Mar 29, 2011, 02:02 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
What if I don't have the cap anymore ??
rcimports is offline Find More Posts by rcimports
Old Mar 29, 2011, 04:24 PM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
I would send it back to Minsoo Kim asap.
Stacky is offline Find More Posts by Stacky
Old Mar 29, 2011, 04:25 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Here I am trying to figure out which CAP is missing (thinking capacitor). Ooops...finally saw the tree for the forest. The cover on the gyro is missing. I'll have to check mine. A little hot glue should hurt. I'm not sure what to say about a missing cover though.
Vantasstic is online now Find More Posts by Vantasstic
Old Mar 29, 2011, 04:55 PM
Jodde73 is offline
Find More Posts by Jodde73
Jodde73's Avatar
Stockholm
Joined Sep 2009
Today when I was going to fly my quad (also from Minsoo Kim) the pitch gyro is not responding. I've got 4,7v, but no response to
Any ideas?
Jodde73 is offline Find More Posts by Jodde73
Old Mar 29, 2011, 05:01 PM
Jodde73 is offline
Jodde73's Avatar
Stockholm
Joined Sep 2009
Fixed it, bad solder joints.
Hmm, don't know if I'm even going to trust it carrying my GoProHD cam.
Old Mar 29, 2011, 05:32 PM
BKMorpheus is offline
Find More Posts by BKMorpheus
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
Is it possible, that the KK Board don't like cold wind or something?
I flew 10minutes and after i changed my LiPo i was not able to activate the board (i fly a tricopter so i have to activate/unlock the board).
When i was back in the house, i was able to unlock it. Then i went out to fly another 10min and then locked the board. I tried to unlock it again and the LED stayed dark.
Back in my room it is working fine.
BKMorpheus is offline Find More Posts by BKMorpheus
Old Mar 29, 2011, 05:38 PM
Stacky is offline
Joined Jan 2011
I find that after a minute of flying if I havent let my quad sit in the ambient air before flying I have to land disarm it and then rearm it again to get it to stop drifitng in the air. It might be a similar thing for you. Try letting the quad sit on the ground for a few minutes before lifting off.
Old Mar 29, 2011, 06:44 PM
Jodde73 is offline
Jodde73's Avatar
Stockholm
Joined Sep 2009
Improvised body, out of lamp connection ceiling covers ($4)
Old Mar 29, 2011, 07:22 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Minsoo Kim View Post
http://www.youtube.com/watch?v=hT_nxNeeJK0
Frame Length: 190mm x 4
Motor: FlyCam 1400 x 4
Prop: APC 8x3.8 SF x 2, SFP x 2
ESC: Turnigy Flush 10A x 4
Weight: 400g (Without Batttery)
Recommended Battery: 3000mAh 20C 3Cells Li-Po
Total Weight: 640g (With Batttery)
This is very interesting.
The EPP aircraft landing skid is the role of the wing.
High speed is very stable in a rising or falling.
Minsoo
http://www.kkmulticopter.kr
That looks like fun. Will you be offering a 'kit' version? I've already got a KK board to use. I'd just be looking at the frame parts and possibly motors and escs.
Old Mar 29, 2011, 07:56 PM
rmorhan is offline
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
picked both quad & hex blue v 1.5 boards from minsoo. after initial setup on the quad with a jr 9303 spectrum ar 7000 & these escs http://www.hobbyking.com/hobbyking/s...idProduct=6458 .( are these escs compatible?) i can get the board to arm but speedos just rapidly beep. tried lowering subtrim & travel adj on throttle but no joy. the manual states to calibrate the escs but doesn,t say wheather it should be done manually or through the controller. i tried both ways & still get rapid beeping on board arming. any ideas? the fact the board arms seems to confirm good channel assignments. it,s actually the manual thats kinda vague on the esc throttle calibration. step 4 says to calibrate ecs throttle & bat type. next is to lower gain pot, power up with throttle full then idle which is effectively reprogramming the throttle calibration through the board this time. when my ecs are calibrated direct through th rx they see both full & idle but when done through the board the second time they don,t see idle for some reason..can the hex board be used with 2.4 spectrum rxs (thought i read somewhere it couldn,t ).any input appreciated...thanks..rob m
rmorhan is offline Find More Posts by rmorhan
Old Mar 29, 2011, 09:12 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Rob,
I'm not familiar with your ESCs, but if the throttle can be manually calibrated I think they should work. I have the KK hex board and use a Spektrum AR500 Rx and have had no issues...short of changing flight modes and I fixed that by increasing my control EPAs. I'm using RCTimer (Hobbywing) ESCs with no issue. By my recall I lowered the YAW gain to minimum, powered up my Tx and put the throttle to full. I then applied power to the KK board, waited and listened for the tones signaling my ESCs were in throttle cal mode. I then dropped my throttle to cutoff and then removed power to the KK board. Of course, do this with the throttle trim all the way down and props removed. When I power the KK back up the ESCs do their normal tones and wait for me to arm the controller then off flying.
Old Mar 29, 2011, 11:41 PM
juka is offline
Find More Posts by juka
Joined Jun 2009
I have the same problem with motors
When is cold outside 5 centigrate my turnigy plus 12A are
beeping only but in room temperature motors start normaly.
I have found solution Try during beeping manually turn propeler of every motor as fast as possible it usually helps me.
I think that cold motor bearings dont move freely /they are cold/
and motor is not able to turn easy and then motor can not produce impulses
for ESC during start procedure.
juka is offline Find More Posts by juka
Old Mar 29, 2011, 11:50 PM
Minsoo Kim is offline
Find More Posts by Minsoo Kim
Joined Apr 2008
Dear Sir
we are going to release the fun fly set without the controller board.
I think that it is the best combination.
Minsoo
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old Mar 29, 2011, 11:59 PM
Joined Apr 2008
Originally Posted by rcimports View Post
Minsoo, or anybody..
Got the KR Blueboard a while back and have been flying with it for a while.
However today I got some funny "glitches" and noticed that cap on the pitch gyro is gone No crashes or anything?
Is that fixible??
Cheers
Dion
Hi, I will post the video for the method of replacement
Minsoo
Old Mar 30, 2011, 12:28 AM
Joined Apr 2008
The hot glue is very useful.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
