Old May 01, 2010, 06:24 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by ben123 View Post
Can't wait to etch it! Here's a very blurry (crappy iPhone) picture of my efforts.
Looks great for toner transfer!
When I tried it, I was using an iron, and the track width was not consistent and depended on how hard I push my hands on. Abandon this method after I didn't want to invest in a laminator, and I got consistent result with UV method..
thanhTran is offline Find More Posts by thanhTran
Old May 01, 2010, 07:05 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
UV photo sensitive boards is the way I did it years ago. I had a laser printer that tracked pretty good and I could run the laser transparency through twice and lay a second image right on top of the first. This gave a very dark image that no light could shine through and ruin the exposure of the board. Had a nice bubbler etchant tank setup using ammonium persulphate.
pug398 is offline Find More Posts by pug398
Old May 01, 2010, 09:48 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Here is the new SMD Board.
It is 50x50mm and have 45mm hole distance.
Now I am going to bed
Edit: The roll and pitch gyros is to be glued with hot glue onto the PCB with the silver box facing down. The Yaw gyro can be mounted like intended, the silver box facing the edge of the PCB and the connections facing up. It also can be mounted with the connections facing down, but then the silver box should face the center of the PCB. Also it needs to be reversed. Make sure the wires it not to short and stiff, or else they may break. That is the reason I placed it with the connections facing up.
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 01, 2010, 09:49 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Verrry nice Rolf!
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old May 02, 2010, 01:47 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Hi, and first I want to thank you for sharing all your knowledge.
Never before I made PCB's myself, it always scared me to start with it. Now with all the info and links you all provided, I STARTED!
Yesterday I tested the toner transfer method, and yes, it is easy (still need some exercise)!
Next, being more mechanic than electronic skilled, i still have a problem on the purchase of the correct electronic components (size, type, etc). I am used to buy here : rscomponents
Is it possible for each board that is put on this list, to provide the list of the components (reference) that will fit it, compatible software, and a correct scaled pcb cicuit path as bitmap image or pdf file (centered)?
Thanks Again for all the hard work and especially sharing your skills.
ManuLRK
alll is offline Find More Posts by alll
Old May 02, 2010, 02:07 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Kaptein...
Very nice work with that SMD design.....are you going to make a production of those boards? Nice idea to use recycled components from silver "gyrds"...
Ive redesigned my board as well. But I made it 52 by 52 mm.....to get 2mm clearance from mounting holes to edge of board. Mounting holes are 45 mm apart.....
There is now both a singlesided and a 2-sided design with ISP. I will add the files to original post in a bit.
http://www.rcgroups.com/forums/showp...&postcount=657
I am still up for a limited production-run of these boards....but I personally think that Kapteins SMD-board makes more sense (lighter, smaller, cheaper components), and I would use that if it were to be produced.
Of course the SMD-soldering could be a problem for some - so perhaps there is still a need for a TH board.....let me know if you still want one.
JussiH is offline Find More Posts by JussiH
Old May 02, 2010, 02:49 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
420RcPilot,
Again, "chapeau".
I am still interested in that design, since it will be my first PCB, and bigger components will be easier to find...
Is it possible for this board to provide the list of the components (reference) that will fit it, compatible firmware, and a correct scaled pcb circuit path as bitmap image or pdf file (centered, to be able to directly sent it to the printer)?
ManuLRK
Old May 02, 2010, 03:06 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Manu. Ill put my list up tomorrow.....but generally look for components with 2,54 mm pin distance. The design is made around that grid! Trimmers are 6mm with 2.54/5.08 mm footprint
However I found that some of the components are hard to come by in TH-type. Dont count on RS having the 28-pin Atmega48/88/168 in stock in europe - backorder everywhere. Supplies are not due until july. Same story with Farnell. I havent checked Reichelt in Germany, cuz they have a 150 euro order minimum for international custumers. Futurlec.com stock the Atmegas, but havent got 0.68 uF tantalum caps - this is why I designed C5, C6 and C8 to take both 2.54 mm and 5.08 mm pin caps (so U can use larger polyester caps instead).
Kaptein - you changed some Capacitor values in your new SMD-design. I am guessing that those values also works for TH design?
Jussi
Old May 02, 2010, 03:40 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Pcb
Hi,
This is the best I can get with the paper transfer method.
I will prepare my etching shaker tomorrow.
ManuLRK
Old May 02, 2010, 03:55 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by alll View Post
Hi,
ManuLRK
Looks like u are pressing to hard or heat is too high - my iron gets very hot on high, so I dont crank it all the way up. If U are using the magazine paper, you dont have to press that hard.
You can also try and print with less toner - as too much will have a tendency to smear.... Wipe the toner off with acetone or paint thinner and give it another go.
Remember also to prepare the board properly - sand down the high edges from cutting board and also sand copper surface with very fine grit wetsanding paper (500-1000 grit). Some also pre-etch the raw board (dip it briefly in the etchant) to make the toner stick better to the copper. Clean again with acetone or paint thinner right before transfering...
Old May 02, 2010, 04:08 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Preparing my components order
For C5,C6,C8: 0.68 uF tantalum, can I use 1F instead
rs-components do not have the 0.68!
Can I use this ATmega48PA-88PA-168PA-328P.pdf?
Here is what I have up to now:
the 100F tantalums are quite expensive!
Old May 02, 2010, 04:38 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
The 100 uF is a aluminuml electrolyte in Kapteins design - much cheaper than tantals. Like this from RS (Number 193-6720):
http://dk.rs-online.com/web/search/s...duct&R=1936720
0.68 uF: try searching for 680 nF instead. Some stores list them that way. RS here in DK has 680 nF 35V tantalums - item number 537-4413.
http://dk.rs-online.com/web/search/s...duct&R=5374413
They also stock polyester film caps in 0.68 uF (680 nF)
I believe that the Kaptein said earlier that only C9 absolutely has to be a Tantalum!
IC looks good - be sure to get a 28-pin - RS listings can be hard to decipher...
Quad Whisperer
Joined Jul 2008
ManuLRK
Thanks, I will see if I can make a list.
Old May 02, 2010, 04:56 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by Scorpia View Post
I have been watching this thread with some interest for a while now.
A service i have heard good things about is this one.
http://www.seeedstudio.com/depot/ope...e-c-64_12.html
The wiki for info is here.
http://www.seeedstudio.com/wiki/inde...=Opensourcepcb
Nice place to get a small run for testing and then i think they are able to make a bigger run as well. either they can sell though there site or send to the orderer,
Also they do discounts for open source designs, i think this should qualify.
Keep up the good work , this looks like it is a great project that is getting better.
If you are going to design a board i would suggest adding small via's for any unused i/o left on the micro as then it could be used later for future idea's.
a couple of idea's i had for using some of the extra i/o left on the chip are.
1. possibly include a low voltage cutout onboard. with some sort of output to a buzzer/led etc.
or
2. use the extra inputs to add an acceleromitor etc.
Either way great work keep it up, Hopefully in a month or so i will be making my own. If boards get produced i will be looking to buy some of them
Seedstudio looks like a way to go. Im in
I use these for low voltage warning: http://www.hobbycity.com/hobbycity/s...idProduct=7223
There will be no more features added to this design. I does as intended, fly a quad/tri. (hexa, Y6 and that avatar thingy to be added) Maybe later with a new design with a more powerfull microcontroller chip.
Old May 02, 2010, 04:58 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by nitc View Post
can i use the atmega88 taken out from hk401B old version (mystery gyrd) in the quadrotor v4
Yep
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
