Old Nov 08, 2010, 11:20 AM
frank48 is offline
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Originally Posted by noppita View Post
i just test my second board of wmp from dealextreme.com and i set pot and stick to 13 and reduce end point of throttle to 80% and found result to be not good like my first wmp. the copter move back and forward like swing either left and right or forward and back. I am using jakub kk board and i think the jakub board use different C and R from other kk board. If c and R is different, the wmp result can be different right? I will check each component on jakub and compare with other kk board standard.
all, rc420pilot, tranthran -------> which kk board are you using and what is the component list? they are different from jakub component right?
any comment
You need to change R10 to 220 ohms
Frank
frank48 is offline Find More Posts by frank48
Old Nov 08, 2010, 01:12 PM
CONCEP60 is offline
Find More Posts by CONCEP60
LŽAmposti
CONCEP60's Avatar
Amposta (Spain)
Joined Feb 2006
Hi
Are there any special software to stop the tri wm +? or just to change and adjust R10 left?
thanks
Pd: tomorrow recibes wm+ to DX
CONCEP60 is offline Find More Posts by CONCEP60
Old Nov 08, 2010, 02:19 PM
Rivelino is online now
Find More Posts by Rivelino
Romania, Municipiul București, București
Joined May 2009
Atmega 48 or 88 PA-PU not working
Hi Niall,
Can you make the software to work with ATMEGA48 Pa-PU ? also with ATMEGA88 PA-PU ?
I have 1 pcs of each , and i not working . I tried also with clocktest.
Nothing.
Fuse Bits is set like 48 20-PU.
Can you help me?
In my country i can find PA-PU series but, 20 PU is very rare.
Thanks.
PS: I send you a email about a month ago , and you tell me is working.
Regards again.
Rivelino is online now Find More Posts by Rivelino
Old Nov 08, 2010, 02:35 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by Rivelino View Post
Hi Niall,
Nothing.
Can you help me?
Thanks.
Regards again.
I am able to program the Atmega48PA and Atmega88PA without any problem. They are both 28 pin chips and I use AVRStudio4 and an AVRISP Mk2 to program the chips.
Where are you facing troubles? What error do you get?
Niall is offline Find More Posts by Niall
Old Nov 08, 2010, 03:08 PM
Edje11 is offline
Find More Posts by Edje11
Edje11's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by alll View Post
Me too, I "lost" the settings (EEPROM??) between switching batteries!
This is scary...
I heard other people had similar problems...
manuLRK
That's is possible if the fuse bit for the BOD (brown out detection) is not set in your ATMEGA.
Edje11 is offline Find More Posts by Edje11
Old Nov 08, 2010, 03:09 PM
IWCoburg is online now
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Originally Posted by Minsoo Kim View Post
Micro KKMultiCopter Indoor Flying
2010.11.08
Minsoo Kim
http://www.kkmulticopter.kr
Nice flying Minsoo. Just wondering if your thinking about a v2 board with the larger chip on it that could use the XXcodebase which is looking good but really wants a larger chip? It would also benifit with support for the Wii setup I think.
Mike.
IWCoburg is online now Find More Posts by IWCoburg
Old Nov 08, 2010, 04:00 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Mike.
I am very sure there will soon be an alternative to the Korean Board that will include a 168....stay tuned!
JussiH is offline Find More Posts by JussiH
Old Nov 08, 2010, 04:22 PM
Joined May 2009
I program it with AVR Burn O Mat with -F on comand line. Nothing is happened.
I reset it to defaults (I made a Fuse Bits Doctor).
I will try
Old Nov 08, 2010, 04:36 PM
Niall is offline
Joined May 2010
I will try
Hi Rivelino,
I have not tried that programme, but I can say that it does work with AVR Studio 4. If you have a programmer that supports that, I would suggest using it. There are comprehensive programming instructions on this link...
http://www.kkmulticopter.com/index.p...h-avr-studio-4
Cheers,
Niall
Old Nov 08, 2010, 05:04 PM
(Jo)Hannes is online now
Find More Posts by (Jo)Hannes
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
if you are willing to try, look at U5, it is a regulator. there are 3 pad on one side and 2 pad on the other side. If you put a jumper wire from the 3 pad side at first pad to the third pad and now on the 2 pad side, you will read 3 v, then look for your signal connection for roll , yaw and pitch again, now it should work. but i do not sure, you will have to try at your risk.
Hey Thanks, that seems to work!
soldered the "jumper" and found these pins corresponding to the 3 axis:
(Jo)Hannes is online now Find More Posts by (Jo)Hannes
Old Nov 08, 2010, 05:25 PM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
i did changed r10 to 220 ohm
Frank
noppita is offline Find More Posts by noppita
Old Nov 08, 2010, 05:29 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
I am looking at your pictures and look different than i describe. On left hand side of the regulator, you connect the top pad to the bottom pad and leaving middle pad untouch right? and right hand side of the regulator is un touch right?
Old Nov 08, 2010, 05:50 PM
Joined May 2009
Originally Posted by Niall View Post
Hi Rivelino,
Cheers,
Niall
Thanks a lot.
Now i must make a serial programmer.(already have one on paralel)
Old Nov 08, 2010, 08:32 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
Is there a way to give more range for the gyro pots? I cannot get the airframe to wag/oscillate even with max settings on the pots. I know this is a side effect of making the copters too big, but I like 'em big.
DarkHeli is offline Find More Posts by DarkHeli
Old Nov 08, 2010, 10:29 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
you can change your potscale to lower number in the hex file? have to you try to revise the hex file?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
