Old Apr 26, 2010, 06:27 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by jjbunn View Post
kapteinkuk,
When you wrote the software for your tri and quadcopters, what did you base the algorithms on? Can you recommend a text that describes the operational principles? Clearly your flight software algorithms are excellent, and I would like to reproduce them on an Arduino based controller (yes, I'm aware of the Arduino based AeroQuad design, but I'd like to start from scratch).
Many thanks!
Julian
They where based on my knowledge on how they works.
some pseoudo code:
Stick input and gyro input are centered around zero, exept collective wich start at zero.
quad:
start of mixing
FrontMotor = collective
LeftMotor = collective
RightMotor = collective
BackMotor = collective
RollCommand = RollStick + RollGyro
(Simple dampening, it is in effect only the D part of a PID. The gyro output is a deriative of absolute rotation angle)
LeftMotor = LeftMotor + RollCommand
RightMotor = RightMotor - RollCommand
PitchCommand = PitchStick + PitchGyro
FrontMotor = FrontMotor + PitchCommand
BackMotor = BackMotor - PitchCommand
YawCommand = YawStick + YawGyro
FrontMotor = FrontMotor + YawCommand
BackMotor = BackMotor + YawCommand
LeftMotor = LeftMotor - YawCommand
RightMotor = RightMotor - YawCommand
End of mixing.
Tri:
start of mixing
RollCommand = (RollStick + RollGyro) * SIN(60)
PitchCommand = PitchCommand * COS(60)
LeftMotor = LeftMotor + PitchCommand
RightMotor = RightMotor + PitchCommand
TailServo = YawStick + YawGyro
End of mixing.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Apr 26, 2010, 06:33 PM
Quad Whisperer
Joined Jul 2008
New quad software
Here is Quadcontroller V4.1
-Added gyro reversing.
-180Hz PWM frequency.
-Same hardware. (V4)
-All gyros can be reversed.
Gyro direction reversing:
1: Set roll gain pot to zero.
2: Turn on flight controller.
3: LED flashes rapidly 10 times.
4: Move the stick for the gyro you want to reverse.
5: LED will blink continually.
6: Turn off flight controller.
7: If there is more gyros to be reversed, goto step 2, else set roll gain pot back.
Gyro reversing is useful if you want to mount the gyro in a way that reverses its output, eg. mounting the yaw gyro upside down, or when using other gyros with reverse output.
Old Apr 26, 2010, 09:08 PM
doorhead is offline
Find More Posts by doorhead
Lazy RCer
Seoul, S.KOREA
Joined Oct 2009
thank you for your detailed answer
I mean "T style" like this.
from Vicacopter.
But your control loop based on 120 degrees. can applicapable T style for your binary hex file?
I'm very awaiting your hands-off stabilize video
doorhead is offline Find More Posts by doorhead
Old Apr 27, 2010, 12:35 AM
jjbunn is offline
Find More Posts by jjbunn
Joined Apr 2010
some pseoudo code:
(snip)
End of mixing.
Superb ... thanks so much!
jjbunn is offline Find More Posts by jjbunn
Old Apr 27, 2010, 01:21 AM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
VTOL RC AVATAR SCORPION Prototype model
VTOL RC AVATAR SCORPION Prototype model (2 min 36 sec)
please watch the above line .. amazing stable with 2 motors and 2 sevos ..
i think this would be very easy for master kapteinkuk.. may be he can pipe line this project too..
quaddynamics is offline Find More Posts by quaddynamics
Old Apr 27, 2010, 04:00 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
now missing is a BMA180
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Apr 27, 2010, 08:41 AM
ben123 is offline
Find More Posts by ben123
NW England
Joined Jul 2005
Hello!
I've been learning Eagle and have drawn a schemetic for a small (38x31mm), single-cell, double layer, ISP pinned V4 board (modified from Thanh's work).
I've also laid out the board and connected everything (mainly for practice as it'll probably have to be all rerouted with the corrections). However please could someone check the connections, schematics, practicality of it before I go any further (buy the components, etch the board).
I've put replaced the large pots with the following ones for which I had to draw a component in Eagle :
http://uk.rs-online.com/web/search/s...duct&R=177-223
I got quite confused about the connections so if someone could check it that would be awesome.
The 5v step schematic I have lifted from here :
http://www.sparkfun.com/commerce/pro...oducts_id=8999
As the power is derived from the single cell battery I've assumed the only connections needed to the motors from the controller board is the signal wire? Also the power for the rx comes straight from out of the step-up circuit, before the filter. Is this correct?
I've put the gyros on the back of the board as this seems to be how kapteinkuk and Thran had mounted their HK401 boards. I haven't designed the z-axis gyro board yet but it should be small with only the gyro and a cap on it.
The board is really untidy (names and values everywhere) as I haven't learnt how to resize and place them properly, but I just need things checking before I go any further.
There are 12 vias I'll have to drill and pin by hand but thats part of the fun I guess
Please be gentle
ben123 is offline Find More Posts by ben123
Old Apr 27, 2010, 08:47 AM
outsider787 is offline
Find More Posts by outsider787
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
Nice work Ben!
Look forward to hearing how your prototype works out.
outsider787 is offline Find More Posts by outsider787
Old Apr 27, 2010, 09:33 AM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
For anyone who was interested in the whole gyro resonant frequency thing, the ST 5xx series is 4.1khz.
pug398 is offline Find More Posts by pug398
Old Apr 27, 2010, 09:59 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
I am a complete noob when it comes to this stuff but would like to build one of these awesome boards for my tricopter - Is there a step by step to building one that I have overlooked in this thread somewhere? Anyone going to sell them at one point?
Thanks guys!
cdi3d is offline Find More Posts by cdi3d
Old Apr 27, 2010, 11:19 AM
dd016857 is offline
Find More Posts by dd016857
barkingside
Joined Mar 2008
from Vicacopter.
Physically this is a T style but still a Y in practice . X will be same as H
dd016857 is offline Find More Posts by dd016857
Old Apr 27, 2010, 12:54 PM
jjbunn is offline
Joined Apr 2010
Could somebody clarify what types of propellers are suitable for this design - do two of them need to be pushers, or can they all be standard? I think I may be missing something fundamental here, but am confused why the AeroQuad needs two pushers and two pullers and yet Kaptain's design apparently does not?
Thanks!
Old Apr 27, 2010, 02:09 PM
frank48 is offline
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Thanks!
Hi
The original design needs 2 cw rotating props and 2 ccw, however on his latest mini quad the front and rear motors are tilted to the right. All props are the same and rotate in the same direction.
Cheers
Frank
frank48 is offline Find More Posts by frank48
Old Apr 27, 2010, 02:18 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by cdi3d View Post
...Anyone going to sell them at one point?
Thanks guys!
I've thought about offering complete built boards. It's going to be sometime before things can be sorted out. Cost, license, part choice, testing my board design, etc.
Kaptein is so nice that he gives the code and design away for free and doesn't mind if someone offers a kit. Some kind of comission should go his way if I do sell the board.
thanhTran is offline Find More Posts by thanhTran
Old Apr 27, 2010, 07:02 PM
jjbunn is offline
Joined Apr 2010
Originally Posted by frank48 View Post
Hi
Cheers
Frank
Thanks, Frank - on the original design, are the CCW props pusher types or not?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
