Old Feb 19, 2010, 12:51 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by kamakazikev24 View Post
Great Job!
I like many others would love to build one of these.
However like many others I would'nt know where to start, esp using my laptop to install your software afterwards.
If you sold a kit with full instructions I would be more than happy to trial it and of course pay you.
I can solder and have some electronic knowledge, but mostly as a signal faultfinder on the railways in the UK.
Oh and I can reflash my Blackberry but not sure if that counts! Lol.
George.
There will be no kits from me, This one is aimed at the scratch builder / mad scientist / pain lover (assembly language ). However, the internet is nearly overflowing of info to program these microcontrollers.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Feb 19, 2010, 12:56 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by pug398 View Post
kapteinkuk it looks like if I wanted to build the circuit I might have trouble locating an 8 mhz atmega48. Could a 20 mhz be substituted or would I need an external 8 mhz clock?
A second look yielded some 10 mhz as well but I am still curious about the timing.
Well a third look at the pic shows the 20PI to be a 20mhz version so I guess the 8 mhz is derived from dividing the internal osc down. Forgive me the 2313 was the last avr I worked with.
You can use any Atmega48. The clock of 8MHz is set with the fuses.
Old Feb 19, 2010, 02:15 PM
KayCee_V4 is offline
Find More Posts by KayCee_V4
Bricks don't glide !
KayCee_V4's Avatar
South Africa, GP, Vanderbijlpark
Joined Mar 2008
Will a Atmega8 work as well ?
KayCee_V4 is offline Find More Posts by KayCee_V4
Old Feb 19, 2010, 03:35 PM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Do you mean for using Arduino hardware?
Yes,
I use AERODUINO - http://www.rcgroups.com/forums/showt...5#post13793425
Application with WiiMotionPlus use
or new PCB than KUKDUINO
WiiMotionPlus anlog about 1mV/ °/s
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Feb 21, 2010, 05:13 AM
cqrp is offline
Find More Posts by cqrp
Joined Feb 2010
Some questions . .
Hi kapteinkuk
Newbee here!
Some questions:
Which of the Turnigy 2215 motors are you using?
This:
http://www.hobbycity.com/hobbycity/s...idProduct=2105
or this:
http://www.hobbycity.com/hobbycity/s...idProduct=9021
What is the power source of the quad? The schematic just refers it to as Vcc.
How is the +5V derived for the system?
What is the flytime with the batteries that you used?
What is the weight of the quad (all loaded)?
Any benefit to be accrued by using the uC clocked at 16MHz?
Once again a fantastic video & a cool quad that you've made!
cqrp is offline Find More Posts by cqrp
Old Feb 21, 2010, 02:02 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Very nice Jürgen. Thanks!
Cheers,
Jim
Originally Posted by JUERGEN_ View Post
My new project KUKDUINO
as a basis for WiiMotionPlus
jürgen
jesolins is offline Find More Posts by jesolins
Old Feb 22, 2010, 03:04 AM
kamakazikev24 is offline
Find More Posts by kamakazikev24
Joined Nov 2006
That's a shame! Your home made quad is one of the most stable I have seen, and most videos only ever show shaky hovering
Can you post up a good link where I can find some useful info?
Thanks. George.
kamakazikev24 is offline Find More Posts by kamakazikev24
Old Feb 22, 2010, 04:44 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Just wondering about and saw this....cracking work.
With my limited knowledge think i could do this! Happy days
Anyone interested in this.Flashing MCU can be done quite cheaply...if you have an LPT port on you compter your laughing CHEAP programmer! PonyProg
I'm hopeing atmega 88 good with this too ?
BTW more a solder jocky but can butcher code
SadSack is offline Find More Posts by SadSack
Old Feb 22, 2010, 08:23 AM
pabmadi is offline
Find More Posts by pabmadi
pabmadi's Avatar
Joined Feb 2009
Here is the new controller V2.
-Added 3 potmeters for gain adjusting.
-Lowered the ADC reference to ca. 1.5V for higher resolution.
-Fixed a bug in the float to 16.16 signed binary converter (Assembler functions used during assebly). The bug appeared when using negative gain for gyro reversion. Also tidied up the format to write floats in the source code.
-Uses the complete gyro sub assembly from the HK401B gyro, with capacitors.
Video will follow shortly.
GREAT; amaizing!! Do you use Helicopter Transmitter with CCPM mixing? Any 72mhz receiver will work?
This thread could easy turn into a hot one !!!
pabmadi is offline Find More Posts by pabmadi
Old Feb 22, 2010, 08:50 AM
Quad Whisperer
Joined Jul 2008
Yes, but not with the new V3 software.
Old Feb 22, 2010, 08:55 AM
Quad Whisperer
Joined Jul 2008
jürgen
What is the price of the WiiMotionPlus?
Old Feb 22, 2010, 08:59 AM
SadSack is offline
Joined Aug 2008
pity that being that there will be 3 8's going from gyros.
Old Feb 22, 2010, 09:01 AM
frank48 is offline
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Hi Kapteinkuk,
The Wii Motion Plus is £14.91 from amazon.co.uk
http://www.amazon.co.uk/Wii-Motion-P...6850678&sr=8-1
What is channel 5 used for in the schematic?
Thanks for a great project
Frank
frank48 is offline Find More Posts by frank48
Old Feb 22, 2010, 09:12 AM
Quad Whisperer
Joined Jul 2008
>Hi kapteinkuk
>Newbee here!
>Some questions:
>This:
>or this:
None of them, It is this one: http://www.hobbycity.com/hobbycity/s...idProduct=5686
I have previosly written that it is the 2215 motor, wich is wrong.
The power to the controller comes from the BEC of the ESCs
3S1800 gives about 10 min
1015g
Not with current software
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
