Old Sep 22, 2010, 04:28 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by thanhTran View Post
Are you mentioning the video I posted earlier?
The video (that has wobble mentioned) I posted earlier was with my tricopter running KK board with 2 ST gyros. See the video tittle?
My quad with my own code is not showing any where yet. Still need my camera woman .
I'm just using decimation and over sampling, no other filtering done. I'm writing my own code, not porting or based of any one. It only relies on rate dampen like what Rolf does though. I.e. no PID control. Since you mention filtering, I will probably do some moving average to see if it improves any thing. What kind of filtering does the UAVX do?
Thanks Mike
-Thanh
Hi Thanh
Yes, thats the one.
Was just curious as to what code you were using.
The UAVX filtering (choose which works best) is as follows (requires saving the previous gyro outputs):
Code:
// Simple filters using weighted averaging
#define VerySoftFilterU(O,N)	(((O)+(N)*3+2)>>2)
#define SoftFilterU(O,N) 		(((O)+(N)+1)>>1)
#define MediumFilterU(O,N) 		(((O)*3+(N)+2)>>2)
#define HardFilterU(O,N) 		(((O)*7+(N)+4)>>3)
#define NoFilter(O,N)			(N)
So when you get new GyroOutput:
Code:
GyroOutput = HardFilterU(PrevGyroOutput,GyroOutput)
PrevGyroOutput = GyroOutput
Its's quite straightforward to implement and tweak in c.
I havn't tried this so can't comment on its effectiveness.....
Mike Barton is offline Find More Posts by Mike Barton
Old Sep 22, 2010, 04:45 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by Mike Barton View Post
Hi Thanh
Yes, thats the one.
Code:
Code:
Thanks Mike
Yeah, that tricopter uses KK controller. I don't have tricopter code yet. Thanks for the filter info. They do look too easy to try I was thinking about a moving average of 8 or 16 samples (which is pretty effective to read the current reading when I was implement a up convert switching A123 battery charger charging up to 42v at around 4A CCCV method). Hopefully the filter helps
thanhTran is offline Find More Posts by thanhTran
Old Sep 22, 2010, 05:03 AM
United Kingdom
Joined Nov 2008
Thanks Mike
The cute thing about this code is that it can weight the new value from previous multiple sample results without having to hold lots of previous samples.
So less storage and processing required.
One other option is Kalman filter, but I suspect the processing required would mean the copter would never take off....
Old Sep 22, 2010, 07:30 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by alll View Post
For the Yaw contest I am still the best , but I don't think I will get close to your flying skills
manuLRK
KK Quad Fast Yaw (0 min 54 sec)
did u watch it till the end? i will compare the videos frame by frame this evening to get a spin/s value...
warthox is offline Find More Posts by warthox
Old Sep 22, 2010, 07:50 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Yar rate contest
Ok, original was taken at 30fps, I need 7.5 frames to do 360, i think.
This makes it 4 rps = 240 rpm
manuLRK
alll is offline Find More Posts by alll
Old Sep 22, 2010, 08:33 AM
Crissbrasil is offline
Find More Posts by Crissbrasil
BRAZIL
Joined Jul 2010
My tricopter is crazy see the video the motor left start first and run more...
http://www.vimeo.com/15180508
I have make all the cheks on the cheklist descript in the kk site...
the tricopter will not fly cool
Crissbrasil is offline Find More Posts by Crissbrasil
Old Sep 22, 2010, 08:41 AM
warthox is offline
Joined Aug 2009
trim it... its normal
Old Sep 22, 2010, 08:44 AM
BRAZIL
Joined Jul 2010
warthox,thanks for help me,i see all your fantastic videos....
the trim going to end,and need more.
Old Sep 22, 2010, 08:52 AM
marba is offline
Find More Posts by marba
Joined Sep 2010
Hi, I have exactly the same problem with mine. And I have also tried trimming it, changing props, everything it says on the kk site. The problem is that the only description of how to trim a multicopter on the kk site is about a quadcopter, not a tricopter...
Would be great if anyone could share how to do the trimming.
...soooo close and yet so far!
marba is offline Find More Posts by marba
Old Sep 22, 2010, 09:00 AM
BRAZIL
Joined Jul 2010
I agree, we need help, please if possible put in a cheklist on kk site, specific for tricopter`s. I look forward to being able to fly but in no way ... as spoken by marba .... so close but so far.
Old Sep 22, 2010, 09:10 AM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Just Ordered a board
I'm perhaps the newest member to the KK quad community.
Can't wait to get started!
nicnaimless is offline Find More Posts by nicnaimless
Old Sep 22, 2010, 09:11 AM
Helichem is offline
Find More Posts by Helichem
France (Dijon - Burgundy)
Joined Dec 2009
Tricopter Motors and Tail servo wiring
Hi there,
After 2 quads, I'd like to make a Tricopter but I can't find again the post for the motors and tail servo wiring!!!!
Is someone be able to help me?
Helichem is offline Find More Posts by Helichem
Old Sep 22, 2010, 09:14 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by Helichem View Post
Hi there,
http://www.kkmulticopter.com/index.p...-a-kktricopter
Niall is offline Find More Posts by Niall
Old Sep 22, 2010, 09:20 AM
Helichem is offline
Joined Dec 2009
Thanks Niall.
I found it just before your reply, there:
http://www.rcgroups.com/forums/showp...&postcount=958
Old Sep 22, 2010, 09:41 AM
warthox is offline
Joined Aug 2009
reverse your channel for roll and try it again ;-)
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 12:15 PM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 04:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 08:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 03:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 11:07 AM
