Old Sep 08, 2010, 07:26 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Good question... these are the one I'm using:
http://www.hobbycity.com/hobbycity/s...idProduct=6460
saucisse is offline Find More Posts by saucisse
Old Sep 08, 2010, 07:34 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
You might have to set the throttle range on those individually. This is the ESC that others have had success with...
http://www.hobbycity.com/hobbycity/s...d_programmable)
The way I set mine was the plug them into the throttle channel of the RX and set them up by stick, one by one. I never got the desired effect however and in the end went with Turnigy Plush. You might have better luck though as mine were a different non card programmable cheap Chinese ESC.
Niall is offline Find More Posts by Niall
Old Sep 08, 2010, 07:39 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
The weird thing is when I set the yaw pot to zero and then turn the kk controler on, I can give some throttle and all 4 motors starts at the same time...but there is no effect witht the aileron/rudder/elevator stick...
Old Sep 08, 2010, 07:44 PM
Niall is offline
Joined May 2010
Weird. What firmware version are you on?
Old Sep 08, 2010, 07:45 PM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
i have a lot of bad experience with hobbyking ss esc. I am almost 100% sure that this esc does not have min and mas setting. When set power to full and connect battery, you will hear that first beep which is program mode ( not min and max setting) no space or time for min and max setting. Someone who have a lot of experience about this hobbyking ss esc, please help me answer this.
there are two version of hobbyking ss esc
1. hobbyking SS esc
2. hobbyking SS esc (card programable)
i think the diff between the two type is one can not program by card and another can program by card.
but both of them can be program with same result using TX right?
if both of them can be program with same result using TX, then both of them can not set min and max.
noppita is offline Find More Posts by noppita
Old Sep 08, 2010, 07:46 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
only program for this hobbyking ss ESC is lipo battery type, NiMH battery, brake on or off.
Old Sep 08, 2010, 07:47 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
this is the one without word (card programable) and i think it mean that you can not use card to program it, you will have to do it manually by TX radio with sound beep
Old Sep 08, 2010, 07:50 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
Are you sure that you are talking about hobbyking ss esc (without word "card programble) because when i connect battery, the first beep and following beep is for program mode such as lipo, Nimh, and brake off. No space or time for min and max setting. I have both 18 A and 25A.
Old Sep 08, 2010, 07:51 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Good question ?? Jakub sold me the kk board with all the parts to complete it along with the Atmega chip already programmed with latest version. Just received it last Friday.
Old Sep 08, 2010, 07:54 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
the above esc are two diff. version (without card programable) and (card programable)
I have tried (without card programable) and i am sure that this esc can not be set to min and max throttle setting. but i never try (card programable) one, but i think they are the same.
someone who know about this esc, please answer
Old Sep 08, 2010, 07:55 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
believe me, nothing wrong with your kk board, it is very sure that the problem is your hobbyking SS esc. I have problem with them so i changed to towerpro.
Old Sep 08, 2010, 08:00 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
noppita, I'll try different ESC's but the problem is all the ones I wanted are not in stock. It is so frustrating not being able to get the parts I want and more over not being able to fly the quad
Which towerpro do you use?
Old Sep 08, 2010, 08:06 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
saucisse - i run these - http://cgi.ebay.com/New-RC-Hobbies-E...ht_3017wt_1137 they work w/ the turnigy programming card and my motors start at the same time. i would recommend also ordering a turnigy programming card as that makes programming a mere 15sec/esc experience http://www.hobbyking.com/hobbyking/s...idProduct=2169 (sadly out of stock)
i have read that the turnigy plush are the same as rctimer programmable, hobbywing pentium, but i can verify 100% that the ones i have linked to do in fact work w/ the programming card and work correctly in setting up the throttle max/min setup. hope this helps
bob
bob4432 is offline Find More Posts by bob4432
Old Sep 08, 2010, 08:10 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Thanks bob4432 for the link. I already have the Turnigy programming card. What sucks is that if I order the ones you have it will take 2 weeks to get to my placec
Old Sep 08, 2010, 08:18 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
bob
turnigy programming card will work with hobbyking ss esc (card programable), but he does not have this type, he has (without card programable) and the turnigy programming card does not allow to set min and max, it only has those thing , lipo, nimh, brake off, time mode, soft start. the problem is min and max setting
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
