Old Sep 06, 2010, 07:08 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Here is new software for TriCopter.
I have added a low pass filter on the output to remove the vibration induced servo jitter.
Code:
	b16sub RxInYaw, LowpassOutYaw	;Low pass filter the Yaw control output
	b16load RxInYaw
	ldi t,3
	rcall FastDivide
	b16store RxInYaw
	b16add LowpassOutYaw, RxInYaw
Also I have doubled the arming/disarming time to make accidental arming/disarming less likely to happen.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Sep 06, 2010, 07:50 AM
321 is offline
321
Find More Posts by 321
321
mixed styles flight
central Florida USA
Joined Dec 2002
Code:
	b16load RxInYaw
	ldi t,3
	rcall FastDivide
	b16store RxInYaw
Thanks! The low-pass filter should help a lot. I think servo jitter may have been causing the controller to battle it out with the weight shifting of the motor and gyroscopic force as well.
321 is offline Find More Posts by 321
Old Sep 06, 2010, 08:28 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Emax CF2822 motor ??
For those using the Emax CF2822 motor, do you leave the shaft like it is stock to install the prop adapters or it is better to have it going out at the bottom so the prop adapter sits flush on the bell ?
saucisse is offline Find More Posts by saucisse
Old Sep 06, 2010, 08:40 AM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
I did it like this Used a cheap prop saver from hobbyking and swap the o-ring with a rubberband.
Quad tweaks (0 min 44 sec)
culexus is offline Find More Posts by culexus
Old Sep 06, 2010, 09:28 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
And rubber bands are holding good ? I guess you gotta checks these buggers once in a while...
Old Sep 06, 2010, 10:04 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi,
I do cut the shafts down when using those prop adapters using a Dremel so they are almost touching the bell when fully inserted on the shaft. Those shafts are also easy to tap for threads. Then just use locknuts and lock washers and then a bit of Lock tite for the best relability. When using the prop saver method on lightweight fun flyers, some Gents cleverly cut silicone tubing to use in place of the O-rings which as you know commonly fail with age.
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Sep 06, 2010, 10:48 AM
ApachePilot is offline
Find More Posts by ApachePilot
Father Francis, formerly Apach
Joined Oct 2006
I just purchased a board a few days ago from here:
http://www.kkmulticopter.com/index.p...=annonce&id=19
I have a thought on mounting it on my Matrix V2 folding TRI.
I believe it will work wonderfully, but have a question....
What is the common concensus?Which is perferred by most, SMD types or TH?
Anything I should be on the lookout for and should know prior to mounting/hookup?
ApachePilot
ApachePilot is offline Find More Posts by ApachePilot
Old Sep 06, 2010, 11:14 AM
IWCoburg is online now
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
ApachePilot
As my eyesight is not up to really small stuff, I opted for the assembled (less gyro) SMD boards as they are nice and compact.
As I am running my boards from a Spectrum reciever I simplified the cabling so I use the Trottle chanel to feed signal and power, but only feed signal on the elevator, aileron and rudder chanels, so you have inreality only 2 cables to connect. This also works direclty if you add the FY20A as well, just a plug in and go job.
Mike.
IWCoburg is online now Find More Posts by IWCoburg
Old Sep 06, 2010, 12:07 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Originally Posted by Xnaron View Post
Here is a version that I included the swapped board and schematic files (_swap) ... I haven't tested yet obviously
I routed it...man those traces are small...I didn't have small enough drill bits and ended up losing some pads. I also made a mistake cutting the board out on the X. The board is offset +0.025 on the X and -0.025 on the Y on the bottom. I compensated the wrong way. Here is a pic...I could use this board but I think I'll make another when I get the right drill bit size.
edit: there are a couple of questionable traces as well... I might work on a 2 sided version of the board. The main problem I had is the via's under components. I might spend some time and try and modify the other through hole version...
Xnaron is offline Find More Posts by Xnaron
Old Sep 06, 2010, 12:27 PM
Fulg is offline
Find More Posts by Fulg
Fulg's Avatar
Montreal, Canada
Joined Sep 2008
You might want to try replacing your bullet connectors too...I had this problem with multiple HK bullet connectors. The male side of the connector is 2 pieces and sometimes there is no continuity. I have two on my bench with this problem...unbelievable I know...I thought it was a bad motor but it was the connectors...just one more thing to try. Use a continuity meter to test.
Funny you should mention that, my Quad flight session this morning was canceled because of that exact problem (thankfully I had brought some helis). One of the motors seemed to be running a bit slower than the others for the past few days and it's been hard to calibrate the quad correctly; this morning that motor wouldn't even start. Just wiggling the bullet connector resolved the issue, so it's clear one of my motor connections is not working (either the bullet connector or my soldering).
I'm just thankful this didn't occur in flight, a friend and I spent all morning yesterday flying the quad (too windy for planes and helis)... I was blaming the wind for the calibration difficulties but it seems I have found the root cause
Cheers,
Ben.
Fulg is offline Find More Posts by Fulg
Old Sep 06, 2010, 12:53 PM
skye is offline
Find More Posts by skye
Joined Jul 2010
Originally Posted by thanhTran View Post
So you just measure the current by sticking the probes to the ESC wires directly? That could blow the fuse inside the meter or worse it could damage the ESC.
I guess some FET's has died. You can try finding which FET has died by comparing it with others and maybe you can fix it, maybe like this: http://www.rcgroups.com/forums/showp...6&postcount=15 (I don't think they have same design, but you can find the replacement FETs.)
They turned out OK. ESC came back after I cleaned out the solder and resolder the cap and power cable.
Now further problem, I'm running v4.4 on Niall's V6TH board and when powered on the LED is off. I moved left stick to lower right and nothing happened, same with stick moved to lower left. When I lower throttle trim the LED on steadily. At this setup if I increase the throttle motors will start differently. M2-->add one throttle click--> M1-->add one throttle click-->add one throttle click-->M3-->add one throttle click-->M4.
I can see the motors speeding or slowing correctly but if I keep throttle at minimum some of them will stop moving after I stop playing with ele/rud/ail.
M1 (sometimes with M2) will start spinning at low speed if I close the throttle and turn off tx.
I also tried to move the board around but didn't notice any change on motor speed.
Sorry for my english.
skye is offline Find More Posts by skye
Old Sep 06, 2010, 12:55 PM
skye is offline
Joined Jul 2010
Cheers,
Ben.
Thank you for confirming this issue. Any picture of your bullet connector? Mine is actually one piece male.
Old Sep 06, 2010, 12:57 PM
skye is offline
Joined Jul 2010
Hi, just curious here, is there any reason not to etched out the wide portion of copper?
Old Sep 06, 2010, 01:09 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
If those big portion of copper is ground (which should be), then it acts like a shield against noise and interference.
-Thanh
thanhTran is offline Find More Posts by thanhTran
Old Sep 06, 2010, 01:22 PM
Xnaron is offline
Xnaron's Avatar
Joined Feb 2003
-Thanh
It would also take a really long time with the small bit I used.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
