Old Sep 05, 2010, 04:27 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by Xnaron View Post
Answering my own question here... just use the ULP command cmd-change-swap-layer.ulp be sure to check the switch A<>B checkbox.
Thanks Xnaron, I will add that to the download page.
Niall is offline Find More Posts by Niall
Old Sep 05, 2010, 04:31 PM
Crissbrasil is offline
Find More Posts by Crissbrasil
BRAZIL
Joined Jul 2010
Hi all
I bought a DX6i and a KK board complete for my tricopter.
so a need configure my DX6i for flying my tricopter
Could you pass me the configuration for my DX6i?
Thank you all
Crissbrasil is offline Find More Posts by Crissbrasil
Old Sep 05, 2010, 04:40 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Here is a version that I included the swapped board and schematic files (_swap) ... I haven't tested yet obviously
Xnaron is offline Find More Posts by Xnaron
Old Sep 05, 2010, 05:15 PM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by lowie View Post
Hey,
I have a simple question.What voltage gives the LM317LZ?
I have a simple answer:
many
See here on how to calculate what voltage you want it to output.
Mike Barton is offline Find More Posts by Mike Barton
Old Sep 05, 2010, 09:57 PM
cyhyam is offline
Find More Posts by cyhyam
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
My latest creation
cyhyam is offline Find More Posts by cyhyam
Old Sep 05, 2010, 10:05 PM
Flyboy_001 is offline
Find More Posts by Flyboy_001
. . . gravity?
Flyboy_001's Avatar
Huntsville, Alabama
Joined Mar 2008
Beautiful work Cyhyam!
Looking forward to the arrival of my board so I can join you with a KKcopter (octo version)
Any detail photos to share of your build?
Greg
Flyboy_001 is offline Find More Posts by Flyboy_001
Old Sep 05, 2010, 10:16 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by skye View Post
If I have to replace one bad ESC, do I need to get the same type? I am thinking of getting a different ESC but if I hate to waste the other three HK SS.
Different brand of ESC could result in different throttle range / resolution. You could use these 3 ESC's for tricopter.
thanhTran is offline Find More Posts by thanhTran
Old Sep 05, 2010, 10:19 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by cyhyam View Post
Beauuuutiful
Old Sep 05, 2010, 10:43 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by johnht View Post
Hi All
I've not yet had to work with the ATMEGAxxx range of micros - coming from a mainly PIC / Pascal environment. As can be imagined, having to plough through ATmega Assembler can be quite hairy to say the least. What I would like to know is whether any software design and or algorithm material exists that I could use to develop a controller?
Hi John
Welcome to RCgroups!
The last time I heard / used Pascal (programming language) was about 12 years ago. Is it still being used? Is that what you meant for Pascal.
I used to go to avrfreaks.net to learn more about Atmel chips. There are some tutorials there as well. If you start new, I would recommend going with C. Assembly is hard to maintain and takes more time write code.
Not sure what algorithm you want, but I assume you want the flight controller algorithm. Kaptein has posted the main part of the mixing algorithm here: http://www.rcgroups.com/forums/showp...&postcount=721
-Thanh
Old Sep 05, 2010, 10:45 PM
Fulg is offline
Find More Posts by Fulg
Fulg's Avatar
Montreal, Canada
Joined Sep 2008
Niiiiice, congrats cyhyam!
What did you use to make the landing gear? That's one of the challenges I have left on my KKQuad...
Fulg is offline Find More Posts by Fulg
Old Sep 05, 2010, 10:48 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
I like the "headlights", I may have to borrow that idea for my Hexa!
RTRyder is offline Find More Posts by RTRyder
Old Sep 05, 2010, 10:49 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
I used continuity and they're OK but just to make sure I replaced the cable and they too tested OK. However when I measure output on the motorside between +/- cable the readout is really different 0.00 - 0.05V & 0.16 - 3.36A while three others are ranging in 0.7 - 1.5V & 2.12 - 3.40A. It also gets warm pretty quick.
I don't understand the numbers in your measurements. Are you saying you measure both voltage and current between every 2 wires of the 3 wires from the ESC? If so, the pair that has zero voltage but high amp makes it sound like the motor is shorted.
If you just measure the voltage, and if your motor is good, it could be that one of the phases of the ESC has died.
The bridge could be normal, clean it up and see what's beneath it
-Thanh
Old Sep 05, 2010, 10:57 PM
skye is offline
Find More Posts by skye
Joined Jul 2010
-Thanh
The motor is good. I measured voltage and current without motor. How suck if the ESC died, it's still new! I guess the bridge has been there when it was working but I'll try to clean up, got nothing to lose,
Thanks Thanh
skye is offline Find More Posts by skye
Old Sep 05, 2010, 11:27 PM
Xnaron is offline
Xnaron's Avatar
Joined Feb 2003
On my tri when I do a full throttle climb the tail drops. I need to input down elevator to keep it level. I thought I had it balanced on the cg. Is this a balance problem or possibly ESC?
Old Sep 06, 2010, 12:05 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
I've seen that on my tri with KK code too. Don't know what causes it. I just assumed that it's probably my motors are not equal, and because throttle is already max, gyro can't push the tail motor more to balance the tricopter.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
