Old Sep 01, 2010, 02:18 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by SSM View Post
There seem to be two different schools of thought on this point:
1. It doesn't matter at all where on the frame the gyros are located. Gyros only detect angular changes and the angular changes are identical everywhere on the frame. See FlipFlop's tri-copter for an example of a tricopter with its gyros placed far off centre but which flies beautifully.
2. As thanhTran says - gyros should be central, so the axis of the gyros are on (or close to) the roll/pitch/yaw axes of the copter.
I'm a type 1 kind of person myself.
Simon
EDIT: I draw a picture and see that the rotation speed is the same no matter how close or how far it is from the center of the rotation. So gyro should be fine to be put away from center . Great to know this.
thanhTran is offline Find More Posts by thanhTran
Old Sep 01, 2010, 02:29 AM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
Originally Posted by thanhTran View Post
If we look at a rotating disc and put a nail at the center of the disc. This nail spins. Put a nail further away from the center this nail don't spin any more: it moves.
Maybe you should actually try that. I just have.
You'll find that for each one (1) turn of your rotating disc, the nail in the center makes one (1) turn. And the nail that's away from the center makes .... well, it also makes one (1) turn.
So, both nails (or both gyros, if you like) "feel" the same amount of rotation, whether they're at the center, or out and away from the center.
Simon
SSM is offline Find More Posts by SSM
Old Sep 01, 2010, 02:39 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
In that case, then moving gyros futher away from an axis wouldn't reduce sensitivity or allow for increasing gain, but would likley increase the noise vs signal ratio due to more linear vs angular motion. A few inches one way or another might not make any significant difference though.
patricklupo is offline Find More Posts by patricklupo
Old Sep 01, 2010, 02:40 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Interesting. I think the further away from the rotation axis, the gyro is less effective.
If we look at a rotating disc and put a nail at the center of the disc. This nail spins. Put a nail further away from the center this nail don't spin any more: it moves. The further away from the center, the faster it moves, and I believe it spins slower. Gyro works with angular rotation around its axis so it's best to put at the center. I'm interested to know if the rotation of the gyro is still the same when it's far away from the center of the CG of the heli though.
Interesting discussion.
A gyro at CoG experiences only angular motion, whereas if displaced, experiences both angular and a displacement movement (theres probably better words for this).
This ofcourse assumes that the model is in a fixed position, which ofcourse it isn't since it's inevitably moving around in 3 axis.
So I'm tempted to say it probably doesn't matter, but this is just my opinion.
Mike Barton is offline Find More Posts by Mike Barton
Old Sep 01, 2010, 02:44 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
A gyro measures angular velocity. Angular velocity is the same at the end of the arm as at the center of copter.
Bottom line: Gyros can be mounted anywhere you please as long as they are parallel to the axis it controls
JussiH is offline Find More Posts by JussiH
Old Sep 01, 2010, 02:56 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Simon
It doesn't matter for angle changes.
Look at the rc-heli gyro's, they are all off center!
manuLRK
alll is offline Find More Posts by alll
Old Sep 01, 2010, 06:57 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
push it to the limit and through corn
kk quadrocopter - devil inside (2 min 52 sec)
warthox is offline Find More Posts by warthox
Old Sep 01, 2010, 07:24 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
LOL! Did you offer the farmers some help for the harvesting?
kinderkram is offline Find More Posts by kinderkram
Old Sep 01, 2010, 08:04 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Hi Guys,
I had an amazing flight this morning getting some video. I flew at a location where I have always wanted to fly.. it is just such a great setting. I think this location was the final inspiration I need to convince me i needed a multicopter.
This is the local parish in the background with a War memorial and gardens in the foreground. How amazing to fly in this location whilst remembering those that gave their lives for their country... just special...
Hope you like it...
Charl
KK HexaCopter - 2010-09-01 - St Bartholomew's Parish & War Memorial (2 min 23 sec)
Here is my parts list,
KK Controller : http://www.kkmulticopter.com/
Motors : XYH 28-30B 750Kv 10A Brushless Outrunner
http://www.giantcod.co.uk/2830b-750k...-p-404451.html
Props : EPP1045 / 5mm
https://www.mikrocontroller.com/inde...9c02cde3e3873a
ESC's : TURNIGY Plush 18amp Speed Controller
http://www.hobbycity.com/hobbyking/s...idProduct=4312
Gyro's : Hobby King 401B Gyro
http://www.hobbycity.com/hobbyking/s...dProduct=10113
Batt : 2 X 3S1P 2200mAh
RX : JR R700 PPM 35Mhz
Motor to Motor distance : 80cm
My Photo Thread...
http://www.axlb16.dsl.pipex.com/My%2...ter/index.html
cvandenb is offline Find More Posts by cvandenb
Old Sep 01, 2010, 08:23 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Marcus,
More absolutely great flying and an excellent and entertaining video!
What version of board were or are you using now?
Thanks and Cheers,
Jim
@Cavdenb
Also nice video!
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by cvandenb View Post
Hi Guys,
I had an amazing flight this morning getting some video. ...Hope you like it...
My Photo Thread...
jesolins is offline Find More Posts by jesolins
Old Sep 01, 2010, 08:46 AM
Greasetattoo is offline
Find More Posts by Greasetattoo
The tattoo guy
Greasetattoo's Avatar
USA, MN, St Paul
Joined Jun 2009
Just ordered my board today.
Greg,
What board did you order?
I got mine from the classifieds from the KK site.
Eric sold it to me.
Let me know.
thanks
Grease
Greasetattoo is offline Find More Posts by Greasetattoo
Old Sep 01, 2010, 09:56 AM
spagoziak is offline
Find More Posts by spagoziak
"Let's put a camera on that.."
spagoziak's Avatar
Twin Cities, MN
Joined Feb 2010
Most retail gyro instructions ask to have the units placed as close to the axis it's intended to be watching, in my experience. It makes sense to me, but I'm intrigued that they would work just as well elsewhere..
Simon
spagoziak is offline Find More Posts by spagoziak
Old Sep 01, 2010, 10:04 AM
spagoziak's Avatar
Twin Cities, MN
Joined Feb 2010
Wow right through the cornstalks! You've got incredible flying skill Wart! I wonder how you'd do with a Trex 600... what a sight that'd be to see one of those plow through a stalk lol
Old Sep 01, 2010, 11:42 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
... that for each one (1) turn of your rotating disc, the nail in the center makes one (1) turn. And the nail that's away from the center makes .... well, it also makes one (1) turn.
You're right. They rotate with the same speed. So the effect of the gyro should be the same.
I'm wondering what kind of effect (if any) would the higher displacement speed cause to the gyro?
If i put my heli tail gyro at the end of the tail boom of the heli (almost 1m long, yes too extreme) would that work as well as when i put it in the heli itself?
Ah, I think it doesnt matter as heli or any other high speed plane also moves the gyro quickly and the gyro still works fine
thanh
Old Sep 01, 2010, 11:53 AM
QS-27 is offline
Find More Posts by QS-27
QS-27's Avatar
Girona, Spain
Joined Dec 2007
Yesterday I could do a quick test of my tricopter.
The day was very windy and only raised it a few seconds to see if everything worked correctly.
The board works great, now wait for the weather to improve to make adjustments to the gains of the gyros and trim settings.
Thank you very much to Niall, fulg, corbystarlet, spagoziak for helping me put my tricopter in flight.
Here is the video of the short flight; back in the trees can feel the wind.
1º test tricopter KK controller (1 min 11 sec)
QS-27 is offline Find More Posts by QS-27
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
