Old Aug 27, 2010, 04:09 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Originally Posted by IceWind View Post
I see more and more quads using the leds strips, do you guys
connect them directly to the Pack?
Or instead to a led switch, I know HK has this lumifly gear.
Thanks.
I connect my LED strip to my 11.1v main lipo via an R/C controlled switch from HK. That way I can turn it off so that it doesn't mess up the light balance from my camera when flying FPV. Ebay has lightweight flat SMD LED strips in most colors and lengths that you can cut to fit.
patricklupo is offline Find More Posts by patricklupo
Old Aug 27, 2010, 04:48 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
I got some led strips from ebay and as Initially I don't plan to put a camera on the quad I thought about connecting them directly to the lipo.
But I guess I'll hack up a rc switch for them as well..
IceWind is offline Find More Posts by IceWind
Old Aug 27, 2010, 05:34 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Or you can use a small brushed esc instead. Also gives you the added benefit of beeing able to adjust brightness on your LED´s
GWS ICS50/100 is perfect!
JussiH is offline Find More Posts by JussiH
Old Aug 27, 2010, 05:48 AM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Guys,
Mayby A stupid question, but how do you know your battery is empty?
Is it normal that the quad does do crazy things if the battery is bad? Yes, I know, the quad comes down then, but before that happends.
I'm using very bad lipo's, ( Full lipo 11,6v, and after hovering about 9,9v! I'm using an OSD, FPV) so mayby that's the reason?
Thanks.
Remy is offline Find More Posts by Remy
Old Aug 27, 2010, 07:00 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Farctors to increase the gains on roll & pitch
Hi,
On my mini quad (36 cm cross), I can't get more than 25% gain on roll and pitch, which make it difficult to fly in windy conditions, a slight wind guts, blows it away!
Can you help me defining all aspects the could help increasing the gain?
  1. Reduce vibration : balance motor and props
  2. Increase distance between motors (longer arms)
  3. ...
thanks,
manuLRK
alll is offline Find More Posts by alll
Old Aug 27, 2010, 07:38 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by Remy View Post
Guys,
Thanks.
Most people use these:
http://www.hobbyking.com/hobbyking/s...idProduct=7223
Old Aug 27, 2010, 07:44 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
This lipo alarm is load and accurate: http://cgi.ebay.com/Super-Lipo-Low-V...item5d2a9b8594
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Guys,
Thanks.
jesolins is offline Find More Posts by jesolins
Old Aug 27, 2010, 07:55 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Guys,
Thanks.
when its empty, the quad comes down, right. before that happens the quad is tilting and u have some seconds to bring it down.
i fly my copter 10min and look how much i can recharge. so i can setup the timer in my tx.
warthox is offline Find More Posts by warthox
Old Aug 27, 2010, 08:08 AM
coda vex is offline
Find More Posts by coda vex
Kansas, USA
Joined Aug 2010
Originally Posted by kapteinkuk View Post
Here is an example of tilting the motors on a CW/CCW quad to get better yaw response:
http://www.youtube.com/watch?v=t-2v-3LVO-0
Front and back motor is tilted to the right, as seen from the motor end of the arm.
Left and right is tilted to the left.
Thanks for the tip. Really good response. So if you look down the arm the two motors will look like they are leaning away from each other? So much for the square tubes.
Is that gun fire in the back ground?
coda vex is offline Find More Posts by coda vex
Old Aug 27, 2010, 08:13 AM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Some info on my new frame!
The biggest problem was to get my hands on some square tubing, but I got a tip
from kapteinkuk that Biltema had some "tørkestativ" with some perfect square tubing 15x15x0.8mm thanx Kapteinkuk!
I think it is about 50% done now and the weight feels quite good.
The landing skid is taken from a t-rex 500, the arm to arm is 60cm
I also stolen some of the Jakub design by solder the nuts to the board! Its realy a good idea.
culexus is offline Find More Posts by culexus
Old Aug 27, 2010, 08:23 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Better quadrocopter yaw response by tilting the motors. (0 min 35 sec)
Is this quad all with 4 CCW props, or 2CW and 2CCW?
I fly my mini quad with 4 CCW props, and tilt as you the front and back motors.
manuLRK
Old Aug 27, 2010, 08:35 AM
warthox is offline
Joined Aug 2009
my mini tri flies ;-)
225mm motor to motor
386gr w/o batterie
583gr with 3s21000
kk minitri copter (2 min 55 sec)
Old Aug 27, 2010, 08:43 AM
Greasetattoo is offline
Find More Posts by Greasetattoo
The tattoo guy
Greasetattoo's Avatar
USA, MN, St Paul
Joined Jun 2009
Towel racks (aluminum) bought at your local home store!
Greasetattoo is offline Find More Posts by Greasetattoo
Old Aug 27, 2010, 09:03 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Carbon Fibre Frames - Any interested?
Hi All,
I've met with a local CNC company to ask if they can cut me some Carbon Fibre for the centre frame of my multicopter. You may have come across them, these are the guys that do the NHP helicopter carbon blades... really good stuff, I actually fly them myself on my 50size heli
The answer is yes... but the catch is I have to buy the complete carbon sheet even if i only want one frame set. So, I can get a number of sets out of one sheet.
Please see the attached graphic of what i will be cutting. If you are interested, let me know. If we have enough interest, i will get it cut and post the sets.
Please see the second attachment for dimensions.
I am proposing that we use a carbon thickness of 1.5mm. We also have a 2mm option, but its heavier and more expensive.
The Hex frame will use the same dimensions and holes, except it will have 4 arms instead of 6 as per the diagram.
So here are the prices,
- If we get 7 people interested in the Quad frame (i will take the two HEX pairs), then the cost PER SET (2) will be £32 (excluding shipping)
- If we get 21 people interested in the Quad frame and 4 people in the HEX frame, then the cost PER SET (2) will be £22 (excluding shipping)
Looking forward to your interest
cvandenb is offline Find More Posts by cvandenb
Old Aug 27, 2010, 09:04 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
386gr w/o batterie
583gr with 3s21000
What are the pot values?
Gyro HK401 ?
manuLRK
PS: I still can't believe you never flow helis before!.?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
