Old Aug 26, 2010, 12:58 PM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Today fun flying ;)
Plus hard landing in to the grass
http://www.youtube.com/watch?v=7MPlcvXjqxU
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Aug 26, 2010, 01:25 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
It's almost alive
rcimports is offline Find More Posts by rcimports
Old Aug 26, 2010, 01:31 PM
coda vex is offline
Find More Posts by coda vex
Kansas, USA
Joined Aug 2010
Cool!
coda vex is offline Find More Posts by coda vex
Old Aug 26, 2010, 01:44 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by rcimports View Post
It's almost alive
Looking very cool. icy.
Niall is offline Find More Posts by Niall
Old Aug 26, 2010, 02:21 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
I have asked this before and have been unable to find the problem - When testing the yaw then I give it full left yaw stick I get the back motor speeds up - when I give it full right stick I do not get any change in motor speeds on the right or left motors - What would cause this? Where do I start trouble shooting? Thanks
cdi3d is offline Find More Posts by cdi3d
Old Aug 26, 2010, 02:26 PM
ta2cba is offline
Find More Posts by ta2cba
United States, NY, New York
Joined May 2009
I get exact same prob in my quad only with v4.5.no prob with v4.3.i thought it was my settings of yaw pot.
Cheers,
bA
ta2cba is offline Find More Posts by ta2cba
Old Aug 26, 2010, 03:10 PM
coda vex is offline
Kansas, USA
Joined Aug 2010
Gyros!!!!
Fresh from Hong Kong to my door today. Let the build begin!!!
Been a long time since I've soldered, hope I don't screw this up.
Old Aug 26, 2010, 03:22 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
I have been trying several different things - Everything yaws great to the left but when I go to the right is is very slow to respond sometimes not at all -
MIke
Old Aug 26, 2010, 03:50 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
MIke
If you plug a servo to ch4 of the receiver, do you see if servo moves equally in both directions when moving rudder stick?
thanhTran is offline Find More Posts by thanhTran
Old Aug 26, 2010, 06:49 PM
don_cocinero is offline
Find More Posts by don_cocinero
Tinkerer
don_cocinero's Avatar
Earth
Joined Oct 2005
Originally Posted by cvandenb View Post
Hi Jim,
Yes, but... i have only used 55% of the capacity... I never like to go over 50%, i like to leave a safe margin.... Hex's dont bounce very well when they drop out of the sky
You might want to test the flight time calculator available here.
don_cocinero is offline Find More Posts by don_cocinero
Old Aug 27, 2010, 02:04 AM
skye is offline
Find More Posts by skye
Joined Jul 2010
booyah! finally i got most of the parts!
now it's noob question again, here's from the 1st page regarding V6 TH board :
C1,2,3,4,9,10,11: 100nF ceramic capasitor.
C7: electrolyte or tantalum with a value of 10uF and upwards.
C5,6,8: 0.68uF Tantalum.
got Niall's board and there is one unlabeled electro-cap between leads, is that C9? anybody can confirm this?
also, C7 & C9 anybody knows if it's better to use 10uF or 33uF (that's the value on the scheme)?
skye is offline Find More Posts by skye
Old Aug 27, 2010, 03:09 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Here is an example of tilting the motors on a CW/CCW quad to get better yaw response:
Better quadrocopter yaw response by tilting the motors. (0 min 35 sec)
Front and back motor is tilted to the right, as seen from the motor end of the arm.
Left and right is tilted to the left.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 27, 2010, 03:15 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
I see more and more quads using the leds strips, do you guys
connect them directly to the Pack?
Or instead to a led switch, I know HK has this lumifly gear.
Thanks.
IceWind is offline Find More Posts by IceWind
Old Aug 27, 2010, 03:38 AM
wuselfuzz is offline
Find More Posts by wuselfuzz
Joined Feb 2010
I might have mentioned it earlier in this thread, but I'm creating something similar, based on a Walkera RX2435.
Right to the interesting parts:
Pic of the top PCB of the RX2435: http://wuselfuzz.de/crapcopter/rx2435_gyro_top.jpg
Code:
   o Z
   o X?
   o Y?
   o ?
   o sw2
   o ?      o GND
   o pot4   o sw1
   o pot3   o 3.3V
   o pot2   o LED
   o pot1   o 2.8V
So by just powering up the rx, there's a 2.4 GHz Walkera compatible receiver, analog gyro outputs, and a nice 2.8V reference voltage for the ADC.
Gyros are centered at 1.35V.
Another interesting fact:
142 Hz PWM on Elevator, Aileron and Throttle, FM on Rudder.
In my software, I'm using a pretty simple IRQ mechanism to sample input data. E,A,T on PCINT21/22/23, looking like this (rewritten from memory, code is at home, it's just to show the idea):
Code:
// initialization: TCNT1 is initialized with 1/8 prescaler and free running,
// so it counts microseconds. PCINT2 is enabled for PCINT21/22/23,
// PCINT0 is enabled for PCINT0
// global variables
volatile uint16_t e, a, t, r;
uint16_t T_last;
uint16_t TR_last;
uint8_t PD_last;
uint8_t PB_last;
ISR( PCINT2_vec ) {
   uint16_t t = TCNT1; // save timer right at start of interrupt
   uint8_t pb = PINB;
   if(PB_last&(1<<5)) e = T_last - t; // if PB5 was set during the last interrupt, it must have gone down now!
   if(PB_last&(1<<6)) a = T_last - t;
   if(PB_last&(1<<7)) t = T_last - t;
   T_last=t;
   PB_last=pb;
ISR( PCINT0_vec ) {
   uint16_t t = TCNT1;
   uint8_t pd = PIND;
   if(PD_last&(1<<0)) r = TR_last - t;
   TR_last = t;
   PD_last = pd;
wuselfuzz is offline Find More Posts by wuselfuzz
Old Aug 27, 2010, 03:51 AM
Niall is offline
Joined May 2010
Yep, that other big one in between the leads is C9 and should be 33uF.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
