Old Aug 26, 2010, 01:15 AM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
Originally Posted by 321 View Post
Another one of the speed controllers went up in smoke. So much for having a spare. These speed controllers are the HK 18Amp SS ones.
Is there something I need to check on the controller before replacing the speed controllers?
Some people are saying it's not much of a problem, and I don't know how I would be able to calculate WHEN it would become a problem but....
Your ESC will SUDDENLY require a serious current when it turns on a motor coil. The wires from the battery to the ESC function electronically as a coil (if you coil-up a wire it works more that way, but a straight wire works as well!). This means that if the current through the wire is now 0A, it cannot be 20A the next moment. It takes a while for the electrons to get going.
So, that's why there is this big capacitor on the ESC: It is closeby, and it will provide the current for the instant that the wire to the battery is not yet adapted to to the new current. Voltage will sag a bit but usually not so much as to be a problem.
Similarly if the ESC suddenly turns OFF a motor, the current will suddenly drop. But that wire is still transporting amps. It takes a while for the battery side of the wire to notice, so it will continue pumping those amps. Again this capacitor will take up the extra electrons. Voltage will spike a bit, but usually not so much that it's a problem.
The capacitor required to solve these problems depends on how much wire you have. So HK designed the ESC with a capacitor that works in the normal case. But if your wires are longer than "normal", that capacitor might not be enough.
Will the ESC blow up spectacularly if the capacitor is the problem? Yes! First the capacitor will be overloaded. Then as the capacitor degenerates especially the voltage spikes will become larger and larger. Once they hit 20V, the power-FETs are outside their safe operating area. They burn spectacularly. And again... once one goes, it will short and take its brother along with it....
rewolff is offline Find More Posts by rewolff
Old Aug 26, 2010, 01:16 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Hey Charl,
Where did you get the pots for your PC board and what K ohms are they?
Originally Posted by cvandenb View Post
patricklupo is offline Find More Posts by patricklupo
Old Aug 26, 2010, 01:25 AM
don_cocinero is offline
Find More Posts by don_cocinero
Tinkerer
don_cocinero's Avatar
Earth
Joined Oct 2005
Originally Posted by spagoziak View Post
Hi again! I'd like to use a switch to control power from the battery. I plan on using 3S lipos, 20C to 30C. The speed controllers are Turnigy Plush 25A. Is this switch an appropriate choice?
http://search.digikey.com/scripts/Dk...ame=67-1934-ND
Not sure where you intend to put the switch (on the battery or on the rail to the board) I hope you want to put the switch on the board
If on the board I would use this
If you want to put a switch on the battery just remember that you could have as much as 50A going though it
don_cocinero is offline Find More Posts by don_cocinero
Old Aug 26, 2010, 01:45 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Nice way to explain it. I remember reading some arguments whether to extend wires on the battery side or wires on the motor side. I think the consensus was leaving the battery side wire short and extend the wires on the motor side or adding some caps in the middle of the long wires because of this reason.
thanhTran is offline Find More Posts by thanhTran
Old Aug 26, 2010, 01:52 AM
rewolff is offline
NL
Joined Nov 2009
Your four ESCs are capable of pulling 100A total, the 25A contact rating is a bit small. At 1kg (a guess) your quad would hover at around 16A. Close but might work. When you connect a battery it always sparks, this would now happen inside the switch. I expect that this current-inrush is about 1000A. This is so short that all components involved are usually not bothered too much about this.
Sparks usually happen when current is suddenly blocked. So why would my plug on the battery spark when I plug it in? I think that when I first touch the copper contacts, the current rises to that 1000A, but with the small contact, the conducting copper is much too small, and will evaporate, break the connection and spark. There is a visible burnmark on my 120A rated plug!
The contacts in such a switch are much smaller than the 120A plugs that I have. They might get welded together by these currents. Either on the first try or after a few times of use...
Old Aug 26, 2010, 02:04 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Hi All,
So here is the second video from yesterday i was waiting for.
Here i went to fly inside the woods at my local park. It always feels like a magical place, and being able to fly inside, was just great.
Hope you enjoy it too....
KEEP YOUR SOUND LOW (no music, just prop noise)
KK HexaCopter - 2010-08-25 12pm - Flying in the Woods (3 min 36 sec)
cvandenb is offline Find More Posts by cvandenb
Old Aug 26, 2010, 02:12 AM
rewolff is offline
NL
Joined Nov 2009
Originally Posted by ta2cba View Post
This itg gyro needs a total gyro interface code rewrite.it's I2C.
You could take a look at "baronpilot". It uses I2C to talk to the gyro in a Wii Motion Plus .....
Old Aug 26, 2010, 02:18 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
I would recommend to take a look at TriWiiCopter or Aeroquad instead.....
JussiH is offline Find More Posts by JussiH
Old Aug 26, 2010, 02:20 AM
rewolff is offline
NL
Joined Nov 2009
YYIIPPPEEE - Yet another great flight with my new KK Hex...
Hey Charl,
Have you considered/tried rotating the camera 30 degrees? Then it will point between two props. Humans always focus on the center of an image. and that's exactly where the prop is now. Of course then there would be two props in view...
Old Aug 26, 2010, 02:28 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Hi All,
H...
Niceee. So stable and no shake. I think I'm gonna build a hex
Old Aug 26, 2010, 03:04 AM
cvandenb is offline
cvandenb's Avatar
Manchester
Joined Jul 2008
Originally Posted by patricklupo View Post
Hey Charl,
Hey...
Unfortunately i cannot say I bought the board plus all the components as a bundle from Niall. The best would be to PM Niall...
Old Aug 26, 2010, 03:07 AM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Originally Posted by kapteinkuk View Post
I buy a "TÝrkestativ" from Biltema: http://www.biltema.no/no/Fritid/Hage/Ovrig/Torkestativ/
Hehe Thanx Kapteikuk, then off to biltema we go!
At first I was trying to get my hands on some old tv antenna, I hoped that they did`t trash all the old NRK antennas from the analog times But I was wrong
But "tÝrkestativ" will do the job!
culexus is offline Find More Posts by culexus
Old Aug 26, 2010, 03:19 AM
cvandenb is offline
cvandenb's Avatar
Manchester
Joined Jul 2008
Hey Charl,
Hey...
Thank you for the suggestion.
I kinda have... but that makes it a bit hard to aim the camera at what you want whilst keeping orientation of the heli...
This is only a temporary mount for the camera... i was just so excited about how great it flies and the video i can get, that i've not completed the final mount.
The final mount will be hung under the frame shooting down and forward, so there should be no part of the heli is view. I have it all ready, i just need a high enough undercarriage, there is a few i have my eye on
Charl
lowie is offline
Find More Posts by lowie
Joined Mar 2010
420RCpilot,
Could you send me the e-mail please?So that i can start to make my board.
You can also post it here.
Thanks Lowie
lowie is offline Find More Posts by lowie
Old Aug 26, 2010, 05:13 AM
ta2cba is offline
Find More Posts by ta2cba
United States, NY, New York
Joined May 2009
Actually I can talk to ITG3200 with I2C! I have to off those gyros and using them at the moment on another quad project tests Baron pilot uses Wii motion plus which is the cehapest way to build a quad.The celever bit is that he is using wii motion plus as is with wii's I2C interface!I have two wii motion plus snesors but didn't have time to crack it.
Cheers,
BA
ta2cba is offline Find More Posts by ta2cba
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
