Old Jan 22, 2010, 07:40 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Your calculation is right. (Other than rounding off of 1024 to 1000, the LSB is 3.64 degrees/second )
However, the noice entering the system, vibrations from the motors, noice from the gyro itself (the internal 30 kHz osc) and ADC noice causes dithering.
This improves sensibility alot, and as you can see on the video it works
I later used a red LED instead of the 2.5V reference, giving 1.8 V and 2.62 degrees/second. This did not improve flight at all. However, it is incorporated into the second version of the controller, coming soon. It will also have pots for gain adjusting, instead of fiddling with the software.
I can, by biasing the ADC with 0.5V, AC coupling it to the gyro and use the internal 1.1V reference, get a sensibility of 1.6 deg/sec. Or even use an amplifier, but then the low part count starts to rise!
kapteinkuk is offline Find More Posts by kapteinkuk
Old Feb 09, 2010, 09:47 AM
Quad Whisperer
Joined Jul 2008
Here is the new controller V2.
-Added 3 potmeters for gain adjusting.
-Lowered the ADC reference to ca. 1.5V for higher resolution.
-Fixed a bug in the float to 16.16 signed binary converter (Assembler functions used during assebly). The bug appeared when using negative gain for gyro reversion. Also tidied up the format to write floats in the source code.
-Uses the complete gyro sub assembly from the HK401B gyro, with capacitors.
Video will follow shortly.
Old Feb 09, 2010, 10:13 AM
jk3n0bi is offline
Find More Posts by jk3n0bi
UFO addict
jk3n0bi's Avatar
Texas
Joined Jan 2009
looking good. Are you planning on selling a kit or some type of tutorial on how to build her up?
jk3n0bi is offline Find More Posts by jk3n0bi
Old Feb 10, 2010, 11:50 AM
outsider787 is offline
Find More Posts by outsider787
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
The HK401B gyros from HK are $14.
You can get a single axis gyro breakout board (LY530AL) from Sparkfun for $20.
I'm wondering if the extra $6 are worth it for the sparkfun board. Are the specs comparable?
outsider787 is offline Find More Posts by outsider787
Old Feb 10, 2010, 06:37 PM
Quad Whisperer
Joined Jul 2008
No kit, but I might make a tutorial. However, it should not be to hard to build it from shematics and the pictures.
Old Feb 10, 2010, 07:03 PM
Quad Whisperer
Joined Jul 2008
It has better specs than the HK401 gyro, no problem using it. By using the 4x output, the sensitivity is 0.44deg/sec which is not bad.
However it needs 3.3V, so a V reg must be added.
But I do not think it will increase the overall performance of the flight controller alone, the framerate must also be increased. Higher framerate might be incorporated in the software in the future.
Old Feb 10, 2010, 07:51 PM
Quad Whisperer
Joined Jul 2008
Here is a video of my new quadrocopter with this flight controller: http://www.rcgroups.com/forums/showthread.php?t=1191843
Old Feb 12, 2010, 06:14 AM
bachurelis is offline
Find More Posts by bachurelis
Joined Jan 2010
Amazing, kaptein!
There are no accelerometers in controller. Do you feel some gyro drift? (I can’t see it in video).
bachurelis is offline Find More Posts by bachurelis
Old Feb 12, 2010, 08:18 AM
Quad Whisperer
Joined Jul 2008
My controller is using angular rate damping only (the deriative element of the PID loop), so any drift is canceled out with the trim buttons.
Old Feb 12, 2010, 10:00 AM
jk3n0bi is offline
UFO addict
jk3n0bi's Avatar
Texas
Joined Jan 2009
I wanna build one
Old Feb 13, 2010, 11:30 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Hello kapteinkuk
what about
port assignment
after ARDUINO ?
Rx / Tx free for Bootloader ?
PB6 / PB7 for Xtal ?
LED1 ... PB5 ?
. .include "m168def.inc" - no problem
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Feb 15, 2010, 05:12 AM
kamakazikev24 is offline
Find More Posts by kamakazikev24
Joined Nov 2006
Great Job!
I like many others would love to build one of these.
However like many others I would'nt know where to start, esp using my laptop to install your software afterwards.
If you sold a kit with full instructions I would be more than happy to trial it and of course pay you.
I can solder and have some electronic knowledge, but mostly as a signal faultfinder on the railways in the UK.
Oh and I can reflash my Blackberry but not sure if that counts! Lol.
George.
kamakazikev24 is offline Find More Posts by kamakazikev24
Old Feb 15, 2010, 05:25 PM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by kamakazikev24 View Post
Great Job!
by low price, with, PonyProg - http://www.lancos.com/prog.html
- http://www.olimex.com/dev/pdf/avr-pg1b.pdf
jürgen
Old Feb 17, 2010, 09:42 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
kapteinkuk it looks like if I wanted to build the circuit I might have trouble locating an 8 mhz atmega48. Could a 20 mhz be substituted or would I need an external 8 mhz clock?
A second look yielded some 10 mhz as well but I am still curious about the timing.
Well a third look at the pic shows the 20PI to be a 20mhz version so I guess the 8 mhz is derived from dividing the internal osc down. Forgive me the 2313 was the last avr I worked with.
pug398 is offline Find More Posts by pug398
Old Feb 19, 2010, 12:44 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by JUERGEN_ View Post
Hello kapteinkuk
what about
port assignment
after ARDUINO ?
LED1 ... PB5 ?
jürgen
Do you mean for using Arduino hardware?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
