Old Aug 19, 2010, 05:24 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Thanks Niall, sent you a PM.
rcimports is offline Find More Posts by rcimports
Old Aug 19, 2010, 07:45 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Originally Posted by Niall View Post
OK Charl and Dion, I found the problem with Charl's chips. .....
Hi Niall,
That is excellent news !! Thank you again for the support and looking forward to getting the updated chips
Charl
cvandenb is offline Find More Posts by cvandenb
Old Aug 19, 2010, 08:13 AM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Originally Posted by Jakub J View Post
How long?
If you want fly longer than a few minutes, and safe
do not excess 350-400g / motor...
Jakub
why is that Jakub?
I have a quad with motors giving as much as 2500+g each, I don't think it would be "unsafe" to request 1000g for hovering, don't you think
Quad 1650g weight is way too heavy!
You can make without problem quad RTF <> 800g
Well this is true... and untrue.
It depends on the machine you build and what it carries.
So yes, 1650g for an empty 50cm machine is way too heavy, but if it is for a complete machine with camera mount, camera, video downlink and battery (ies), it really is a very decent weight.
So it's only a matter of what you use for he intended job, then try to keep motors + escs + propellers + batteries so that a 2/1 thrust to weight ration is achieved, and you'll be just fine.
FYI, best motor efficiency generally is achieved around 1/3 o max thrust.
FWIW,
Bob
bob.titus is offline Find More Posts by bob.titus
Old Aug 19, 2010, 08:42 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
PCB TH V6 finished...
All recycled parts, this makes it longer to assemble, but it is "learnfull"! I can start the programming now! ...
Any suggestions for the next? How to check the circuit before putting the IC? ...
I will use the USBasp and eXtreme Burner.
manuLRK
alll is offline Find More Posts by alll
Old Aug 19, 2010, 09:52 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Getting crazy and will hack the FY20A for the KK
OK, after tested the FY20A and found that I should maximise it and make exery dollar spend worth!!.
If I just add the FY20A to the KK Quad, the gyro mode seems like a monster to adjust the gain to match the KK. So only direct switch to Stable mode which fly ok and feel like added insurance in case of lost orientation. - Not optimum!!!
The self correct takes few seconds to get back to level and it still drift a fair amount.
Since the FY20A already have the Gyro build in, why not use it to direct the KK as well???
I am going to use the KK board w/o Gyro and tap out the Roll/Pict/Yaw Gyro output and connect direct to the KK Gyro input. The FY20A is using the LPR/LY 530 which having very similar spec on ref voltage so I assume this should be a direct drop in.
I just done a voltage tap from the chip output pin after the 10K resistor is Zero at 1.25 (maybe my meter is not that great as rated Ref is 1.23 according to spec). Done some shake and it does jump sometime above 1.6V. Assume it wont be that extreme in actual flight.
What do you think? Make sense?
Will post some picture tomorrow as only will start to do the solder tomorrow.. it is late now..
Cheers!
Dan
ps: spec for the Gyro in FY20A
http://www.st.com/stonline/products/...2/lpr530al.pdf
http://www.st.com/stonline/products/...1/ly530alh.pdf
dt8666 is offline Find More Posts by dt8666
Old Aug 19, 2010, 09:53 AM
chris_g_69 is offline
Find More Posts by chris_g_69
Joined Jul 2010
Originally Posted by thanhTran View Post
As long as you align the gyro with the arms, I don't think the orientation would cause problem. Mine is like this:
What's the total value of the output capacitors? I can see you have one on the gyro board and two connected parallely on the controller board.
Chris
chris_g_69 is offline Find More Posts by chris_g_69
Old Aug 19, 2010, 09:57 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Bob, on your trouble shooting guide, why do you recommend setting the ESCs to NMh mode instead of Lipo, even when Lipo is being used? I am recalibrating my ESCs and I thought I should find out the reasons why that setting works better..
Cheers,
Niall
Niall is offline Find More Posts by Niall
Old Aug 19, 2010, 10:01 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
This is probably guide to quadpowered controler...
I did not see any reason to do this with KK
J.
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Aug 19, 2010, 10:09 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Cheers,
Niall
yes there is a major reason : when you set to LiPo you activate LiPo cut off, and you really don't want your motors to shut off in flight, do you
When set to NiMh, escs won't cut off when battery is low, and that's exactly what you want.
J.
Do you see the reason now Jakub
This setup applies to any multirotor, only the section in orange concerns quadpowered specifically.
After you have built and flown enough different platforms, you will realize the similarities...
Hope this helps,
Bob
Niall is offline
Joined May 2010
J.
What settings do you use for your ESCs Jakub? Are they Turnigy Plush?
I am compiling a big list of FAQs.
Cheers,
Niall
Old Aug 19, 2010, 10:11 AM
Niall is offline
Joined May 2010
Originally Posted by bob.titus View Post
yes there is a major reason : when you set to LiPo you activate LiPo cut off, and you really don't want you motors to shut off in flight, do you
This setup applies to any multirotor, only the section in orange only concerns quadpowered only.
After you have flown enough different platforms, you will realize the similarities ,)
Hope this helps,
Bob
LOL, experience is the best teacher.. I will put this explanation in the Tutorial.
Cheers,
Niall
Old Aug 19, 2010, 10:59 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Cheers,
Niall
TowerPro 12A, Turnigy 10A - settings typical, nothing special
J.
Site Sponsor
Old Aug 19, 2010, 11:05 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
TRI v3 ;)
Hi
Do you remember my first video with TRI crash at the end?
I spend last days working with this problem and here are results
http://www.youtube.com/watch?v=o7Tjrz89Qqw
Servo: Hitec HS-65HB
Props: GWS 10x4.7" SF
I'll make tests a few other servos and make list of "tested and approved"
Jakub
Site Sponsor
Old Aug 19, 2010, 11:08 AM
Niall is offline
Joined May 2010
Hi
Jakub
Yes please do, and for motors also. I have ordered some RC-Timer 750Kvs and I am looking forward to trying them out. My Strong Power 1100KVs are too much for my quad.
Niall
Old Aug 19, 2010, 11:13 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
...I spend last days working with this problem and here are results :...
it's very good Jakub, your tri is very stable.
Do you use the default linear curve for your throttle or did you make a special curve?
Bob
J.
cool, thanks
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
