Old Aug 18, 2010, 11:27 PM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
hello kapteinkuk,
i used the camerapantilt hex for the quad board and connected the servos @ 15,16 (atmega168) and tx channel 1 and channel 2 @ pin 2,3 respectively .. but led doesn't turn on .. and doesn't work either , please help me i have built the pan tilt frame ,waiting for the software to work for.. i have built the hex using your 168 headerfile . please help me . does this software need some modification in your hardware
quaddynamics is offline Find More Posts by quaddynamics
Old Aug 19, 2010, 01:54 AM
chris_g_69 is offline
Find More Posts by chris_g_69
Joined Jul 2010
Hi,
anyone using lpr/lpy550 and happy with them? my quad is very stable with gyros from hk401, 100% gain, but i can't get 550s to work, it's unstable, oscilates even with low gain. 550 are really cheap and seemed great alternative to hk401 so can someone share their proven design please?
Chris
chris_g_69 is offline Find More Posts by chris_g_69
IWCoburg is offline
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Originally Posted by fireslayer26 View Post
I'm thinking of trying this setup and wanted to get others opinions.
Jakub's 68cm fiberglass frame + FLYCAM Artist xm-L4500Pro camera mount.
Aske me in a day or so when I have fitted mine to the smaller frame
I ordered one of those yesterday to go on the smaller frame as putting the camera on top of the frame made it too top heavy on my setup. I have the KK board in a plastic tub on top of the frame so camera is about 3-4 inches above the upper frame, so wanted somehtign to undersling the camera and the Pro seems to be about the right sorta thigns, but concerned about the camera mount itself, as it does not look very good.
Will post more when I have it.
Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old Aug 19, 2010, 02:17 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by chris_g_69 View Post
Hi,
anyone using lpr/lpy550 and happy with them? my quad is very stable with gyros from hk401, 100% gain, but i can't get 550s to work, it's unstable, oscilates even with low gain. 550 are really cheap and seemed great alternative to hk401 so can someone share their prooved design please?
Chris
lpr/lpy550 has different electrical characteristics to the hk401 gyros.
You are changing the R10 (original value 68 Ohms) to a different value when running this different gyro ?
For lpr/lpy550 (un-amplified output):
Zero-rate level 1.23V + ((2000d/s x 0.5mV/d/s)/1000) = 2.23V
R10 would therefore need to be a value of at least say 180 Ohms (200 may be safer) which would allow for up to 2.27V.
Mike Barton is offline Find More Posts by Mike Barton
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Hi,
Chris
Do you use 1X or 4X output? I'm using 1X outputs and I'm happy with them
http://www.rcgroups.com/forums/showp...postcount=2077
-Thanh
thanhTran is offline Find More Posts by thanhTran
Old Aug 19, 2010, 02:45 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
In my test with the 1x output, I've never seen it reaches that high of a voltage. With a bench test and a fluke 179 in min/max mode, I see it's registers around 1.38v when I twist the gyro board.
The document here http://www.st.com/stonline/books/pdf/docs/15813.pdf (figure 4) shows it's max at 1.48v for 1X output and that's aligned with what I see. In fact I fly with the stock KK board (see above post)
I don't understand the part of the spec that says the measurement range is capable of 2000 degrees/sec, but chip is only 500 degrees / secs. Any idea?
Thanh
Old Aug 19, 2010, 03:10 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Thanh
That is after 4X amplification according to spec.
Dan.
dt8666 is offline Find More Posts by dt8666
Old Aug 19, 2010, 03:18 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Dan.
If you look at Table 3 section 2.1 of http://www.st.com/stonline/books/pdf/docs/15813.pdf, it says FS measurement range (NOT AMPLIFIED) is 2000*/s. The 4X out is still only 500*/s. Spec wrong?
-Thanh
Old Aug 19, 2010, 03:24 AM
United Kingdom
Joined Nov 2008
Thanh
You're not twisting it enough
Thanh
Thanh
I think this datasheet is slightly suspect as Figure 4 doesn't agree with Table 3. The un-amplified outputs in Table 3 say 2000 degrees / sec whereas Figure 4 shows 500 (or perhaps I'm not reading it right).
Using 2000 degrees / sec in Figure 4 would give the same s suspect since you would get the same voltage out
If yours flys ok then I would recommend to chris_g_69 to go with the same as you ...
Old Aug 19, 2010, 03:38 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
lpr550/ly550
normal
zero rate 1.23 + 500*0.5mV = 1.48V
amplified
zero rate 1.23 + (500*0.5mV)*4 = 2.23V
warthox is offline Find More Posts by warthox
Old Aug 19, 2010, 03:48 AM
Joined Jul 2010
Description: I use 1x output. What about gyros orientation on the board, mine are rotated 45 degrees?
Old Aug 19, 2010, 03:58 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Attachment 3424234I use 1x output. What about gyros orientation on the board, mine are rotated 45 degrees?
As long as you align the gyro with the arms, I don't think the orientation would cause problem. Mine is like this:
Old Aug 19, 2010, 04:02 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Obviously with all the wires on a bench test duh
Certainly it's not a 2000*/s gyro, and with 1x output, it can't be 2.x volts. Speaking of this Vref, my first KK board with my own PCB was running at 2.5v so I'm fine either way. Spec says 1.48v and it's working happily in one of my stock tricopter board (1.6v vref). Quad flies with 2.5v vref.
EDIT: just did some reading live on my quad and with very strong twisting (of a average build 35+ year young guy ) of the arms, Fluke 179 says min 0.806v max 1.649v. Fluke may smooth out the reading a bit though
Old Aug 19, 2010, 05:16 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
OK Charl and Dion, I found the problem with Charl's chips. It was CHKDIV8 that was checked in the fuses section. This was dividing the clock speed by 8 and causing the long time till the LED flashed. I have reprogrammed them with the the latest firmware with the Arm/Disarm feature and will get them out today. Dion, Let me know if you want my guys in Zim to send you down a replacement, or if you are going to get a programmer yourself to upload future firmwares.
Cheers,
Niall
Niall is offline Find More Posts by Niall
Old Aug 19, 2010, 05:24 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
This is my 3D cube...
manuLRK
alll is offline Find More Posts by alll
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
