Old Aug 18, 2010, 03:45 PM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
Originally Posted by warthox View Post
if it works i will layout a smaller pcb.. lets look how small we can do this with this little gyro..
When you do, think about adding a place for an accelerometer. The one that sure electronics sells a breakout board for ($6.50) looks compact.... Only two pins (SDA, SCL).
rewolff is offline Find More Posts by rewolff
Old Aug 18, 2010, 03:46 PM
jjk77 is offline
Find More Posts by jjk77
No, it's the same plane ...
jjk77's Avatar
Deutschland, Nordrhein-Westfalen, Bochum
Joined Jul 2010
Originally Posted by bob4432 View Post
i tried google translate and no mention of kk.....
I think you must go onto this site: http://cafe.naver.com/multicopter
And there is a link to the shop and also there is mentioned that the design is from kaptainkuk
Jens
jjk77 is offline Find More Posts by jjk77
Old Aug 18, 2010, 03:47 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
the board has the same size as the original kk board. its one chip with 3 gyros internal. the black thing down right on the pic. 4.4mm x 7.5mm x 1.1mm with 28pins under the case. nothing for beginners
once a design is finalized, solder stencil but will you stay 0805 w/ the resitors/leds, caps could be a bit smaller than current but please don't go smaller than 0805 on those either. don't want to turn anybody off w/ a smt design
those gyros should be coming online shortly - they are up at mouser, just no stock and they are considered active on the st site. too bad st won't talk to the "little guy" in regards to, well, anything....
bob4432 is offline Find More Posts by bob4432
Old Aug 18, 2010, 03:51 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
Jens
thanks, hopefully the boards will have a reference to kk too
Old Aug 18, 2010, 04:33 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
right now the R are 0603 if u want i can make a layout with 0402
warthox is offline Find More Posts by warthox
Old Aug 18, 2010, 04:41 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
I got everything working!
Im soo happy right now! hehe. Thank you all for all the help I got from you people I took my time to balance the propellers and also found out that I got my yaw gyro reversed. Now everything is perfect i think, maby some small adjustment left but it is flying!
I use the GWS 3 blade 9x5 (cw and ccw), ordered from himodel.com
http://www.youtube.com/user/josteinkallevik
culexus is offline Find More Posts by culexus
Old Aug 18, 2010, 04:42 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
oh man, does 0805 make it that much larger? i just don't want your design to alienate people so we can still get enough made in bulk so they will be cheap like now NOOOOO on the 0402, i would have to buy a microscope to assemble and tweezers that have tips made from flea hair....
Old Aug 18, 2010, 04:48 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
Congratulations. Excellent maiden flight.
Niall is offline Find More Posts by Niall
bob4432 is offline
bob4432's Avatar
Joined May 2010
very nice and congrats just out of curiosity, does your neighbor have a ladder attached to the side of his house?
Old Aug 18, 2010, 04:56 PM
warthox is offline
Joined Aug 2009
nice maiden flight.. and next video with some rolls and loops please
Old Aug 18, 2010, 05:14 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by Niall View Post
Could this also be the issue that Charl is seeing, or is it more likely clock fuses are messed up?
No, judging from the lenght of the initial flash, it seem like it runs on 1MHz.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 18, 2010, 05:16 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by rcimports View Post
Niall, Kaptein,
I'm unfortunately having EXACTLY the same issues as cvandenb?? I'm using a carona rx and jr tx, I can't get it to "listen"???
Please help,
Dion
It will be fixed in future softwares.
Old Aug 18, 2010, 05:17 PM
Niall is offline
Joined May 2010
Yes this is also my diagnosis. Sounds like CHKDIV8 is checked in the fuse settings. But I thought I had unchecked it when I programmed the chips. So we will see when they come back for surgery.
Old Aug 18, 2010, 05:19 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by alll View Post
For the caps can we resume this?
C1,2,3,4,9,10,11: 100nF ceramic capasitor. no polarization (small caps)
C7: electrolyte or tantalum with a value of 10uF and upwards.
C5,6,8: 0.68uF Tantalum.
manuLRK
Yes, that is the correct capacitors. For the 100nF, I use ceramic multilayer.
Old Aug 18, 2010, 05:21 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by cdi3d View Post
Just finalized my build - Great board KapteinKUK!!!! So Stable - And what a great match with Jakub's frame - Still tweaking settings and added a Fy20a (not that this board really needs it!) Anyway - I am using 11x3.8 cw & ccw props (12x3.8 cut down) - Getting about 9 minutes of flight time on a 3s2200 pack - video later -
Thanks, and congrats with a flying quad
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
