Old Aug 18, 2010, 01:31 PM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by rcimports View Post
Niall, Kaptein,
I'm unfortunately having EXACTLY the same issues as cvandenb?? I'm using a carona rx and jr tx, I can't get it to "listen"???
Please help,
Dion
Hi Dion,
I will be checking Charl's chips when they come back. If it turns out to be a clock problem, I have some more chips in Zimbabwe, and one of my guys will probably be going down south later this week or early next. I will get them to post you a replacement when they get to JHB.
Cheers,
Niall
Niall is offline Find More Posts by Niall
Old Aug 18, 2010, 01:32 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Cool, thanks!
But it is very strange though?? Other people allso hqvw this issue? I can't be the only one using a carona rx.
Cheers
Dion
rcimports is offline Find More Posts by rcimports
Old Aug 18, 2010, 01:35 PM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by cdi3d View Post
Just finalized my build - Great board KapteinKUK!!!! So Stable - And what a great match with Jakub's frame - Still tweaking settings and added a Fy20a (not that this board really needs it!) Anyway - I am using 11x3.8 cw & ccw props (12x3.8 cut down) - Getting about 9 minutes of flight time on a 3s2200 pack - video later -
I'm very curious you opinion about FY-20A.
My own Fy-20A is in duty office
jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Aug 18, 2010, 01:38 PM
Niall is offline
Joined May 2010
Cool, thanks!
Cheers
Dion
I have a Corona RX and a Futaba TX, and it works fine on mine so I suspect an issue with the fuses, but we need to check to make sure. I should know on Friday if the old chips arrive by then.
Cheers,
Niall
I use the Corona RD620II And a Futaba T6X super.
Old Aug 18, 2010, 01:40 PM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by F.O.D View Post
Yes theat is right my tri dont fly more then 5min. My quad wil be 1650 with 4 70g motores. So that vil be 412g / motor. Then i need 650-700g max pr motor.
Alex
Quad 1650g weight is way too heavy!
You can make without problem quad RTF <> 800g.
Do u know any motor for GWS hd0950 3 balde that gives 650-700g??
Yes I know, but this is wrong thread
You should try to make your quad lighter...
Jakub
Site Sponsor
Old Aug 18, 2010, 01:54 PM
coda vex is offline
Find More Posts by coda vex
Kansas, USA
Joined Aug 2010
Originally Posted by Jakub J View Post
How long?
If you want fly longer than a few minutes, and safe
do not excess 350-400g / motor...
Jakub
Jakub-your talking about just motors and not esc's as well correct. I was thinking of using either the Turnigy 2217 20turn 860kv or the BP A2217-9 950kv which comes in at 71 and 73.4 g respectively.
This for a fairly standard quad for my first build. TH v6 kk board - towel bar frame-55cm. Any recommendations or input?
coda vex is offline Find More Posts by coda vex
Old Aug 18, 2010, 02:02 PM
F.O.D is offline
Find More Posts by F.O.D
Joined Feb 2010
Jakub
My quad 1000g. fpv 100g. camra 400g. camera mount 100g. =1600g
Alex
F.O.D is offline Find More Posts by F.O.D
Old Aug 18, 2010, 02:06 PM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Alex
Go 6x, better 8x and try to make construction as light as possible.
J.
Site Sponsor
Old Aug 18, 2010, 02:22 PM
South Africa
Joined Oct 2005
Sorry for getting a bit sidetracked. Can somebody point me in the right direction for info on programming the chip via 6 pin header with a normal ardiuno?
Tx
Dion
Old Aug 18, 2010, 02:29 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Alex
wow realy heavy, can u post a pic?
my quad weights arround 750gr incl. gopro hero hd..
warthox is offline Find More Posts by warthox
Old Aug 18, 2010, 02:31 PM
warthox is offline
Joined Aug 2009
Originally Posted by Niall View Post
Looks good... I will be very interested in seeing how these ST gyros work out. They will knock a third off the build cost for the controller.
93$ ????
i've programmed the board now. no problem. clocktest works.
settings for atmega168: low fuse=E2, high fuse=DF, extented fuse=FF
now i will put it on my quad and maybe do a testflight in my room if everything works
Old Aug 18, 2010, 02:35 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
So Warth
you got the new 3 axises gyro and the board from Spang? that was really fast.
Thanh
thanhTran is offline Find More Posts by thanhTran
Old Aug 18, 2010, 03:22 PM
warthox is offline
Joined Aug 2009
Originally Posted by thanhTran View Post
So Warth
Thanh
yes. it was unbelievable fast. from korea to germany in only 4 days friday - monday
Old Aug 18, 2010, 04:37 PM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
A - 61mm, B - 43mm, C - 27mm, D - 24mm, thickness - 9mm.
HK SS 8-10
A - 35, B - 22.5, C - 18, D - 15.5, thick - 7
HK SS 25-30
A - 58.5, B - 36, C- 23.5, D - 21.5 thick - 9
Turningy Plush 30A
A - 58.5, B - 35.5, C - 26, D - 25, Thick - 12.5
Turnigy Sentry 18A
A - 58.5, B - 36, C - 26, D - 23.5, thick - 10.5
rewolff is offline Find More Posts by rewolff
Old Aug 18, 2010, 04:42 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Originally Posted by Scorpia View Post
Looking at the website, it looks like its being setup as a full shop.
www.multicopter.kr
Does anyone know if the files etc for this version of the board will be available to DIY?
i like the look of the pictures , looks like the frame could be quiet nice.
Also i couldnt see any mention of Rolfe or Kaptainkuk there anywhere
wish i could read what ever language the website is in, theres probably a link there somewhere.
i tried google translate and no mention of kk.....
bob4432 is offline Find More Posts by bob4432
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 12:15 PM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 04:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 08:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 03:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 11:07 AM
