Old Aug 09, 2010, 01:14 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Jim, I haven't actually put a video recorder in the air yet so can't say if the vibe dampeners on the motors really work. I know shame on me. On the other hand the mounts worked well for me under the controller board and did remove some unwanted vibrations.
Originally Posted by jim80 View Post
Do they make a difference?
If so, how much?
I've been meaning to try exactly this for a while, just not got round to it yet
It's always liked a good idea to me.
pug398 is offline Find More Posts by pug398
Old Aug 09, 2010, 01:30 PM
pug398 is offline
VA
Joined Nov 2009
They had a bunch of them in stock here:
http://www.frozencpu.com/cat/l3/g7/c...ews-Page1.html
when I ordered mine but I don't see the exact same ones now so can't guarantee they use the same size mounting hole or that they are as "mushy".
Originally Posted by agressiva View Post
Pug, where you order these HD anti vibration mount ?
Old Aug 09, 2010, 02:42 PM
Klaassie is offline
Find More Posts by Klaassie
The Netherlands
Joined Feb 2010
Does anyone have a picture where I can see how to mount the prop (EPP1045) to the RCTimer 750kV motor? I read about shortening the shaft (with dremel?) and mounting using tiewraps, but I don't understand how to do that...
I really need some help!
Klaassie is offline Find More Posts by Klaassie
Old Aug 09, 2010, 02:53 PM
Lewta is offline
Find More Posts by Lewta
Argentina, San Luis
Joined Feb 2006
Originally Posted by Lewta View Post
Hi: this was a tests weekend, so i started with medium and later moved to high motor timming, but still can hear some clicks while hovering ...no idea how to eliminate them.
Second test, changed to version 4.5 .... Handsfull while trying to lift !!!.
Props out, and tested motors reactions. Yaw gyro had to be reversed, and the beast became a pet again..
Is this normal behavour or something changed without warning??
Arming with stick full right, disarm full left, gyros at 50% and atv kept at A:50%, E:50%, R:100 % .
Nice toy ! Thanks KK, Jakub, and the rest who answer so many questions.
BTW, still wating the cw props!!!
Lewta.
Here is a pic taken yesterday afternoon.
Lewta is offline Find More Posts by Lewta
Old Aug 09, 2010, 03:21 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
The motor closest to the camera looks like it is angled a bit.
Xnaron is offline Find More Posts by Xnaron
Old Aug 09, 2010, 03:30 PM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
I think it's on purpose : all props must be rotating the same direction, so all motors are angled to compensate yaw.
Bob
bob.titus is offline Find More Posts by bob.titus
Old Aug 09, 2010, 05:14 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Okey
As always I got my questions hihi!
Im going to fly in "x" mode and wondering what direction will be the front?
I made a picture from some info I found on the fist side of this forum.
Could some one just tell me out from my picture what color dot that will face the front of the quad in "x" mode?
I hope the picture is right and easy to understand And maby help others
culexus is offline Find More Posts by culexus
Old Aug 09, 2010, 05:19 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Originally Posted by culexus View Post
Okey
http://www.rcgroups.com/forums/showthread.php?t=1288550
bob4432 is offline Find More Posts by bob4432
Old Aug 09, 2010, 06:03 PM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
[QUOTE=culexus;15748611]Okey Could some one just tell me out from my picture what color dot that will face the front of the quad in "x" mode?
QUOTE]
Culexus - which is the front will depend on how the "delta" mix (or "elevon" mix for Futaba) is set up.
Plan on the front being green, and if it it turns out to be red, just reverse the inputs to the delta mix.
Simon
SSM is offline Find More Posts by SSM
Old Aug 09, 2010, 06:44 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Simon
Red is the front with default delta mixing.
For the rest (reversing inputs), I'll let you try and feedback, I personally wouldn't
Bob
Old Aug 09, 2010, 07:02 PM
don_cocinero is offline
Find More Posts by don_cocinero
Tinkerer
don_cocinero's Avatar
Earth
Joined Oct 2005
Okey
That is right Bob. Also, to Quote Bob:
If there is no native "X" mode by software on you quad, to transform it from "+" mode to "X" mode, you just need to use "delta mix" (or "elevons" on Futaba) on your radio, or a delta mixer such as this one if your radio doesn't have delta mix.
It is as simple as that, that's all you need to do, no change at all has to be made on the quad, everything stays the same as for + (flight controller orientation and so on).
Don
don_cocinero is offline Find More Posts by don_cocinero
Old Aug 09, 2010, 07:35 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Don
yep, I wonder where you got that from
Wait until next time I fly to MB Don
Bob
Old Aug 09, 2010, 07:51 PM
Tinkerer
Earth
Joined Oct 2005
I am compiling a book of "Bob" quotes.
promises...promises!
Don
Old Aug 09, 2010, 08:19 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
send me a copy, when you're done
Don
wanna bet?
Bob
Old Aug 09, 2010, 10:16 PM
skye is offline
Find More Posts by skye
Joined Jul 2010
Originally Posted by Klaassie View Post
Yeaaahhhh! : party:
I nearly was getting mad, searching for if there were other words to tell you this!
Thanks skye, for hitting his head!
LOL you guys were actually bringing back a visualization of my mean physics theacher
Now here's another noob question, can anybody gives direction where should I look for basic electrical RC configuration? I'm sure it'll save weight if I can use motor's lipo for rx power but how do I reduce the voltage? Is this set up recommended or risky?
skye is offline Find More Posts by skye
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
