Old Aug 06, 2010, 06:53 PM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
glad you sorted your problem Lewta
One thing about your configuration, your 30A Plush really are overkill for the 20-20L driving a 10" propeller.
You will draw a maximum of 15A per motor with your 3s battery, so even a 12A esc would do the job and a 18A would be on the safe side, but still slightly overkill unless you fly like Warthox
The benefit of using smaller escs : less weight, and weight really matters on a quad!
Clicking noise = wrong timing.
You can set higher or lower timing and see if it solves the problem, it did cure the clicking many times on my setups.
Beware that incorrect timing can result in motors shuting down in flight with an horrible squeeking sound when you are asking too much power too fast (followed by the sound of the quad hitting the ground)!
Bob
Originally Posted by Lewta View Post
Hi:
Many thanks to both of you (Bob & Jesolins). Problem seems to be solved.
I have just finished my first quadrocopter and when testing all 4 motors stopped at once after aprox 1min flight!. Test was not higher than 60 cm!
Change the battery for a just charged one and the left arm motor stopped twice, without damage.
After reading your answers and more about motor timming suggestions ( another issue ) I tested today again . Seems to be solved, no arm going down and no motors stopping during a 5 minutes hover !
Here is what i have
74 cm m2m quadro, fore&aft motors about 6 degrees to the right.
Pulso hk20-20L motors
4 ccw 10 x 3.8 gray APC
Plush 30 A esc
homemade pcb following Jakub info ( and his pcb just received still unpopulated ) quadro 4.2 version.
3s 2100 mAh 25C battery
Settings Nmhxxx, cutoff, medium motor timming.
Motors are making some "click noise", once in a while. Any idea if should be run with high timming ???
Any experience with this specific motors and escīs?
Lewta
bob.titus is offline Find More Posts by bob.titus
Old Aug 06, 2010, 07:11 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by bob.titus View Post
nice video, very relaxing
What about some aggressive flying for a change?
Bob
sorry that i bored you next time i will try to fly in knife edge through the field, only for u
warthox is offline Find More Posts by warthox
Old Aug 06, 2010, 07:55 PM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
yawn... nyeeowww... zzzz ... nyeeowww ... zzzz
Bob
Old Aug 06, 2010, 08:27 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Try doing that in a smaller field
thanhTran is offline Find More Posts by thanhTran
Old Aug 06, 2010, 08:54 PM
Fulg is offline
Find More Posts by Fulg
Fulg's Avatar
Montreal, Canada
Joined Sep 2008
Originally Posted by oeyvindo View Post
I have just completed the v6 PCB. When I connect the power the LED flash once and then it takes exactly 32 sec before it lights steady. The ESC signals no input from the receiver.
Did you test if your Atmega clockspeed is correct with the clocktest firmware first? If it isn't, then you forgot to (or simply didn't) set the fuses correctly.
If that's not it, someone else will have to chime in, because that's as far as I got with my KKcontrollers (still building my quad & tri frames)...
Cheers,
Ben.
Fulg is offline Find More Posts by Fulg
Old Aug 06, 2010, 11:20 PM
spagoziak is offline
Find More Posts by spagoziak
"Let's put a camera on that.."
spagoziak's Avatar
Twin Cities, MN
Joined Feb 2010
You're an incredible pilot, wart.
so here it is. hope u dont throw away your barf-bags after the last video
spagoziak is offline Find More Posts by spagoziak
Old Aug 06, 2010, 11:34 PM
fireslayer26 is offline
Find More Posts by fireslayer26
My Karma ran over my Dogma
fireslayer26's Avatar
United States, FL, Jacksonville
Joined Feb 2010
Please.... he's an amateur at best..... J/K! Great work Warthox!
fireslayer26 is offline Find More Posts by fireslayer26
Old Aug 07, 2010, 12:51 AM
skye is offline
Find More Posts by skye
Joined Jul 2010
Originally Posted by fpv4ever View Post
Maybe because 18-20A are not in stock and for some bucks more ,you get 25A.
My first test was done with towerpro H40 40A because only those in my personal stock... i change with Supersimple 25-30A because half price and good result , i can say that the quadri is more responsive with the same settings.
My motor turnigy 2217 860kv 22A.
I orders 10 days ago some Emax 2822 1200kv , still in transit...
Thanks and what is the purpose for upgrading to higher kv in this case?
I have another question, I plan to build X quadcopter, anybody knows what will happen if I widen the gap between left and right arms? That way I will have more free space to put a camera with wide angle lens.
skye is offline Find More Posts by skye
Old Aug 07, 2010, 02:42 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
why not build a tri then?
bob4432 is offline Find More Posts by bob4432
Old Aug 07, 2010, 03:01 AM
skye is offline
Joined Jul 2010
not comfortable with yaw servo
Old Aug 07, 2010, 03:11 AM
bob4432 is offline
bob4432's Avatar
Joined May 2010
how about y6?
Old Aug 07, 2010, 03:20 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Hello, now I have added MK style arming / disarming to the Quad software. It will be added to the others soon.
Collective down and yaw left for off.
Collective down and yaw right for on.
The LED will show the current status.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Aug 07, 2010, 03:31 AM
bob4432 is offline
bob4432's Avatar
Joined May 2010
thank you
assuming it starts in disabled mode?
Old Aug 07, 2010, 03:35 AM
Quad Whisperer
Joined Jul 2008
Yes
Old Aug 07, 2010, 04:19 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
How about Tri?
Im working now with frame for tri
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
