Old Apr 04, 2010, 03:37 PM
jjbunn is offline
Find More Posts by jjbunn
Joined Apr 2010
Bare bones Tx/Rx ?
Superb thread, Kaptain
For a complete noob like me to anything Radio Control, who doesn't even have a transmitter/receiver, is there a more affordable, entry level, Tx/Rx than the Futaba? Would one of the Hobby King units work, I wonder, e.g.
http://www.hobbyking.com/hobbyking/s...x_%28Mode_1%29
Or, more specifically, will this unit work with your upcoming V4 software?
Thanks!
jjbunn is offline Find More Posts by jjbunn
Old Apr 04, 2010, 04:40 PM
cyborgcnc is offline
Find More Posts by cyborgcnc
The Drones are Coming!!!
cyborgcnc's Avatar
New York, NY
Joined Feb 2010
Man this thing is STABLE!!
Just did about 20 minutes worth of flying, on 3 packs....I can't tell you how well this thing is flying....VERY stable.
Kapteinkuk, if you ever integrate an accelerometer or GPS in your code, this will be the most stable Quad design on rcgroups!
On a 2500 LiPO, 35C pack (Rhino, from hobbyking) I can easily get a 5 ++ minute flight. I land early, cause I do not have an alarm on it yet, and the battery still has about 300-400ma lefts when I charge it again...very happy with the motors, and props so far.
I did some final trimming today with the TX, and I can easily hover this thing almost hands off...obviously, I need to keep on the throttle (but that is why we need GPS!! :-) )
Rolf, again THANK YOU SO MUCH for your code!! You wrote a VERY GOOD set instructions for the Atmel chip, and it is doing an EXCELLENT job at flying my quad!
I will have more video soon for you all....need to convince the wife again to take it!
cyborgcnc is offline Find More Posts by cyborgcnc
Old Apr 04, 2010, 09:19 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
By your first picture it is correct sequence if you have the probes hooked up as
0-aileron
1-elev
2-throt
3-rudd
4-aux
in the second picture if ch1 aileron channel, ch3 throttle channel and ch5 aux channel then it seems correct
Originally Posted by thanhTran View Post
Thanks. I understand how the quad calculate the channels from the 3 odd channels it uses.
I believe the sequence of the channels is correct. At this time I could only look at 5 channels, but they are in sequence. Please see the attached photos for the channels capture. They seem to be in correct sequence, right?
One of the weird things is that with this Eclipse 7 & Spektrum RF & RX set up, when the board is armed, the thing works: so the sequence seems correct because all 4 motors (which I hooked 4 servos to watch) move in response with the TX control. I.e. if you move throttle up, all 4 servos move up, when you move rudder or pitch or roll, some servos move right some servos move left.
-Thanh
pug398 is offline Find More Posts by pug398
Old Apr 04, 2010, 10:13 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Hi Kapteinkuk
I've been watching this thread with great interest. I loved the flying chicken so much and the simplicity of your project that I decided to duplicate your great work.
So I got the PCB done & programmed. However, I got some weird issues with the arming of the controller. I'm using your V3 software in a somewhat modified V3 (i.e I'm using a voltage reference chip instead of the LM317)
My TX is a Hitec Eclipse 7. The actual radio RF module can be replaced by either the stock Specktra module or the modified original Specktrum DX6 TX. With the original Specktra module and an old Berg6 RX, the quad controller is armed immediately no matter what position of the throttle stick, and I can see the servos hooked to the Motor connectors moved with my throttle stick movement. However, when I use the DX6 RF Tx module in my Eclipse 7 and a AR6000 RX, the quad controller just does not arm no matter what throttle stick position is.
Before I built the quad, I've verified that my TX with the Spektrum RF and an AR6000 have sequence channels with a logic analyzer (sump.org with a BusPrivate V2). I've also compared the signals of Ch1, Ch3, Ch5 of both RF module and RX setups, they are basically almost identical down to micro seconds.
During live poking with the logic analyzer, sometimes somehow the controller got armed with this Eclipse7 Spektrum set up, and I got servo movement as expected.
I've checked the signal level of both RX'es, they are both around 3.29v.
I'm running out of idea of what causes this. Any suggestion? I'm thinking about hooking a ttl uart to the PD6 to see what you have for debug there, but I'm thinking about asking the expert first. Any suggestions?
Thanks Kaptein!
-Thanh
Hitec uses the samme channel ordering as Futaba. But Im not sure what the problem is. If you connect a terminal to PD6 and enable the debug code you can get the channels as seen by the atmega.
Also you can try the new V4.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Apr 04, 2010, 10:15 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by dd016857 View Post
Kapteinkuk ,...just an idea..... While you are busy writing a new version of the software I wish to know if an accelerometer can be incoperated in the existing design? Would it improve hovering perhaps?
As others have stated too, I am very appreciative in your design and effort presented here.
Rolf...thank you very much.
This controller will be as is. But maybe I will make a new controller with all the gadgets. Time will show
Old Apr 04, 2010, 10:18 PM
Quad Whisperer
Joined Jul 2008
Thanks!
Any reciever will work with the V4
Old Apr 04, 2010, 10:20 PM
Quad Whisperer
Joined Jul 2008
Thank you very much!
This controller will stay as is. Maybe one day a new controller with all the gadgets!
Old Apr 04, 2010, 10:40 PM
Quad Whisperer
Joined Jul 2008
I think I have busted a few brain cells, but here is the new V4
The good news:
- Works with any 4 channel or more reciever. Any channel order.
- Higher control loop frequency, 160Hz, much more stable.
One drawback is hardware changes:
- Reciever connect to different pins than V3. It had to be done to use the external interrupts.
- Had to add 3 capacitors to act as gyro filters. (forming a RC filter with the 6800 Ohm resistor on the gyro boards) My software filter did not perform good enough due to slow hardware.
I tested it on my smallest quad, which was a bit unstable. Now I could double the gain without oscillations and it is rock stable!
Video will follow.
Old Apr 05, 2010, 12:28 AM
pug398 is offline
VA
Joined Nov 2009
Excellent once again.
And the hardware changes are minor to what I was expecting. Now the students will be able to use a cheap radio and keep their hands off my good one.
Old Apr 05, 2010, 01:12 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
0-aileron
1-elev
2-throt
3-rudd
4-aux
Thanks Pug!
Yes, that was how I hooked the logic analyzer to the receiver. I
thanhTran is offline Find More Posts by thanhTran
Old Apr 05, 2010, 01:22 AM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Here is what the debug says when I un-commented the "rcall ShowChannels"
With Berg6 RX: 0005 0013 0003 0017 0035
With spektrum: 000B 0019 0006 0019 0037
They look almost identical. The reading of channel 3 varies from 0003+ - 005C+ for both receivers when I move the throttle stick. I'm trying to debug the code with AVRStudio. Sometimes, during single stepping, the board armed correctly. I'm not familiar with AVR assembly. Not just assembly alone, your math library is so advance to me, and I just couldn't figure out some of the codes there
ldi t,high(int(@1+0x8000)-0x8000)
ldi t,high(int(frac(@1)*0x10000+0x10000)-0x10000)
Apart from thinking you are trying to get the integer and fraction part of the numbers, what do they actually do? What do we get when we add the second param (says, 20, or 100) to 0x8000 and then substract with 0x8000? And why 8000 and 10000?
anyway, I'm going to try out your V4. Thanks very much
-Thanh
Old Apr 05, 2010, 01:50 AM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
great job kapteinkuk
thanks alot
v4 is working with my Tx/Rx, slight trim is required , when i increase the throttle m1 starts first , i think i need to decrease the yaw gain .. soon i will put video of the flight
quaddynamics is offline Find More Posts by quaddynamics
Old Apr 05, 2010, 02:28 AM
Joined Mar 2010
when i give the throttle m1 and m4 starts first and m3 last by m2 , i tried the trick gave by cyborgcnc i couldn't make it right please guide me the tuning in detail
2204 brushless outrunner
10A esc (not programmable)
Old Apr 05, 2010, 02:38 AM
lowie is offline
Find More Posts by lowie
Joined Mar 2010
My gui for avrdude programmer still gives an error:
clocktest : 1 unrecognized caracter: ":"
WHAT MUST I DO?
Thanks Lowie
lowie is offline Find More Posts by lowie
Old Apr 05, 2010, 04:51 AM
zotfidjy is offline
Find More Posts by zotfidjy
Ourense, Spain
Joined Nov 2005
Thanks a lot kaptainkuk for the V4, now it can be used for all the people.
Thanks a lot for your job.
zotfidjy is offline Find More Posts by zotfidjy
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
