Old Jul 06, 2010, 08:09 AM
OpticalFlow is offline
Find More Posts by OpticalFlow
Brisbane, Australia
Joined Mar 2010
Originally Posted by OpticalFlow View Post
Just a quick question: I have ordered pretty much all the parts to build the controller board on perf board - except for the LM317. I have a 7805 voltage regulator lying around, is there any reason (such as interference) that I couldn't use that instead of the LM317. Another alternative I have lying around is a 5V Ubec.
nevermind, I just figured out that the LM317 isn't configured to have 5V output
OpticalFlow is offline Find More Posts by OpticalFlow
Old Jul 06, 2010, 09:52 AM
cyhyam is offline
Find More Posts by cyhyam
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
Originally Posted by thanhTran View Post
Do you have screen shot of the programmer software that you use? (press ALT-PrntScrn after you high light Programmer window and paste that picture out in paint program). Or link to it?
EEprom usually stores variables, settings, and not the program itself. It's not big enough to store the flight controller program either. Even if a program fit in it, the ATMEL won't load the code from EEPROM to run. The program (like clock test or the flight controller) is supposed to go to flash
thanhTran,
Thanks for looking at this, I am trying to put off buying a $34.00 programmer if it is absolutely necessary.
Name: fuse calcs.jpg
Description: Name: extremeburner ss1.jpg
Description: Name: extremeburner ss2.jpg
Description: Name: extremeburner ss3.jpg
Description: Name: extremeburner ss4.jpg
Description: Name: extremeburner ss5.jpg
Description: Name: extremeburner ss6.jpg
Description:
Here are the screen shots, if you need more let me know.
cyhyam is offline Find More Posts by cyhyam
Old Jul 06, 2010, 10:02 AM
Klaassie is offline
Find More Posts by Klaassie
The Netherlands
Joined Feb 2010
Are the EMAX2822 the same as the FC28-22 from Hobbyking?
http://www.hobbycity.com/hobbyking/s...idproduct=5354
The specs look identical.
Originally Posted by Jakub J View Post
Hi
Yesterday I was measure my new motor - RC-Timer 750KV:
http://www.rctimer.com/index.php?app=goods&spec_id=145
Results - almost no vibrations, very nice looking ,
high overal build quality, and high eficiency - little lower
than Turnigy 2213 but much higher than EMAX 2822.
I was found my new motors
Unfortunatelly I have only one and will wait 3 weeks for more
I will prepare all my new frames for this motors (Emax 2822 too).
Jakub
Klaassie is offline Find More Posts by Klaassie
Old Jul 06, 2010, 10:03 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
I think so.
J.
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Jul 06, 2010, 11:07 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
OK guys,
I have added some new and exciting functionality to the website. www.kkmulticopter.com
For new users, you can add information on your multicopter from the registration page. This includes things like multicopter version, firmware, AUW, maxumum payload, maximum flight time etc.
For existing users you just login, click on "member profile" in the user menu on the left, click on Edit /Update profile, and then just add all your info.
There is also a members video and photo gallery where you can upload some pics of your multicopter, FPV videos, Aerial photography etc.
Once uploaded, the videos and photos are linked to your multicopter profile for others to see.
Please report back any bugs you come across, or additions and changes you can think of.
Niall is offline Find More Posts by Niall
Old Jul 06, 2010, 12:17 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by cyhyam View Post
thanhTran,
Attachment 3343706 Attachment 3343678 Attachment 3343662 Attachment 3343663 Attachment 3343664 Attachment 3343665 Attachment 3343666
Thanks for those screen shots Cyhyam! That's too many but is really useful . I assume the first screen shot was just a sample and not the actual settings you chose (because I see the clkdiv8 bit set).
Could you please try this:
1. Erasing the chip by clicking on the button with the yellow asterisk
2. Go to the "Fuse bits/settings" tab, Click on the "Read all" to see what kind of fuse your chip is currently has. Please give us a screen shot of the result if possible.
3. Still in this tab, type in the values you calculated, and check on the box that has low, high, extend. Don't check the boxes that write "lock fuse" and "calibration". And then click "Write". I assume this will write the fuse only. If not then click on "Write", and then "Write fuse bits and lock bits".
4. If the fuses are written at step 3 above, then go ahead load the clock test (how did you compile that?) And then click on "Write", "Write Flash" like you did earlier.
5. If the program still reports error, please exit it, and then rerun it, and click on the "read all", and please show us the screen shots of the "Flash" and "Fuse bits/Settings" tabs.
Please let us know how it goes
-Thanh
ps. I suspected that you didn't actually write the fuse bits and settings, and thus the programs probably has some problem reading it back
thanhTran is offline Find More Posts by thanhTran
Old Jul 06, 2010, 01:37 PM
Yorbid is offline
Find More Posts by Yorbid
United States, NV, Carson City
Joined Apr 2008
cyhyam,
Your screen captures are copies of my experience. I have banged around with so many pieces of software with no luck I am not sure which way is up anymore. However, I did manage to read the Lock Bits (I think,) and this may be our problem.
The first line says it all. If this is true, then how do we unlock the darn thing, or, is it simpler to buy a new chip?
BTW, this is from Khazama AVR Programmer.exe.
Yorbid
Yorbid is offline Find More Posts by Yorbid
Old Jul 06, 2010, 03:02 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Originally Posted by Niall View Post
OK guys,
hey niall,
u've done a great job! i've already added my pics and video
markus
warthox is offline Find More Posts by warthox
Old Jul 06, 2010, 03:52 PM
Niall is offline
Joined May 2010
Originally Posted by warthox View Post
hey niall,
markus
Thanks Markus,
Your Tri video was really good. Nice to see some content there.
Cheers,
Niall
Old Jul 06, 2010, 04:35 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
I am too old for command line also. After you get WinAvr set up (avrdude) you then extract the avrdude-GUI folder into the WinAvr folder. avrdude-GUI is the user friendly interface. You have to make sure you have netframework2.0 and usb libraries installed for it to work. They are listed in the readme file of avrdude-GUI. Something else to try before buying another programmer. With your lockbits set to FF I don't think you have locked the chip. avrdude-GUI is here on rcgroups.
link to avrdude-gui
http://www.rcgroups.com/forums/attac...mentid=2484012
http://www.rcgroups.com/forums/attac...mentid=2484011
When I used the fuse calculator;
http://www.engbedded.com/cgi-bin/fcx...&V_EXTENDED=FF
I first took the default values and “divide clock by 8” was checked giving me the low-62, when I unchecked it then low was E2.
I looked at AVRDude software but it is command line and I haven’t messed with that since I had a TRS80, I need something more user friendly.
I think the extreme burner could do it if I got the right settings. It reads the chip, sets the fuses, all with no glitches. Only when I try to load the clock program it has a problem.
pug398 is offline Find More Posts by pug398
Old Jul 06, 2010, 05:11 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Hello
I ordered today some equipment for three quad's I'm going to setup for me and my friends.
My setup so far is Jakub J frames (foldable) and his quad control board.
The engine and esc ordered from hobby king.
12 pcs off the TowerPro 9g w12A Brushless Speed Controller
12 pcs off the FC 28-22 Brushless Outrunner 1200kv
So my question is what props I use for this setup?
Someone who has the same setup and that can come with tips?
I got tips from Jakub to use these esc but are they really big enough?
Should I preferred a bigger esc?
Sorry for all the questions but it is a bit baffling to me hehe.
culexus is offline Find More Posts by culexus
Old Jul 06, 2010, 05:15 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Originally Posted by culexus View Post
Hello
i think jakub uses the emax 2822 which is pretty much the same motor as you ordered and i think the same escs - ask him what he uses as he seems to have a good rep and his stuff looks top notch. whatever he says i would go w/.
his setup may be my 2nd quad
bob4432 is offline Find More Posts by bob4432
Old Jul 06, 2010, 11:44 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
I have them on mine. They are quite nice & very smooth, almost no vibration, but they are a bit fragile I think. So buy some spare. In some hard landing that my quad experienced the motor and the base were separated. The thread of the stator was stripped (too fine threads). I tried to glue back with green loctile, but I'm not so confident until I got some spare coming in.
Thank you. Good to know that the base and motor have fine threads. I will have to figure out a mounting system for the motor to not break if I crash.
DarkHeli is offline Find More Posts by DarkHeli
Old Jul 07, 2010, 01:47 AM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
That's not all. It is also used to get much more noise-free voltage reference than an UBEC would be able to provide. (because those are usually "switching").
rewolff is offline Find More Posts by rewolff
Old Jul 07, 2010, 01:51 AM
cyhyam is offline
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
I want to give a BIG THANKS to thanhTran, I talked to him on the phone today and many times through email, he was very very helpful discovering some things I had overlooked.
When I loaded the clocktest.hex file into the program the codes showed up in line 000000 – 000030. When I tried to load it to the chip, even though it failed the load, it showed up in line 000080 – 0000B0. We are not sure why it skipped several lines before writing, maybe something in the fuses, don’t know.
Anyway I tried to load the TricopterV1_2M168_M328.hex and it exhibited the same start offset, (lines skipped before writing).
At this point I tried to read the chip and got errors, (power on failed). The chip is still getting 4.9 volts on pin 4 so something else is wrong.
I have a AVR INSystem mkII ordered and it will be here Thursday and I think I will put things on hold until then.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
