Old Jul 01, 2010, 03:07 AM
MarcAntonio is offline
Find More Posts by MarcAntonio
Speed Nut
Joined Jan 2010
Hello KapteinKUK,
congrats for the great developements. I have ordered a couple boards to test out your controller. I was wondering if you foresee to implement auto-leveling ability in the near future....
Thanks again for your help.
MarcAntonio is offline Find More Posts by MarcAntonio
Old Jul 01, 2010, 03:59 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Originally Posted by MarcAntonio View Post
Hello KapteinKUK,
Hi MarcAntonio,
Auto-leveling is very difficult to implement using only gyros but appears to not be completely impossible. From what I've heard the TT-Copter V1 board manages to mostly self-level using only gyros and I think the Gaui 330X also does the same without accelerometers, but am not certain. I suspect both require code to detect neutral stick positions and call an elaborate algorithm to pull off the feat, so code space and processor speed may limit it from becoming a possibility on the 8MHz 4K Atmega PIC the KK controller is based on. I also believe that the great success of KapteinKUK's project is due in no small part to the simplicity and inherent stability of the design.
I don't believe either the TT-Copter or Gaui 330X can toggle between heading hold and auto-leveling modes dynamically; without landing first and being reprogrammed to do so. I feel that being able to toggle between HH and self-leveling modes on the fly (literally) is the best of both worlds and only accomplished via accellerometers+gyros, so I'll be upgrading my KK quad copter with an FY-20A. It uses 3 gyros and 3 accellerometers that are able to track poistion at 1200/sec. I'm hopeful it will add a very stable auto-leveling feature, but wouldn't be surprised if was also was able bring the copter out of an uncontrolled spin (given enough altitude). Will post videos and results when I receive and install the stabilizer.
patricklupo is offline Find More Posts by patricklupo
Old Jul 01, 2010, 04:16 AM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
... because it is the flight controller board that will be de-coupled from the frame's vibrations using gell pads or grommets.
Bob
Originally Posted by ergocentric View Post
Most heli gyros suggest foam double sided tape for mounting, why the hot glue?
kuk! kuk rules!
pretty please post the gyro code for my curiosity
eric.
bob.titus is offline Find More Posts by bob.titus
Old Jul 01, 2010, 04:29 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Hello KapteinKUK,
Full autoleveling requires accerellometers, insanely low drift gyros or horizon sensing, so it is not possible with this controller. However, a new design might appear in the future
A basic auto leveling occurs in a normal well trimmed multicopter. My multicopters sit still for many minutes in still air. Also it recovers from moderate speed when letting go of the stick.
This is due to aerodynamic forces, not the controller:
1: The multicopter pitches agains the direction of travel because the front propellers get still, clean air and the back propellers gets downward moving air, giving less lift and a up pitching moment.
2: Center of gravity is below center of lift, giving roll or pitch moment if not level.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jul 01, 2010, 04:55 AM
Speed Nut
Joined Jan 2010
That is very good news...
Of course the stability and simplicity are the most important features and it's what you have achieved judging from the happy users around the world.
Autoleveling would be nice to have for FPV and far away flying. FPV can be done without autolevelling, but flying far, non FPV, would benefit from the autoleveling features.
It funny that when I am flying my tricopter, a lot of people (non rc people) say, what happened? it's not able to climb up high? It doesn't have the power to "make" it?
it's a pain having to explain that if it goes up more than 100 feet, or 30 meters, it gets near impossible to keep orientation.
I am still using gyros only, so I am looking forward to the upgrade using your board.
What kind of real improvements are in the code, compared to 4 gyro operation?
Is it a faster response time of the Gyros?
I am just curious and impatient not in this particular order
Old Jul 01, 2010, 04:58 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
stable "autoleveling" tri
Originally Posted by kapteinkuk View Post
If the goal is to have a stable "autoleveling" tri, what are the mechanical points to pay attention to:
1) pitching the motors, how? (to the out/in-side,...?)
2) distance from center of lift far above the center of gravity of the tri...
3)...
ManuLRK
alll is offline Find More Posts by alll
Old Jul 01, 2010, 06:52 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
@ Kaptein.
I just love kitchencounter tech, and will try your reflow method when I get into the workshop again next week.
@ the GoproHD owners:
Which package of GoPro HD did you buy? Motorsports, Surf, Kite or Naked?
Can someone with a GoproHD post some closeups pics and some measurements of the dimensions with the waterprood housing, so that I can start to design a gimbal for it?
Jussi
JussiH is offline Find More Posts by JussiH
Old Jul 01, 2010, 07:26 AM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
Someone still should try my idea.... (which so far nobody knows about but me)... but here goes...
To answer your question: no tilting the motors doesn't help.
Someone should build a quadcopter, that has a very light frame, and the COG hanging about 1x to 2x the motor-to-motor distance below the props. The COG ends up being mainly the battery. And the frame would only need to keep the motors apart and right-side-up, but nothing else. The reciever, mixer, and batteries would go "in a basket" hanging from the four motors....
Now instead of stabilizing gyros, you only need a quad mixer. Stability comes from basic physics.... The Kapteinkuk boards have all the hardware, just leave the gyros unconnected, and take the gyro part out of the source code..... (I flew my quad with the HK gyros intact simply inserted into the roll and pitch lines from the reciever My AVR board just functioning as a mixer).
rewolff is offline Find More Posts by rewolff
Old Jul 01, 2010, 08:45 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
Jussi
hi
i use the nacked package. and i dont use the waterproof case. not on my single wings and not on my kk tricopter. its too much added weight. i mount the cam with some tape or velcro.
if u want to mount the gopro in a case for better exchange, i would make an lighter case and dont use this waterproof case because of the weight..
markus
warthox is offline Find More Posts by warthox
Old Jul 01, 2010, 10:14 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by warthox View Post
hi
markus
Thanks, Markus
How much does the GoPro weigh without the waterproof housing?
But weight is not a big issue, as my quad easily can fly a 1000 gram payload (Was built for 450 gram camera and 150 grams gimbal. The Hexa I am working on will lift even more...
My tricopter can fly a 500 gram payload - no problem.
But of course, less weight means longer flighttime, and I am all for that.
Jussi
Old Jul 01, 2010, 12:13 PM
critters is offline
Find More Posts by critters
SF Bay Area
Joined Jun 2007
Great demo of the soldering and really helpful shots of the finished board KK.
Thanks so much for all you do!
critters is offline Find More Posts by critters
Old Jul 01, 2010, 01:01 PM
darek53 is offline
Find More Posts by darek53
POLAND
Joined May 2010
I tried gyros LPY550AL
They work very well.
They are cheaper than HK401B and need only two.
darek53 is offline Find More Posts by darek53
Old Jul 01, 2010, 01:34 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
These are very interesting, and cheap!
About $6.80 each at mouser:
http://www.mouser.com/ProductDetail/...B6STbivpPw0%3D
This means the gyros are about 1/3 the cost of pulling them out of HK gyros.
Anyone know about the relative sensitivity? The interesting thing is that with a little thought you get redundancy on one orientation with the fourth gyro, so you could average the response of the two gyros, on maybe the pitch axis? Whichever one you'd like the most sensitivity on. Maybe the yaw to keep it moving in the same direction.
Edit: Actually, if they are mounted flat on the board, you get redundancy in yaw automatically. It just has to be hardware/software configured.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Jul 01, 2010, 01:59 PM
IWCoburg is offline
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Will one of these be fine for programming the boards?
http://cgi.ebay.co.uk/USB-ISP-Progra.../250656613474?
Reason for asking is it has the 6 pin header in place of the 10 pin of the USB ISP Programmer for ATMEL AVR ( 51 ATMega ATTiny ) suggested on the site which comes with a 10 pin header, which is a s*d as the nice v4 and V6boards come with 6 pin headers.
TIA, Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old Jul 01, 2010, 02:11 PM
corbystarlet is offline
Find More Posts by corbystarlet
Portugal, Beja, Beja
Joined Jun 2010
Originally Posted by iwcoburg View Post
will one of these be fine for programming the boards?
http://cgi.ebay.co.uk/usb-isp-progra.../250656613474?
reason for asking is it has the 6 pin header in place of the 10 pin of the usb isp programmer for atmel avr ( 51 atmega attiny ) suggested on the site which comes with a 10 pin header, which is a s*d as the nice v4 and v6boards come with 6 pin headers.
Tia, mike.
i have one of this,works good.
corbystarlet is offline Find More Posts by corbystarlet
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
