Old Jun 30, 2010, 08:38 AM
zotfidjy is offline
Find More Posts by zotfidjy
Ourense, Spain
Joined Nov 2005
Originally Posted by jbfoamy View Post
Zotfidjy,
What is the measurement from motor to motor? Your quad looks great! But, it seems bigger than most.
Hi Jbfoamy, the Quad have 76cm motor 2 motor. Today the quad is "only" 50cm. motor 2 motor.
Im happy with the shorter version, is light, reacts fast and strong to sticks. 76 cm. quad is better for learning.
The complete quad without lipo today weights 800gr. Im try to get a 750gr Quad. (when i made it it weights 950gr, not bad)
Telmo
zotfidjy is offline Find More Posts by zotfidjy
Old Jun 30, 2010, 08:45 AM
zotfidjy is offline
Ourense, Spain
Joined Nov 2005
Originally Posted by DarkHeli View Post
I have been using extreme burner so far... Noticed the lack of a lot of options.. What programmer do you pick when using AVR Studio 4? I have the USBASP one and it is not in the options.
Hi, i have several problems with comercial avr programmers, i cant program the atmega.
But I follow the step by step made by 402RcPilot's:
http://www.rcgroups.com/forums/showa...0&d=1274217816 , I made the programer and it works.
I think i waste my money in those programmers, and with less than 5€ the ponyprog makes the job.
(Thanks 402RcPilot's )
Telmo
Last edited by zotfidjy; Jun 30, 2010 at 09:32 AM. Reason: Change step to step autor
Old Jun 30, 2010, 08:56 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Aah I do not have USBASP. I have been using the AVRISP500 and AVRISP mkII.
http://www.avrfreaks.net/index.php?n...topic&p=489155
This thread may be of interest however.
Niall is offline Find More Posts by Niall
Old Jun 30, 2010, 08:59 AM
Niall is offline
Joined May 2010
But I follow the step by step made by Niall:
I think i waste my money in those programmers, and with less than 5 the ponyprog makes the job.
(Thanks Niall )
Telmo
Aaah I think that is 402RcPilot's instruction manual. He is very good at that kind of thing.
Old Jun 30, 2010, 09:30 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
My assembly of the V5 SMD PCB:
-Solder a bit of solder onto the pads. For the small chip pads, add flux to the pads, add a bit solder to the tip and then run it over the pads. Then add flux to all the pads.
-Add all the components to the pads. Aligment is not critical, but you may do it better than I did
-Move to the kitchen. Here I placed the PCB on a 2mm aluminum plate and put a glass lid over it. Then I turned on the cooking plate to about half power.
After about 10 minutes I turned up the heat and soon the solder melted. 10 minutes may be too long time, but I wanted to avoid grilling the PCB. As soon as all the solder had melted, I moved the aluminum plate off the cooking plate. The IR thermometer was reading 190 degree celcius. Not to hot I think. After cooling carefully inspect the PCB. A few of the legs of the Atmega chip was not soldered. It was fixed with a very small tip and a microscope. Next time I am going to try to add a small weight ontop of the chip to make all the legs come in contact with the solder.
Kitchen SMD reflow soldering (1 min 53 sec)
-Solder on the TH components.
-Attatching the gyros.
Put the gyro onto the PCB and then put hotglue in between the two PCB's
Finished!
Note: If you have used a ATmega88 from the silver gyrd, you have to provide a extenal clock signal until you have programmed the correct clock fuses. I used
a 100kHz signal from a signal generator applied to pin 9. It will light up the led I used an ISP frequency of 6kHz.
The chip on both the gyrds where not locked, so I downloaded the program from it. Later I am going to nerd through the code and see how it works.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 30, 2010, 10:07 AM
cyhyam is offline
Find More Posts by cyhyam
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
Kapteinkuk,
Thank you, this is perfect, it will be very helpfull, my components should be here any day.
cyhyam is offline Find More Posts by cyhyam
Old Jun 30, 2010, 10:08 AM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
Now that is what I call thinking out of the box. Or on top of the stove.
I had seen some of the videos showing re-flow soldering but with solder paste and in a toaster oven and had dismissed them because of the problem of getting the solder paste(Needs to be kept refridgerated). But this puts a whole new light on the situation.
To hold SMD parts in place while soldering. Take a piece of single strand copper household wiring about 150 mm long. Bend the last 10/20 mm on each end up 90 degrees. Take another piece of the same wire and twist one end around the middle of the first wire so that the second wire ends up at an angle about 10 or 20 degrees to the first wire. Like a "Y" with a narrow "V". Make the ends of the first wire point up and put a bend on the end of the second wire so it matches length of the other arms of the "Y". Turn it over so the ends are all pointing down. The single end/bottom of the "Y" will sit on top of the SMD part and hold it in place while the other ends will stop the "device" from falling over while you solder. Adjust sizes/angles and weights to suit. You can solder the join. Or not.
Thank you KK.
Bill
SupraGo is offline Find More Posts by SupraGo
Old Jun 30, 2010, 02:45 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
Okay, we may be getting somewhere...
I plugged in my bec to RX OUT ports, and I get a green light, but it doesn't turn off. Voltage at the chip reads about 2 Volts. If I plug the bec into the ESC/motor out ports, I get no power to the chip and no light.
Perhaps I have a jumper wire not fully soldered, and not supplying power to the other half of board?
DarkHeli is offline Find More Posts by DarkHeli
Old Jun 30, 2010, 03:00 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
http://www.youtube.com/watch?v=FD-PQ85bGJQ
Finished!
very nice. just out of curiosity, what is the reason for putting the glass over the board as it cooks? it is for keeping in the heat or for safety?
bob4432 is offline Find More Posts by bob4432
Old Jun 30, 2010, 04:21 PM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
Most heli gyros suggest foam double sided tape for mounting, why the hot glue?
kuk! kuk rules!
pretty please post the gyro code for my curiosity
eric.
ergocentric is offline Find More Posts by ergocentric
Old Jun 30, 2010, 04:31 PM
km28104 is offline
Find More Posts by km28104
km28104's Avatar
Indian Trail, NC
Joined Oct 2009
Bob,
I suspect it's to localize the heat and make a mini oven.
Ken
km28104 is offline Find More Posts by km28104
Old Jun 30, 2010, 04:32 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
kuk! kuk rules!
eric.
i believe it has been mentioned to mount the whole controller in a cushioned fashion to isolate all the gyros at once.
Old Jun 30, 2010, 04:58 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by km28104 View Post
Bob,
Ken
yep
Old Jun 30, 2010, 05:00 PM
Quad Whisperer
Joined Jul 2008
Correct. This gives a larger mass, and thus easier to isolate from vibrations.
Old Jun 30, 2010, 05:06 PM
Quad Whisperer
Joined Jul 2008
you have to check it out completely
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
