Old Jun 29, 2010, 01:18 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by Jakub J View Post
You have free subscription
And noooow T-rex on steroids
Motor 2 motor 44cm.
Total weight with LiPo holder, legs, screws etc - 210g.
Jakub
That looks awesome Jakub! You change the arm a bit and flip it huh?
If the battery could be in the middle of the two plates it would be better. I'm always worried about hard landing that would destroy battery. Plus the legs are bent easily, so there is no protection for battery there. ALso, someone may be interested in doing AP, and thus they have to hang the camera in the bottom, with a battery there, it might be hard to put in the camera holder / hanger
Just some of my 2 cents thought
-Thanh
-Thanh
thanhTran is offline Find More Posts by thanhTran
Old Jun 29, 2010, 01:55 PM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
-Thanh
-Thanh
This frame is too small for serious AP I think.
Flying FPV with small camera and video TX will be no problem.
I have bigger frame "in pipeline" for AP, but six or octo...
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Jun 29, 2010, 04:34 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
Re-did the pcb... Now the light does not even work when clocktest.hex is loaded....This time however, nothing is hot or smoking
Any ideas?
DarkHeli is offline Find More Posts by DarkHeli
Old Jun 29, 2010, 05:13 PM
Scorpia is offline
Find More Posts by Scorpia
Australia, VIC, Narre Warren
Joined Apr 2010
opps , ignore
Scorpia is offline Find More Posts by Scorpia
Old Jun 29, 2010, 05:49 PM
zotfidjy is offline
Find More Posts by zotfidjy
Ourense, Spain
Joined Nov 2005
This version no - it is ugly
I have version 2 - will show today probably.
I have an idea to make a few this frames and sell with
looow price for persons who want to test this kind of frame.
(Somebody interested?)
I'm curious your opinions about material - it is "Alubond"
- composite material 0.3mm aluminium + 1.6mm PE + 0.3mm Al.
It is diferent than G10 or carbon, but I like it.
Finaly I'll make this king frame using G10 too.
Jakub
Jakub, I want to test one of yours frames. Thanks
zotfidjy is offline Find More Posts by zotfidjy
Old Jun 29, 2010, 06:19 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Measure voltages across the atmel chip Vcc and GND to see if you have anything correct (near 5v) there. Make sure the LED is still working
when you reprogram the chip, does it do verify the flash content?
If you have a check on the clk/8, it might take a long time before the LED lights up or turns off.
Old Jun 29, 2010, 06:46 PM
zotfidjy is offline
Ourense, Spain
Joined Nov 2005
Hi, last weekend i fly FPV with the Quad.
Setup:
Camera: Fpv530Hd with osd
Tx: lawmate 500mw
Bat: 2s 800mah.
Videos are uploading now.
This is the Setup, only 4 screws to go Fpv or 3 view.
Telmo
Old Jun 29, 2010, 07:28 PM
zotfidjy is offline
Ourense, Spain
Joined Nov 2005
Fpv Videos:
Pruebas Video Fpv Cuadricoptero zotfidjy (4 min 37 sec)
Segundo vuelo Fpv Quadricoptero zotfidjy (2 min 3 sec)
Youtube....
Last edited by zotfidjy; Jun 30, 2010 at 04:58 AM. Reason: Change videos at Youtube.
Old Jun 30, 2010, 12:48 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by zotfidjy View Post
Vimeo sucks, YT if much faster and better quality now
Jakub
Site Sponsor
Old Jun 30, 2010, 01:28 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Jakub
have to agree w/ you jakub, never uploaded videos myself to vimeo, but can't figure out the draw it has. youtube, you put up a video and it is ready in 10min or so for the low quality, these videos that zotfidjy put have said "in line" for 6+hrs...
bob4432 is offline Find More Posts by bob4432
Old Jun 30, 2010, 03:13 AM
IWCoburg is offline
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
Originally Posted by Jaguar_5 View Post
Just switched my tricopter from seperate gyros to this controller, and WOW, what a difference! I was wasting my time with the separate gyros. SNIP Wish the tail was heading hold, not rate mode, I think I'll throw the HK401 back on there for yaw.
Just spend a few minutes to set the tail up, just liek you would on a CP heli. A simple frame to loosly hold the ri, but enough to let it fly, and get the revs up and adjust the mechanical centre so the tail stays where you put it. You don't realkly need HH.
Just my 2c, Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old Jun 30, 2010, 03:22 AM
dd016857 is offline
Find More Posts by dd016857
barkingside
Joined Mar 2008
Any ideas?
Hi all
Is there anyway the clk test can be done without the KK board. Can a led be placed on certain ic pins and IC powered up on a breadboard or proto board for example.
dd016857 is offline Find More Posts by dd016857
Old Jun 30, 2010, 03:32 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
Originally Posted by dd016857 View Post
Hi all
You should be able to check the clock if you hook up the chip to your programmer and read the settings with AVR studio 4.
Just connect the appropriate pins from the chip on the right below to the corresponding sockets on the programmer. You may also need to put some power into the board depending upon your setup.
Niall is offline Find More Posts by Niall
Old Jun 30, 2010, 06:05 AM
jbfoamy is offline
Find More Posts by jbfoamy
Cleveland, Ohio
Joined Jan 2006
Setup:
Tx: lawmate 500mw
Bat: 2s 800mah.
Telmo
Zotfidjy,
What is the measurement from motor to motor? Your quad looks great! But, it seems bigger than most.
jbfoamy is offline Find More Posts by jbfoamy
Old Jun 30, 2010, 08:31 AM
DarkHeli is offline
DarkHeli's Avatar
NY
Joined Jul 2008
I have been using extreme burner so far... Noticed the lack of a lot of options.. What programmer do you pick when using AVR Studio 4? I have the USBASP one and it is not in the options.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
