Old Jun 29, 2010, 08:30 AM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
hahahaha, I figured out what was wrong...
I soldered up the dip socket reversed, where pin one is supposed to be, its at pin 15 and so forth... Oh well, time to get the desoldering braid hot. At least the chip still works.
DarkHeli is offline Find More Posts by DarkHeli
Old Jun 29, 2010, 08:38 AM
Scorpia is offline
Find More Posts by Scorpia
Australia, VIC, Narre Warren
Joined Apr 2010
If its only the socket thats wrong, just turn the chip around and it should be good.
I wouldnt bother trying to unsolder a socket just to get the pin 1 in the right spot.
or did you put it on the wrong side of the board?
Scorpia is offline Find More Posts by Scorpia
Old Jun 29, 2010, 09:03 AM
DarkHeli is offline
DarkHeli's Avatar
NY
Joined Jul 2008
Basically wrong side of the board, to fix it, I would have to put the socket on the reverse side of the board, where the solder connections are...
Old Jun 29, 2010, 09:11 AM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
Wow. It surprises me again and again what mistreatment these chips will take. A 1A current limit on the power supply will save an Atmel CPU if you plug it in backwards.... Ok. Nice to know. :-)
Glad you can see the humor in this. :-)
rewolff is offline Find More Posts by rewolff
Old Jun 29, 2010, 09:12 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by Jakub J View Post
But I dont told "no" CF - maybe will try it. But first FR4/G10.
there is nothing like aluminum
he always comes down
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Jun 29, 2010, 09:17 AM
Niall is offline
Find More Posts by Niall
Joined May 2010
I fried some chips over the weekend due to having the wrong polarity. A very basic mistake but still I didn't spot it till it was too late. 4.1v battery box powering my target board killed my Atmegas
Anyway, I know better for next time.
Niall is offline Find More Posts by Niall
Old Jun 29, 2010, 10:06 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
This version no - it is ugly
I have version 2 - will show today probably.
I have an idea to make a few this frames and sell with
looow price for persons who want to test this kind of frame.
(Somebody interested?)
I'm curious your opinions about material - it is "Alubond"
- composite material 0.3mm aluminium + 1.6mm PE + 0.3mm Al.
It is diferent than G10 or carbon, but I like it.
Finaly I'll make this king frame using G10 too.
Jakub
I am interested
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jun 29, 2010, 10:24 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Originally Posted by kapteinkuk View Post
I am interested
You have free subscription
And noooow T-rex on steroids
Motor 2 motor 44cm.
Total weight with LiPo holder, legs, screws etc - 210g.
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Jun 29, 2010, 11:03 AM
blindflight is offline
Find More Posts by blindflight
blindflight's Avatar
CA
Joined Dec 2003
TH Board assembly V 4.1
New to electronic pc board assembly.
Anybody have pic's or info on "Jakub" TH pc board. I am doing the assembly and trying to understand the +- of some of the parts for proper installation as well as where to mount the HK 401b gyro's. Any and all info / pics of a fully populated board would be great.
Thanks, BLINDFLIGHT
blindflight is offline Find More Posts by blindflight
Old Jun 29, 2010, 11:10 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
hey jakub, im definitly interested in being a tester for one of your great frames ;-)
markus
Motor 2 motor 44cm.
Jakub
warthox is offline Find More Posts by warthox
Old Jun 29, 2010, 11:50 AM
Niall is offline
Joined May 2010
Thanks, BLINDFLIGHT
I will get you some pics of my populated 4.1 board later this week with all the connections. It is down in my workshop (about 2 hrs away) and I will only be going down later this week.
Cheers,
Niall
Old Jun 29, 2010, 11:53 AM
Jakub J is offline
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
Thanks, BLINDFLIGHT
I'll made guide tommorow... I hope
Jakub
Site Sponsor
Old Jun 29, 2010, 01:04 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Thantran,
With your Lpr550 gyro PCB, im assuming you use the 1x outputs for hooking to the KK controller?
Yes Peter! I'm using the 1X output. With 4X, the quad becomes very sensitive.
-Thanh
thanhTran is offline Find More Posts by thanhTran
Old Jun 29, 2010, 01:11 PM
warthox is offline
Joined Aug 2009
i made some onboardvideo's last weekend with a gopro hd on my kk tricopter v2. the footage is awesome. smooth and no vibrations. i think u will like it. but i have to edit the 45min of raw material to a short video. uuh this takes time i made rolls, loops and some very low flights
i hope i can finish the video till the next weekend...
so be prepared
some appetizers the pics are not inverted themselfs
markus
Old Jun 29, 2010, 01:13 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by bob.titus View Post
I haven't tried G10 yet, but it seems like it could be an option as long as it's not as damn heavy as normal GF.
Bob
I've seen some numbers about weight from Askman who makes Aerial Photography gears. If I remember correctly, G10 is heavier than CF. For same strength, G10 has to be thicker as well.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
