Old Mar 17, 2010, 01:18 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Originally Posted by quaddynamics View Post
Bravo kapteinkuk,
Is it possible to use atmega168 for your quad controller circuit , if so please help me out in setting the atmega168 for 8Mhz internal oscillator with fuses using phony prog since my burner is compatible with phony prog, and will the same code will be working for atmega168 too else we have to make any modification in the code ? ..
im ready with your hardware only the burning part is left .. im struck up with the internal clocksettings for atmega168.. please please please help me out ken
Yes, The atmega48/88/168 is basically the same chip. Their differences is different flash, EEPROM, RAM sizes and some other stuff.
I have compiled a HEX file for eatch of the 48/88/168 chip, see attachments.
You have to use correct HEX file.
Note that this is for V3 only. Also note that I do not have the 88/168 chip, so it is not tested, but should work according to the datasheet.
I do not have phony prog, so I can not help you with that.
****EDIT: The hexfile for 168 was wrong, it is fixed now (Used wrong jump intruction in the vector table, RJMP instead of JMP) ****
kapteinkuk is offline Find More Posts by kapteinkuk
Old Mar 17, 2010, 01:21 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by lowie View Post
Kaptain,
Is there a difference between VCC + and + 5V in the schematic from the QuadcontrollerV2?
Yes, the VCC is filtered 5V supply. +5 shall be connected to the +5 leads of the ESC's
Old Mar 17, 2010, 02:17 PM
lowie is offline
Find More Posts by lowie
Joined Mar 2010
The VCC came from the LM317,am I right?
Must I connect all the speedcontrollers to the +5 V?
They give 5 V each from the bec of the speedcontroller= 4 x 5V = 20V ???????
Or should I connect just one speedcontroller t the +5 V ?
lowie is offline Find More Posts by lowie
Old Mar 17, 2010, 09:29 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
kapteinkuk am I correct in assuming the different hex files were compiled using each ones device specific def.inc file?
pug398 is offline Find More Posts by pug398
Old Mar 17, 2010, 09:57 PM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
thanks ken ,
is there is any other posibility for setting 8Mhz internal clock setting for atmega168, because i tried with your clock.hex file using the programmed 8Mhz atmega168 it dosent work ,that is i could not make it 8Mhz internal clock , im doing it wrong , i have spoiled 6 chips till now , i dont know where i went wrong either with the fuses or clock . now im blind ... can you suggest me the right hardware which is compatible with avr studio 4 , so that i will build the hardware and will follow your way of setting ... thanks again
quaddynamics is offline Find More Posts by quaddynamics
Old Mar 18, 2010, 04:58 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
The ATMEGA differ by another stack pointer address
to modify the ASM
by ATMEGA48 .. org kapteinkuk -
.include "m48def.inc"
by ATMEGA88 -
.include "m88def.inc"
by ATMEGA168 -
.include "m168def.inc"
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Mar 18, 2010, 05:18 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
no problem with using USB
... Programmierer und Debugger AVR INSystem mkII Programming Kit
- http://de.mouser.com/ProductDetail/A...csKqwYpg%3d%3d
or, ATAVRDRAGON
- http://de.mouser.com/ProductDetail/A...tIZaKRJg%3d%3d
or ...
kapteinkuk or take into account the use of ARDUINO
no longer probmem With Fuses.
jürgen
Old Mar 18, 2010, 06:38 AM
lowie is offline
Joined Mar 2010
Kaptian,
Is there a big difference between the ATmega88 and ATmega88P ?
I have ordered an ATmega88P should it work ?
Old Mar 18, 2010, 05:41 PM
Quad Whisperer
Joined Jul 2008
No, VCC comes from the RC lowpass filter R4/C7.
Just connect according to the schematic, all VCC symbols is connected together and all +5 symbols is connected together.
The four ESC's is connected in parallell, so the voltage is still 5V.
Quad Whisperer
Joined Jul 2008
Yes, that is correct.
Old Mar 18, 2010, 06:06 PM
Quad Whisperer
Joined Jul 2008
thanks ken ,
I use AVRSTUDIO 4. It is free from Atmel, the makers of the chip.
Get it here: http://www.atmel.com/dyn/Products/to...p?tool_id=2725
On the same page there is useful documents to read, for example "Novice's Guide to AVR Development".
I use the AVRISP programmer: http://www.atmel.com/dyn/products/to...p?tool_id=3808
Also read the user guide document on this page.
Your 6 nonresponsive chips can be saved by using a programmer witch uses High voltage programming interface (eg. stk500), or by using the above ISP programmer and supplying the chip with a crystal or a external clock signal. You have probably disabled the internal osc with wrong fuses.
Old Mar 18, 2010, 06:08 PM
Quad Whisperer
Joined Jul 2008
to modify the ASM
by ATMEGA88 -
by ATMEGA168 -
jürgen
Also M168 differs from 48/88 by using JMP instead of RJMP in the interrupt vector table.
Old Mar 18, 2010, 06:10 PM
Quad Whisperer
Joined Jul 2008
or, ATAVRDRAGON
or ...
jürgen
I will take a look at the Arduino thingy
Old Mar 18, 2010, 06:16 PM
Quad Whisperer
Joined Jul 2008
Kaptian,
No problem. P is the 28 pin plastic package.
Old Mar 18, 2010, 06:18 PM
Quad Whisperer
Joined Jul 2008
Note that I have updated the HEX file for the M168. Redownload it if you have it already.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
