Old Mar 15, 2010, 03:26 PM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
see here ...
- http://www.atmel.com/dyn/resources/p...ents/8271S.pdf
or
- http://www.atmel.com/dyn/resources/p...ments/8271.pdf
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Mar 15, 2010, 03:27 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Lowie it is truly best to learn how to use the tools. Juergen provided an excellent link and if you scroll down to the section explaining "burning fuses" you will find a link to the avr fuse calculator. In the first drop down box select the device type (atmega88) and choose the clock options KapteinKuk graciously provided in an earlier post. At the bottom it will give you the value of the low,high and extended fuse bytes. Enter these in the GUI. Give it a try first and see what you come up with. And no they do not appear to be the same for an atmega88.
pug398 is offline Find More Posts by pug398
Old Mar 16, 2010, 06:43 AM
lowie is offline
Find More Posts by lowie
Joined Mar 2010
I have fond a avr fuse calculater on the net : http://www.engbedded.com/fusecalc/
I give it a try and a give my report (it can take 1 week or so)
lowie is offline Find More Posts by lowie
Old Mar 16, 2010, 10:20 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Correct clock speed is important.
Use the attached program to test the clock speed.
When running the led will be off for one minute and then on for one minute, and so on. Check with a stop watch. A few seconds off is OK.
If not, the fuses is wrong.
If it does not blink at all, the clock is not running or something else is wrong.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Mar 16, 2010, 11:32 AM
lowie is offline
Joined Mar 2010
I have another problem : I cant order an 8MHz ATmega,I thougt I had read That the clockspeed dusn't matter.Than I can order an 20MHz ATmega?
But the avr fuse calculator can't calculate the fuses for the internal clock from 20MHz,had enyone another fuse calculator?
Old Mar 16, 2010, 03:43 PM
Quad Whisperer
Joined Jul 2008
Yes.
The 8 and 20MHz is their maximum speed. They can use any clock freq below and inclusive their maximum speed.
I have no idea about the fuse calcs.
Old Mar 16, 2010, 03:51 PM
nitc is offline
Find More Posts by nitc
calicut
Joined Feb 2010
i m confused ,
purchased :
4 bldc
4esc
1 lipo
3 gyros
just want to know what else (everything right from scratch)will i need
pleeeez help me ,i m a noob to RC hobby
nitc is offline Find More Posts by nitc
Old Mar 16, 2010, 07:20 PM
cyborgcnc is offline
Find More Posts by cyborgcnc
The Drones are Coming!!!
cyborgcnc's Avatar
New York, NY
Joined Feb 2010
Nitc
Go here:
http://www.rcgroups.com/forums/showthread.php?t=1174262
read everything, Understand it...and if you still have questions, we would be glad to answer them!
cyborgcnc is offline Find More Posts by cyborgcnc
Old Mar 17, 2010, 04:08 AM
nitc is offline
calicut
Joined Feb 2010
i have read the whole discussion and dowloaded all the images .
btw i was asking for atmega48 based components thanks
Old Mar 17, 2010, 04:20 AM
JUERGEN_ is offline
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
Originally Posted by nitc View Post
i m confused ,
purchased :
4 bldc
4esc
1 lipo
3 gyros
RC components are the same as everywhere. - http://aeroquad.info/bin/view/Main/PartsList_v2
etc. my parts ...
jürgen
Old Mar 17, 2010, 07:00 AM
lowie is offline
Joined Mar 2010
Kaptian,you say :
"The 8 and 20MHz is their maximum speed. They can use any clock freq below and inclusive their maximum speed."
Than I can use an ATmega 88 with a maximum 20MHz clock.And simplely don't use the 20 mHZ clock but a 8MHZ clock?
Thanks Lowie
Old Mar 17, 2010, 10:48 AM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
Bravo kapteinkuk,
Is it possible to use atmega168 for your quad controller circuit , if so please help me out in setting the atmega168 for 8Mhz internal oscillator with fuses using phony prog since my burner is compatible with phony prog, and will the same code will be working for atmega168 too else we have to make any modification in the code ? ..
im ready with your hardware only the burning part is left .. im struck up with the internal clocksettings for atmega168.. please please please help me out ken
quaddynamics is offline Find More Posts by quaddynamics
Old Mar 17, 2010, 11:51 AM
Quad Whisperer
Joined Jul 2008
Originally Posted by lowie View Post
Kaptian,you say :
Thanks Lowie
Yes, that is correct.
Old Mar 17, 2010, 12:19 PM
lowie is offline
Joined Mar 2010
Kaptain,
Thanks for the answer.Now I gone start to build one!!!!!!
Lowie
Old Mar 17, 2010, 12:43 PM
lowie is offline
Joined Mar 2010
Kaptain,
Is there a difference between VCC + and + 5V in the schematic from the QuadcontrollerV2?
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
