Old Jun 02, 2010, 01:03 PM
cyhyam is offline
Find More Posts by cyhyam
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
I am a little embarrassed to ask.
I have followed this development fairly close and skimmed the thread, I am sure it is here somewhere but I can’t find it. I logged in to kkmulticopter.com and searched there also.
I got in (4) HK401’s and want to build this controller. I am good at soldering and can figure out the programming but am looking for a step by step of the assembly, maybe pics?
I understand the 401’s will be used for many of the parts, the rest I need to order. Is that cannibalization detailed somewhere?
I am looking forward to the “project” part of this and the final results.
cyhyam is offline Find More Posts by cyhyam
Old Jun 02, 2010, 01:40 PM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Hello Cyhyam,
I'm almost done with my KK quad and will be posting a parts list, pictures and supplier links in about a week. See my mini how-to for programming recommendations.
You'll only need 3 of those HK 401B's and I recommend getting one of these unpopulated PC boards while they're still available, as it cost me $9 for a generic blank PCB and took several hours to solder all the wires to each component.
patricklupo is offline Find More Posts by patricklupo
Old Jun 02, 2010, 02:47 PM
cyhyam is offline
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
Hi Patricklupo,
I bought 4 of the 401s so I would have a spare.
I saw those unpopulated boards but since I will be using many of the components off the 401 gyros wouldn't I be looking for a surface mount board, the ones offered are thru hole.
Old Jun 02, 2010, 03:37 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
...I got in (4) HK401ís and want to build this controller. I am good at soldering and can figure out the programming but am looking for a step by step of the assembly, maybe pics?
Not sure what to provide for "step by step assembly". General rule is soldering the SMD main chip at last. Solder everything else first and check power reading across the power pins of the Atmel chip, and the 1.5v VREF out of the LM317 make sure they are correct, then solder in the main chip.
Some pics here with Kaptein's V5 PCB (you can ask Peter (Scorpia?) to get one):
http://www.rcgroups.com/forums/showp...postcount=1498
Jussi (rc420pilot) also has some pics of the same SMD board.
Thanh
thanhTran is offline Find More Posts by thanhTran
Old Jun 02, 2010, 03:42 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by jesolins View Post
FYI Many kitchen cutting boards are mad out of Derlin. ...
The delrin material I bought from MC-Mastercar is much harder than the kitchen board. It is not flexible. It's almost like plexi glass.
But I think the kitchen cutting board would be nice to make motor mount or center plate for the quad / tri. Thanks very much for the hint!
Speaking of motor mount, anyone has any suggestion how to dampen the vibration from the motor? I'm thinking of putting some rubber (if I can find some) beneath the motor and around the screw to lessen the vibration on the frame.
ALSO, for mechanic gurus out there, my drill press chuck had an incident long time back which I drill something too hard, and it had a shock. After that the chuck is slightly less center. The chuck is installed into the drill press shaft by just pushing it in and hit it with a block of wood to make it stay. The shaft shape is a cone, and similarly for the chuck (a cone hole). My question is how do take the chuck out and reinstall it for straightness? Any suggestion?
Thanks very much
-Thanh
Old Jun 02, 2010, 03:52 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
The SMD board uses the components specified by KK in very first post of this thread.
some of these components (47 uF caps, trimmers, Leds, servo wires) can be found in the HK401b gyros.
If you got the older XMhobbies version (Gy401b) with silver top and "Gyrd" on top you will also find an Atmega48 TQFP that fits the SMD board. Contact user Scorpia for those boards.
You still need to source resistors and some caps that are not found inside 401b-type gyros.
To desolder smd components you can use a hotair gun at about 250 degrees celsius. You can just push components aside when solder melts.
Remove the gyro board first and take care not to damage sensor by exposing it directly to the hot air or dropping it! The safe and slow way to remove gyro board is of course with solderiron and desoldering wick!
JussiH is offline Find More Posts by JussiH
Old Jun 02, 2010, 03:53 PM
ben123 is offline
Find More Posts by ben123
NW England
Joined Jul 2005
I'm currently in the process of making motor pinch mounts out of kitchen cutting board
Btw I bought scales and my controller weights just under 8gs.
Ben.
ben123 is offline Find More Posts by ben123
Old Jun 02, 2010, 05:04 PM
Joined Jul 2009
You can go SMD or not but I think the same gryos are needed (or at least are the more cost effective for their parts). I always prefer non-SMD as it's far easier to solder parts to and the size difference in the PCB doesn't matter unless your building a micro sized copter. I'll leave the SMD stuff to robots or folks with 20/20 vision and lots of patience.
Hi Patricklupo,
Old Jun 02, 2010, 05:05 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Thanks very much
-Thanh
Bear with me as I'm tryin to do this at work from my cell phone in my shop. What you are gunna have to do is lower the chuck a lil with the handle till you see the long slot. You might have to turn it just a bit till you can see throught it. there should be a wedge shape key that should have came with your drill press. The key goes into the slot and lightly tap it with a hammer while your holding onto the chuck. It should pop right out. Be careful not to let it hit the floor as the taper has to be smooth to fit back it. I will try to attach some pics to show you what to look for.
braindead4554 is offline Find More Posts by braindead4554
Old Jun 02, 2010, 06:38 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Originally Posted by braindead4554 View Post
.... there should be a wedge shape key that should have came with your drill press. The key goes into the slot and lightly tap it with a hammer while your holding onto the chuck. It should pop right out....
Thanks very much for your help! I will try to see if I can do that tonight. I don't remember my drill press come with any other key. It's been around 5 years since I've bought it, and I've moved, so chances are any accessory coming with it might have lost . Will see what it looks like tonight.
The photos were perfect. What phone is that?
-Thanh
Old Jun 02, 2010, 07:30 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Delrin...yep darn spell checker... The cutting boards tend to melt using table and probably radial arm saws or even simple sabre saws, although they will still work with a bit of edge sanding clean up afterwards. I found band saws worked for the cleanest cuts. And yes... some of the cutting boards are nylon-ish, but that works well too
Cheers,
Jim
Originally Posted by ergocentric View Post
1. Delrin, please not derlin, very tough, power tools only (Polyoxymethylene)
2. cutting boards are better because they are cheaper and strong enough
they are made from high density polyethylene (HDPE), not delrin
My opinion
Eric
I will use a cutting board and a radial arm saw, though the thick ones are getting difficult to find.
jesolins is offline Find More Posts by jesolins
Old Jun 02, 2010, 07:39 PM
cyhyam is offline
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
SMD doesn't scare me a bit, I have the right equipment and have done a fair bit in the past. I prefer SMD in vibration enviroments although if thru hole is the only board available then I will do that before using perf.
Old Jun 02, 2010, 08:14 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
-Thanh
Glad I could help! Anything with a taper or maybe even a screwdriver could work. My phone is a BlackBerry Tour 9630. Not a bad phone to take pics with. Its the only thing I have to take pics with lol
Old Jun 02, 2010, 11:58 PM
rewolff is offline
Find More Posts by rewolff
NL
Joined Nov 2009
What i do is to lift the board by holding the component up, when the board falls away, you have your component.
rewolff is offline Find More Posts by rewolff
Old Jun 03, 2010, 12:54 AM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
Originally Posted by km28104 View Post
You might want to rethink the c channel. It has poor torsional strength and can add to gyro instability. Square channel would work much better.
Ken
That was my first thought. But I'm still looking around for a local supplier. But I alreadly had the c channel laying around so I was gunna try it out. I cut them kinda short and tryed twisting them in my hands. Didn't really flex much but a lil probably will go along way with the gyros. Thanks for the tip.
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
