Old May 31, 2010, 05:25 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
having a brain ft atm...can't think for the life of me what the items are called next to the arrow - making out a build list on digi-key, so also need the spacing/pitch too...
bob4432 is offline Find More Posts by bob4432
Old May 31, 2010, 05:43 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Male headers:
http://search.digikey.com/scripts/Dk...=SAM1017-50-ND
JussiH is offline Find More Posts by JussiH
Old May 31, 2010, 05:51 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
Originally Posted by 420RcPilot View Post
thanks, feel like an idiot
Old May 31, 2010, 05:54 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by thanhTran View Post
You're like code warrior .
-Thanh
Indeed - the force is strong with this one!
Old May 31, 2010, 07:31 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
Will order mine later in the week ... I cant wait ....Thanks so much for your dedication on this board .
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old May 31, 2010, 07:50 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
i haven't decided if i am going to build one of the smd boards or buy one, but i did put together a list in case i do build my own.
could i get you guys to take a look at it to verify the parts are correct please?
KK SMD Board Parts List
it is on my home server, thus the "alternative" port since cox blocks 80
thanks,
bob
Old May 31, 2010, 08:37 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
thanks,
bob
Here is a mouser order for 5 sets of parts if you want to cross-reference. It was checked by others but not built yet.
(edit: too long. PM for list if desired)
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old May 31, 2010, 08:53 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
thanks, got it appreciate it greatly.
Old May 31, 2010, 09:22 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
quad build
As I am waiting on my pcb to arrive in the mail I thought I would work some more on the frame. So I sat down and started to draw up some parts on the ol cad program. Then sent it off to my CNC router to mill it out. Check it out......
Here is my mill in action if you want to see.....
CNC Router milling quad parts (7 min 1 sec)
Combining my two hobbies into one
braindead4554 is offline Find More Posts by braindead4554
Old May 31, 2010, 09:29 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
http://www.youtube.com/watch?v=xyzOTS_spJE
nice
what are you using for arms? wood? rect Al tubing?
Old May 31, 2010, 11:10 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
nice
I am going to use aluminum c channel. 3/8" X 1/2"
Old May 31, 2010, 11:23 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
thanks,
bob
I skimmed through the list. It seems fine. You don't need the C10 though. On my own PCB, I had a 10K between the reset line and the Vcc and no cap, and it never glitched or self reset. Kaptein's V5 PCB has a 4.7K resistor there, so it's even safer. And many of the 47uF cap can be taken from the HK401 gyros. so you don't need to buy them.
Thanh
thanhTran is offline Find More Posts by thanhTran
Old May 31, 2010, 11:33 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
...Then sent it off to my CNC router to mill it out. Check it out......
...Combining my two hobbies into one
it's always fascinating to see those CNC machine in action.
The parts look nice. Have you considered cutting those parts out of derlin? That is much stronger than wood and could weight less; I'm not sure about the weight, but the parts could be smaller and still strong.
Old Jun 01, 2010, 04:03 AM
bob4432 is offline
bob4432's Avatar
Joined May 2010
just out of curiosity, is there any advantage of going w/ a atmega168 vs a atmega328 or vice/versa? anybody know who has them in stock in the US? i have only looked @ digikey and mouser beeing a noob...
i think i have probably read all 100+ pages and not seen this question. sorry if it has been asked.
bob
Old Jun 01, 2010, 06:01 AM
doorhead is offline
Find More Posts by doorhead
Lazy RCer
Seoul, S.KOREA
Joined Oct 2009
I wish to reflash my tricopter_1.1 to Y6_1.2 But I don't know M1 to M6 physical motor position and each motor direction.(sorry... I only interested on KKtricopter related threads before today)
Just in my two cents...
Could you add M1 to M4(M6) mapping description in source code comment?
OR
add Tri, Hexa/Y6(incl rotate direction) connection diagrams to first thread for the newbies?
OR
add motor connection diagram to each flash with next realese?
Originally Posted by kapteinkuk View Post
Here is the new versions with potmeter reversing.
To change potmeter direction, set roll gain to zero, turn on, wait for the led flashes and then raise the throttle stick.
doorhead is offline Find More Posts by doorhead
Discussion Quadrotor brushless controller airbotix Multirotor Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Power Systems 8 Jan 07, 2006 10:07 AM
