Old May 01, 2003, 09:05 PM
BobFlyer is online now
Find More Posts by BobFlyer
Panama City Beach, FL.
Joined Aug 2002
Motor Suggestion For Bi-Plane Scratch
Will this work
Wing 30" 4.5" Chord 270 sq in
Current weight 6ozs with Mini-Max
Sturdy-Board/Meat trays
My guess when finished 11-12 ozs depending on bat used.
add berg 5, hitec 55's 2 ea. controller. ect.
Mini max motor (280 7.5x5 prop)
Also have mpjet 25/25 controller 950 kans
Lion 18650's
props 7.5x5,9x6,9x5
Anyone know what I could use from the above
to fly the plane.
BobFlyer is online now Find More Posts by BobFlyer
Old May 01, 2003, 09:10 PM
Joined Aug 2002
Also would like suggestions on using some of the on hand components and add to for a good setup.
Thanks All in advance Bob
Old Nov 30, 2004, 12:26 AM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
Bobflyer, is there a gearbox attached to that motor, and if so, what ratio is it?
I just started building my GWS tiger moth (similar size and weight to your scratch-built one, perhaps a bit lighter), and am intending to use a 280 motor (GWS EPS 100) to get a little more power than the tiny stock IPS motor. With the GWS "2" ratio gearbox, and a GWS 8x6 prop, current draw was 2.65 A at 7.5V dc (roughly the average voltage from a 2S Lipo, which varies from about 8.4V at full charge to maybe 6 V at full discharge). This represents about a third more power than the stock IPS motor, "A" ratio gearbox, and 9x7 prop, which pulls a hair under 2 amps at 7.5 V.
I also tried a GWS HD 10x6 prop on the same motor and gearbox, and it pulled 3.35 A at 7.5 V. This is about two-thirds more power than the stock IPS setup.
It is possible to squeeze more power from the 280 for sure, but I wanted long flight times, so I didn't try to go for the most power possible from the motor.
By the way, I'm no motor guru, I'm learning as I go, but I believe these two combos should work well in a Tiger Moth of this size.
Thats a very pretty Moth you have there, by the way!
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Old Nov 30, 2004, 06:56 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The MiniMax motor is geared, forget the ratio, but it's similar to an EPS-100C-2S as I recall. The stock prop should be fine, or try an 8x6 or 9x4.7 for a little more. The 18650 LiIon cells would work with the MiniMax motor as well.
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 30, 2004, 10:27 AM
Joined Aug 2002
Motor
Yes: As Gene mentioned above its a Mini Max Motor that I salvaged..
It geared but I do not recall the ratio...somewhere in the 2.xx:1
I have several similiar planes that I have been using the EPS-100 "c" gearbox 5:33:1 with the DCM-189 motor with a 10x4.7, 9x7 props and they perform
very good on a two cell lipoly..
BobFlyer
Motor suggestion for Aeronaut's Super Dimona TC80 casioppc Electric Sailplanes 2 Sep 18, 2003 12:59 PM
Motor suggestion for Trick 1000 with TP2100's YZ 212 Power Systems 1 Sep 08, 2003 02:38 AM
wanted-brushless motor/esc for 2m plane kjw03 Aircraft - Sailplanes (FS/W) 0 Jun 01, 2003 09:17 PM
Motor suggestion for Goldberg Sr. Falcon rcav8r2 Sport Planes 9 Jan 05, 2003 10:21 AM
Motor Suggestion for Globe Swift? RCFlybry Parkflyers 4 Nov 12, 2002 02:16 PM
