Old Nov 16, 2009, 04:17 AM
bleary is offline
Find More Posts by bleary
Cookie Monster
Australia, QLD, Diddillibah
Joined Aug 2005
HK-450MT CCPM 3D Fully Alloy Electric Helicopter Kit
I would suggest to get in quick for this one.
http://www.hobbycity.com/hobbycity/s...dProduct=10413
bleary is offline Find More Posts by bleary
Old Nov 16, 2009, 04:26 AM
Zootster is offline
Find More Posts by Zootster
Joined Jul 2007
Cheap Dangerous Junk. Sorry. I have seen what happens when they fail. BANG
Zootster is offline Find More Posts by Zootster
Old Nov 16, 2009, 04:31 AM
bleary is offline
Cookie Monster
Joined Aug 2005
:No good eh? I don't know much about Helis,just thought that it was pretty cheap...although cheap and helis probably aint in the same suburb...
Carry on,just posted cos it came up as I was browsing(as you do)HC.
Bleary.
Old Nov 16, 2009, 06:38 AM
Zootster is offline
Joined Jul 2007
I dont think $46 will buy a full metal 450 size heli of any quality. I saw a blade and blade grip eject from 450 the other week. Nothing broke or no screws came loose. it just pulled off at high head speed and went about 25ft. Bad tolerances. Stick to a known brand. Much safer. I have been hit by a 450 blade and it hurts HEAPS. Luckily it was only wood and not carbon.
Old Nov 16, 2009, 03:18 PM
evo62 is offline
Find More Posts by evo62
Nup, I got nothing!.....
evo62's Avatar
Gold Coast, Australia
Joined Jun 2007
Don't do it mate. It brings the phrase "bottomless pit" to mind. I got a tiny, little 'touch' from a FG 450 blade and cut me to the bone.
Here's the real problem. Every crash costs you heaps. Whereas you can effect repairs on planes, on heli's you need to replace parts. As the cost escalates I found I started to build a tough little mental safety box and was not progressing past tail in/side hovering from fear of crashing.
Clovus
evo62 is offline Find More Posts by evo62
Old Nov 16, 2009, 06:48 PM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Clovus
Not commenting on the quality of this one. The spare parts on these cheap helis are very cheap. If you crash a Gen T-REX it gets very expensive very quickly. If worried you might be buying a lemon, just wait till there is a group consensus from people who have flown one. Also keep your distance, it reduces how fast the blade will be going when it hits you and decreases your chance of being hit.
Stuart
fredo21 is offline Find More Posts by fredo21
Old Nov 16, 2009, 07:11 PM
lovetoflyjets is offline
Find More Posts by lovetoflyjets
United States, CA, Riverside
Hi I just got mine today. I ordered the plastic one but they sent me the metal one for the same price. I also have a align t-rex 450se and to tell you the truth I cannot tell the difference in the cnc work.
lovetoflyjets is offline Find More Posts by lovetoflyjets
Old Nov 16, 2009, 07:44 PM
evo62 I understand what you are talking about. With this cheap heli I am going to ring this baby out to the limit and learn learn learn.
Old Nov 17, 2009, 01:37 AM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
Give them a few months till they sort the bugs, unless you want to beta test. A few ppl I know have bought various HK helies and all needed replacement parts. The HK250GT actually worked out cheaper if he bought the align, half the reason being it has motor etc included.
Eagleburger is offline Find More Posts by Eagleburger
Old Nov 17, 2009, 03:24 AM
Magnum9 is online now
Find More Posts by Magnum9
Molded Hotliner Destroyer
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
On the 500 kit they say they use 2000 series alloy whereas all the other manufacturers including align use 6000 series. 2000 series alloys are generally twice the tensile strength of 6000 series.
Magnum9 is online now Find More Posts by Magnum9
Old Dec 28, 2009, 01:06 AM
chopperdave is offline
Find More Posts by chopperdave
United States, CA, Santa Clara
Joined Nov 2004
enjoyed my first flights today
I got one last week and was horrified by the job they did assembling it. Some screws had too much loctite, and one even broke off rather than unscrewing. Other screws had none, and some screws were not even snug.
The flybar cage touched a screw head as it moved, and so could not move freely. Had to bend it slightly to get it to clear. The flybar cage pinched the bearings that the flybar passes through, and had to be filed down so that those bearings could move freely.
The gear mesh between the tail drive gear and the lower big gear is very loose, but it is working for now. I'll have to find a way to adjust that.
The swash plate oscillates laterally as the head rotates.
The screws are very poor quality. The heads are not a good fit for any allen wrench in my set, metric or imperial, and I have reasonably high quality allen wrenches. Some of the heads strip before the screws are reasonably tight, so I am gradually replacing them with high quality screws from a local store.
All that said, it flies brilliantly! I moved the flybar weights up against the flybar cage, and it rolls, loops, and flips easily. Those are my most advanced maneuvers, but I think the heli is capable of more when my thumbs are up to it. It also hovers very smoothly and easily. Other heli pilots are amazed when they hear that my gyro was about $30 and tail servo about $3. They tell me it would be better if I used higher a quality servo and gyro, but the tail holds pretty well even with this setup.
I'm using HXT900 servos all around, a telebee gyro from hobbycity, and an align motor and ESC given to me by a friend, flightmax 2200 3s 20c and 15c batteries and an electron 6 receiver. I use align wood blades, and got a different canopy from HC for about $6.
Though it is far from perfect, I'm happy that I decided to get this heli. I enjoy solving the goofy problems like the flybar cage hitting a screw head, so I didn't mind too much. If you want a heli that works properly right out of the box, this is not for you!
Fly safely,
David
chopperdave is offline Find More Posts by chopperdave
Old Dec 28, 2009, 02:11 AM
KoziFlyer is offline
Find More Posts by KoziFlyer
Globemaster Maiden Time
KoziFlyer's Avatar
Melbourne
Joined Jun 2007
I have an HK450, and HK500 (70+ flights and no issues) ennuff said. Don't be anal and just fly it!! One word of advise, the HK500 is much better then the 450 and that is the general consensus for any brand name. The 500 size is the best to learn on and to do 3D, autos, etc.
KoziFlyer is offline Find More Posts by KoziFlyer
Old Dec 28, 2009, 02:23 AM
KoziFlyer's Avatar
Melbourne
Joined Jun 2007
Probably coz the person didn't know what they were doing!!! Check everything b4 you fly, remember it comes from a manufacturing plant and the person building it may have had a bad day like we all do, yeah???????
Check , check, check and remember to change your blades every 50 flights!!!
Old Dec 28, 2009, 03:33 PM
inverted22 is offline
Find More Posts by inverted22
Brisbane
Joined May 2009
This is very true, it all comes down to the first time you take it out of the box and when you take it to the feild for it first flight. I get mine on friday.
inverted22 is offline Find More Posts by inverted22
Old Dec 28, 2009, 03:46 PM
evo62 is offline
evo62's Avatar
Joined Jun 2007
Stepping up from the Blade 400 Inverted? I'll swap you a crashed up foamie for your Blade
Discussion HK-500GT 3D Helicopter Build Thread ChrisWNY Large Electric Helis 11416 Jul 27, 2016 08:02 PM
Discussion RCAerodyne 500 Size 3D Helicopter Kit Carbon Fiber and CNC Aluminum ( Blue Edition ) Hoverup Large Electric Helis 29 Feb 15, 2012 05:12 PM
Sold HK-450 CCPM 3D Electric Helicopter Kits Bill Hawthorne Aircraft - Electric - Helis (FS/W) 0 Aug 22, 2009 01:42 PM
Discussion HK-450 CCPM 3D Electric Helicopter Kit millera1 Micro Helis 2 Mar 21, 2009 09:44 AM
Blade CP fully CCPM Micro RTF Helicopter jmc67 Micro Helis 13 Dec 02, 2005 09:33 AM
