Joined Apr 2009
Guys,
Using a carbon or metal pole right next to the 2.4 antenna is going to seriously mess with the output radiation pattern. And if you are unlucky it will reduce the effective output. It can also potentially couple back through the transmit antenna a signal that is out of phase and result in heating the finals. Please use something non-conductive. Gerald |
Lake Elsinore, California, United States
Joined Aug 2003
Jun C. |
What about putting mylar on the end of your 2.4ghz antenna?
I have a 2.4 ghz setup and have been weary of doing the mylar streamer on it so I made a ~10 inch piece of ripstop nylon. Could I use mylar streamer? Ryan |
Latest blog entry: 2012 Masters Videos
Joined Apr 2009
Thermaln2,
Yes, you shouldn't. But that is a different issue. It used to be well known in the past but seems to have been forgotten that one transmitter next to another will intermodulate it somewhat. It probably affected things more in the AM era where it was more obvious. At least most of our transmitters are not shielded at all. If a signal couples into the input of the amplifier chain in the transmitter that signal will get amplified as well. This causes distortion. It can also cause your or the other guy's transmitter to splatter RF at frequencies it shouldn't be sending on. That could hurt everyone's reception by a small bit. The two antennas a couple of inches apart issue is substantially that they are in each other's near field. RF will couple between them. They will inductively and capacitatively couple. This proximity changes the output impedence of the "real" transmit antenna which could cause some issues for the circuitry perhaps reducing output power and increasing heating, as well as definitely distorting the output radiation pattern. It may improve it in some directions but likely hurts it worse in others. Unless you have mapped it out you have no idea. Please study up on the issues some. I have, having done some research into antennas before and as a HAM operator. Gerald KE4ET |
That said, there's no substitute for range checking
Let's try it this way!
New product from M M Glider Tech!
We are announcing that we are now manufacturing a 2.4 Wind Direction Aerial. It is manufactured with a Urethane base mount that can be bonded to the back side of the TX with RTV or double sided tape. The aerial is a 3/16" X 18" long White fiber glass rod that was made to be removable from the base for transporting. It can also be ordered in a longer length. Attached to the one end of the aerial is a mounted mylar ribbon. For more details look on the www.mmglidertech.com web page on the accessories page. The part numbers are MM-108 & MM-109. We are happy to support this great hobby! Safe Flying! Mr B. |
Looks Great Merrill a good solution to the short antenna. Clarence |
I fly a JR 12X MV that I run on 2.4 but it also has the antenna for 72mhz. Two weeks ago I flew my Xplorer on 2.4 while using the metal 72mhz antenna pulled out about 2 feet with a tell tail and had no issues flying it at normal TD distances. I asked Larry Jolly if he thought it would be an issue and he said that he didn't think so.
On my X9303 I am using Merril's 2.4 Wind Direction Aerial and I really like it. Very high quality, the base is out of the way of my fingers, I can still get to the bind button just fine. Nice job Merril! Clay |
| Thread Tools | |
| Discussion Walkera 4#3 FFs and Wind Fight PLUS the HARD CYCLIC DANCE !! | EQMOD | Micro Helis | 11 | Sep 22, 2009 08:51 AM |
| FMS wind direction? | TomO | Simulators | 2 | Jul 21, 2005 10:50 AM |
| Wind speed/direction history? | stegre | Slope | 2 | May 30, 2005 11:52 AM |
| Questions about USAIRNET wind direction | Cziltang Brone | Slope | 1 | Feb 15, 2005 02:24 PM |
| How to handlaunch in follow-wind direction? | temp_oct | Parkflyers | 10 | Nov 12, 2003 08:56 PM |
