Old Nov 22, 2010, 03:16 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Originally Posted by johnUK66 View Post
Thanks for the reply Capt re the razor saw, I haven't used one before and have just been checking them out, how many TPI is the blade you used? Thanks too Mike, do you have any pics/vid of your retracts in action?
John
I'll shoot some video later. I have the PingZheng 15091's in my heavy FMS P-47. Seem to work pretty well.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Nov 22, 2010, 07:32 PM
Joined Jan 2004
The video:
FMS P-4 with Ping Zeng 15091 retracts (1 min 11 sec)
Old Nov 22, 2010, 07:42 PM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Eflite retracts on CMP Spitfire .50 (0 min 20 sec)
mike early is offline Find More Posts by mike early
Old Nov 22, 2010, 07:57 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
Razor Saws
Originally Posted by CarreraGTSCS View Post
CaptEasy-- Why bother with the stock inserts at all? They only add weight and really do nothing for the looks. A little balsa or cardstock Cya'd in place top to bottom around the opening and you're done. That's what I'll do after getting the etracts in place. OOS at HK. Waiting patiently.
Mike....I think I'll try some card stock. It would definately look better and probably be less complicated - thanks.
John... I'm not sure but the small saw looks like maybe 48 TPI and the larger one is about 32TPI. Maybe the attached pics will help. I used the smaller saw only because I thought it was a little more conveneint to handle. The larger one would have worked just as well. Hope this helps.
Dick
capteasy is offline Find More Posts by capteasy
Old Nov 23, 2010, 04:50 AM
johnUK66 is offline
Find More Posts by johnUK66
johnUK66's Avatar
Joined May 2010
Thanks, gentlemen for all your replies.....gotta love this forum!
John
johnUK66 is offline Find More Posts by johnUK66
Old Nov 23, 2010, 08:18 AM
johnUK66 is offline
johnUK66's Avatar
Joined May 2010
Hi Capt, looks like a great tool, I could think of many uses for, I just purchased this 52 TPI one, looks like it may be the same one you have..... http://cgi.ebay.co.uk/ZONA-RAZOR-SAW...item56352131c7
Thanks for the replys and pics.
John
Old Nov 23, 2010, 11:24 PM
capteasy is offline
capteasy's Avatar
Joined May 2008
John
That looks like the one - it's the only tool to use for precise cutting and what I used for cutting my canopy also.
Cheers
Old Nov 24, 2010, 12:59 PM
Joined Jan 2004
I never posted pics of the castoring tailwheel mod I did. I also relocated the tailwheel to a more scale looking location. Still have to putty it to smooth it in but I'll do that right before I repaint the whole thing.
Old Nov 24, 2010, 02:45 PM
johnUK66 is offline
johnUK66's Avatar
Joined May 2010
Nice mod, how did you fix the fingers, ca, epoxy?
John
Old Nov 24, 2010, 03:00 PM
Joined Jan 2004
Don't laugh! I work in a hospital so I'd bet that I wash my hands between 75 and 100 or more times a day. My fingers do crack in the winter and guess what I use to seal the wounds? You guessed it, Ca glue. It works.
Old Nov 25, 2010, 06:35 AM
johnUK66 is offline
johnUK66's Avatar
Joined May 2010
Hey Mike, was kidding, I meant how did you fix them to the plane!
John
PS Is everyone on here 'cept me n the Capt called Mike!?
Old Nov 25, 2010, 07:52 AM
Joined Jan 2004
No problem. I know you were kidding but I really do use Ca to glue cracks in my hands.
I used Locktite Ca to glue the hardwood to the fuselage. I first routed out a circular opening in the fuselage slightly larger than the wheel collar that stays the tail wheel leg/axle on the now hidden topside of the hardwood part. Seems to be holding up well to my less than perfect landings.
I'd like to wish a Happy Thanksgiving to all.
Old Nov 25, 2010, 09:35 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
castor tailwheels always gave me trouble
Old Nov 25, 2010, 09:43 AM
Joined Jan 2004
Honestly, I haven't had any trouble since I learned to blip the throttle and modulate the rudder and it's only an issue when I taxi on my runway (baseball diamond). On grass it's a none issue. Took off from grass yesterday and it was a snap. Still belly landed her. I worry the etracts will get ripped out of the foam in the rough grass.
One of the Mike's
Old Nov 25, 2010, 04:07 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Is there a problem with the stock CMP gear ?
I built & setup mine exactly as per instructions, and it seems to work fine, I have about 6 flights on it.
Maybe I have an older plastic retract model ?
CMP Spitfire stock gear (0 min 34 sec)
Herb is offline Find More Posts by Herb
Question CMP P40 Warhawk 50 - 54" KentuckyColonel Fuel Warbirds 446 Jan 15, 2012 03:31 AM
Sold CMP Spitfire cowl tom_sandiego Aircraft - General - Miscellaneous (FS/W) 2 Dec 03, 2009 10:34 AM
For Sale CMP Yak-54 140 size 72" Backwing Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2007 08:39 PM
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 05:04 PM
For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA Stewby Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2005 03:10 PM
