Old Nov 06, 2012, 07:55 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
rodney -
That looks really sweet. I wish I'd sheeted mine but never thought about it. I added split flaps though and I think she'll perform well when I can replace that horiz stab. Would you be willing to share your formula for the balsa sealler...it sounds interesting.
Thanks for the help with the horiz stab.
Dick
capteasy is offline Find More Posts by capteasy
Old Nov 07, 2012, 02:51 AM
rodneyf is offline
Find More Posts by rodneyf
I couldn't help it!
rodneyf's Avatar
Australia, NSW, Padstow
Joined Oct 2009
It is pretty simple Dick, 2 parts dope and 1 part Talc powder. Once you paint it on you just sand it back and it comes up as smooth as a babies bum.
She is coming back!
rodneyf is offline Find More Posts by rodneyf
Old Nov 07, 2012, 06:42 PM
capteasy is offline
capteasy's Avatar
Joined May 2008
Very spiffing mate....thanks for the tip. I'll look forward to trying it out. Besides the extra CMP Spit in the box I have Travel Air Mystery Ship short kit that your little trick might well be perfect for the sheeted wing.
Son as I finish up a current project I need to get that horiz stab replaced on my Spitfire. It's been built with several mods and custom paint to represent Don Blakeslee's MkVb 133 sqn (Eagle). Pics of it are on my blog page: http://www.rcgroups.com/forums/member.php?u=208594 Scroll down about 7 planes.
Best,
Dick
Old Nov 07, 2012, 08:36 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Link
http://www.rcgroups.com/forums/showp...54&postcount=1
I don't get tired looking at that one.
Well done sir!
That elevator doesn't look too bad in the pic. But I'm sure it bugs the hell out of you.
TripleW is offline Find More Posts by TripleW
Old Nov 07, 2012, 09:13 PM
rodneyf is offline
I couldn't help it!
rodneyf's Avatar
Joined Oct 2009
It sure does look good but you're right, just a little airfoil makes all the difference to the looks.
Old Nov 07, 2012, 11:14 PM
capteasy is offline
capteasy's Avatar
Joined May 2008
Originally Posted by TripleW View Post
Link
Well done sir!
That picture was taken several months back but I think the horiz stab looks worse than that now.
Anyway the photo itself came out well - thanks.
I thought as long as I was going to remove and replace the stab I may as well build one with some airfoil shape to it. It might even help strenthen it as well.
Dick
Old Nov 08, 2012, 04:17 AM
rodneyf is offline
I couldn't help it!
rodneyf's Avatar
Joined Oct 2009
Dick
Dick the problem is that the groove in the fuse is 6mm so you need to build the normal stab, slide it in, glue it and then build the airfoil shape after it is fitted.
Old Nov 08, 2012, 09:00 AM
capteasy is offline
capteasy's Avatar
Joined May 2008
rodneyf -
Thanks for reminding me about the initial fit I may have overlooked that.
Dick
Old Nov 11, 2012, 12:07 AM
rodneyf is offline
I couldn't help it!
rodneyf's Avatar
Joined Oct 2009
The spitty is starting to look like a plane again.
Old Dec 05, 2012, 04:19 PM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I am going to replace my Saito 82 (and some of the nose weight) with a Saito .91
mike early is offline Find More Posts by mike early
Old Dec 07, 2012, 05:30 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
The 82 doesn't have enough poop?!
Old Dec 07, 2012, 05:32 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
ahh yes. Flew it that way since I bought it. But hate ballast, and the .91 is just gathering dust.
Old Dec 07, 2012, 07:07 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Hmmmm and I was thinking of putting a .72 saito in one
kahloq is offline Find More Posts by kahloq
Old Dec 07, 2012, 07:57 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
How far does the 82 hang out of the cowl?
Old Dec 08, 2012, 08:15 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
A saito 72 would be great, I am sure that a 62 would fly it fine. The 82 was certainly more power than needed, and way above scale. I merely obtained a .91 and wanted to use it. So, I am currently bumping down the engines in my planes 91 in place of the 82, the 82 in place of the 72, the 72 in place of the 56, and will find a plane for the 56 in the future. The 56 is just too big to replace the 40 in my GP Combat planes...
The 82 hangs out the bottom of the cowl very little. I opened up a hole in the front of the removable bottom plate to allow air to flow across the cylinder.
The 72-82 requires my battery strapped to the side of the fuel tank, a whole bunch of nose ballast, and the heavy stock muffler. (I usually use the light straight-pipe exhausts)
You could easily use a Saito 125 in this plane or even the FG-21 and the ignition box and not worry about CoG
Question CMP P40 Warhawk 50 - 54" KentuckyColonel Fuel Warbirds 446 Jan 15, 2012 02:31 AM
Sold CMP Spitfire cowl tom_sandiego Aircraft - General - Miscellaneous (FS/W) 2 Dec 03, 2009 09:34 AM
For Sale CMP Yak-54 140 size 72" Backwing Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2007 07:39 PM
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 04:04 PM
For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA Stewby Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2005 02:10 PM
