Old Jun 23, 2011, 07:16 AM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I never noticed that the Dave Brown wheels are too soft. You won't have any problems with them. Anyone using gear doors yet?
mike early is offline Find More Posts by mike early
Old Jun 26, 2011, 07:07 AM
Maccanaut is offline
Find More Posts by Maccanaut
Melbourne Australia
Joined Aug 2010
Mine had flat spots after sitting on the garage floor. They roll out after a few turns though. I'm not using the gear doors mike. I think theyre just one more thing that could potentially jam the retracts. Probably wrong on that.....donno but leaving them off anyway.
Michael
Maccanaut is offline Find More Posts by Maccanaut
Old Jun 26, 2011, 07:27 AM
johnUK66 is offline
Find More Posts by johnUK66
johnUK66's Avatar
Joined May 2010
As this is a leccy powered thread, thought Id ask...
Can any of you chaps reccomend an extremely accurate Lipo cell meter for checking balance, preferably a stand alone item and not as part of a charger?
Anybody have any experience of the Etronix battery Doctor?
http://www.cmldistribution.co.uk/cml...tId=0000003637
It looks identical to the HK version, but hey looks can be deceiving, components may be way cheaper?....
http://www.hobbyking.com/hobbyking/s...dProduct=10328
If anyone has the etronix one and the HK one and can verify both tally on the readings or not, that would be super duper!
Thank y'all, John
johnUK66 is offline Find More Posts by johnUK66
Old Jun 28, 2011, 05:13 AM
Bølle is offline
Find More Posts by Bølle
Denmark
Joined Apr 2010
Finely made the maiden yesterday.
The flight was fantastic.
My setup: 7.6 lbs CG was spot on at 3,9" from the leading edge (at the fuse) using 5000 mah 5S lipo and a 13x11 prop. Turnigy SK 50-55 580KV motor, ECS 100A ,turnigy 5-7,5A (8-42V)HV UBEC for Lipoly
This plane flies great, I've never flown anything that flies so well before, but takeoff and landing on grass is a different matter, After three flights it went wrong, it nose over under takeoff and broke my spinner back plate, and the rudder was loose when she landed upside down . so there is a little work to be done before she’s fly again, sorry i have no pictures
Bølle is offline Find More Posts by Bølle
Old Jun 29, 2011, 01:10 AM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
Thanks for the flight report...good luck with the repairs. Hope you get her back in the air again soon.
capteasy is offline Find More Posts by capteasy
Old Jun 29, 2011, 07:22 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I bought some gear doors when I first got the plane. Not even sure if they fit, but it looks like the gear will accommodate them
Old Jun 29, 2011, 07:25 AM
MerlinV is offline
Find More Posts by MerlinV
Melbourne, Australia
Joined Mar 2009
Yeah, doors should fit over that. Fabricate from Aluminium drink can sheet if the timber ones don't.
Cheers,
Hugh
MerlinV is offline Find More Posts by MerlinV
Old Jul 01, 2011, 08:28 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Where is everyone's elevator when trimmed for level flight?
Mine has a tad of down angle.....
Old Jul 01, 2011, 02:52 PM
Bølle is offline
Denmark
Joined Apr 2010
Hallo Mike
my plane has two click down on the elevator for level flight
Old Jul 02, 2011, 06:54 PM
Melbourne Australia
Joined Aug 2010
Mine too. Was beginning to think i needed more weight. Sounds like the down angle is pretty much the norm.
Michael
Old Jul 02, 2011, 07:58 PM
MerlinV is offline
Joined Mar 2009
It's just scale. The full size had it too.
Hugh
Old Aug 02, 2011, 09:12 PM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
My set-up exactly. I fly it often, no issues.
Here is a trick for these types of planes on grass.
Once she is down on on the grass, ease back on the throttle, and up on the elevator, when you come to a complete stop, you will be at full up elevator. Don't let it take off again, idea is to keep the nose light, and the tail planted as you are coming to a stop. It works every time.
I have had to program in up in up ailerons and an elevator mix to slow similar planes on grass and avoided a nose over, but have not needed it on this one.
markusvt is offline Find More Posts by markusvt
Old Aug 02, 2011, 09:13 PM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
Same here.
Hallo Mike
Old Aug 03, 2011, 02:40 PM
Bølle is offline
Denmark
Joined Apr 2010
thanks for the trick, I will try it next time and see how it goes
is your spitfire ok, or can you begin to see some damages after all the times it has flown , do you have some pictures of the spitfire now?
Old Aug 04, 2011, 11:58 AM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
Still looks great!
Question CMP P40 Warhawk 50 - 54" KentuckyColonel Fuel Warbirds 446 Jan 15, 2012 02:31 AM
Sold CMP Spitfire cowl tom_sandiego Aircraft - General - Miscellaneous (FS/W) 2 Dec 03, 2009 09:34 AM
For Sale CMP Yak-54 140 size 72" Backwing Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2007 07:39 PM
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 04:04 PM
For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA Stewby Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2005 02:10 PM
