Thanks!
The seller didn't have the 50-size in stock. (No one has here in Finland.) But they ordered it from the manufacturer. Price was 169 euros. Couldn't get it cheaper from anywhere else. Shipping and VAT added, it would have costed more from anywhere else, so I'm fine with it. And no idea when it'll arrive. But I'm not in a hurry, I've got still plenty to do with my Hyperion Mustang accessories, Great Planes Sopwith Camel and my little experimental Hellcat project... I think I'll start the Spitfire after the summer. Now I'm looking for a reliable and affordable setup for this plane. I was thinking of Turnigy 80 or 100 amp speed controller and Scorpion motor (somehow I don't trust Turnigys). Not sure which servos. I'll most likely install a Spektrum AR600 receiver, which I use also in my other bigger planes. And definitely a separate DESC and rx battery. Still a lot of things to consider, like retract options etc. Oleo-struts are most likely addition to retracts. Yesterday I received the Tamiya 1:48 Spitfire Mk Vb which I wanted as a study case. I'm planning of trying out an airbrush paintjob on this one first, so I'll know which colors to use. And there's lot of nice details I can see from a model more easier than from pictures. Also planning of ordering some nice books about the subject. The color scheme will be Battle of Britain era, before d-day stripes. I want the classic looks.
I wonder if it would be possible to install a sound system into this bird. The placement of the speakers is a big question. I'd really like to go NUTS with this build...
I wouldn't use a sound system in this one. It's so heavy and there is very little room in the fuse for anything once you've got the motor & batteries in there.
The only reason I'd even consider it is if I needed a lot more nose weight. Better a speaker than a ton of lead. Best bet would be to mount it to the back of the chin hatch, pointing down. Your gonna get your best bang for your buck in the taxi, not so much in flight. There's no room for really big speakers and a sound box, which you need to maximize the efficiency of a sound system. I'd point the speaker at the ground so that it can bounce sound waves off the ground and up to the people standing around looking at it... Set the speaker wire up as detachable probably with a mini deans or something so you can pull the hatch off when inserting your flight pack. I guess you could try to build a speaker into the center of the wing as well, pointing down. You'd weaken the center of the wing doing it, but it might allow you to build up a bit of a sound box on the top of the wing sitting inside the fuse, but not much. I'd lean towards the hatch installation for two reasons. First, you're getting weight in the nose, which is much needed on this plane. Second, you could set it up with two hatches. One with and one without the speaker. I'm sure there are a few people who've crashed their spits who could part with the hatch. That'd get you an option of flying without the speaker when there's nobody around to appreciate it. If you do try doing it, make sure to do a blog on it and let us know. And get some video! |
Best of luck whatever your decision.... |
You might be right. I'll take a look what could be possible. But as I have not yet received the plane, I can't take even a wild guess if it could be done. I'll most likely concentrate on making it look scale and fly well. And sound system might give too much penalty on the "flying well" part.
The battery tray has been re-done. Not much clearance reamains between the bat and motor - maybe an 1/8". However, the bat will be very snug with no room to move under conseravative and reasonably accellerated manuevers. At least that's my theory otherewise it could be potentially disasterous.
Next, repair the right horiz stab that got wacked (again.) The first repair must not have been substantial enough so it fractured in the same location, at the root. Also noted the entire horiz stab is drooping on both sides for some reason. I'm not pleased with that and uncertain what caused it. Tomorrow is a planned get together with a couple good friends and i was hoping to maiden the Spitfire, but winds are actually increasing from 10 -20 to 15-25 gusting to 30mph. Pretty discouraging outlook and getting very wearisome. Keep your RPM's up... |
Bat Tray & Horiz Stab
Here's some pics if interested .......note the droop in the horiz stab before repair. The right side was fractured at the root LE but repaired now with 1/8 x 1" CF tube at LE and toward TE of stab. The left side still droops some. Out of curiosity I checked the stab in my backup NIB CMP Spit and it was warped and drooped the same. From now on I'll be checking all the control surfaces more closely prior to final assembly.
Update
Took MDU out for some taxi tests and engine run up this morning - winds were rediculous but the ground handling went well.
The engine run up indicated a lot of vibration beginning at about 3/4 throttle. Initially I suspect the spinner and or prop may be out of balance. It shook the top hatch off, loosened sliding canopy then blew it off. That's good to know but will need to be addressed. There should be some video by tomorrow. |
Wow...!
Again, beautiful work Capt.. ![]() I've done more conversions than I can remember but your pics have given me tons of new ideas. I hope you do a build thread on an Axis bird soon! Maybe something big and for the builder in you.. Meister or Don Smith!Happy Father's Day everyone.
Melbourne Australia
Joined Aug 2010
Mines all ready for its second flight after weeks of wating for oleo struts and those dave brown lite wheels as recommended. Curious though.....the foam/rubber on those wheels is so soft, sitting on the driveway it looks like theyre half flat. Is that normal i wonder? I get the impression that on landing theyre going to bottom out. I'll try to vid the flight and especially the landing. I expect an 'incident', since this plane comes in too hot for our short, rabbit burrowed landing strip. We have long grass at both ends of the landing strip too, so i'm reaching the start of the runway at a height of at least 6 feet. I'd prefer to be at around 3 feet given the runways length. The knees are gonna wobble!
Michael |
| Thread Tools | |
| Question CMP P40 Warhawk 50 - 54" | KentuckyColonel | Fuel Warbirds | 446 | Jan 15, 2012 02:31 AM |
| Sold CMP Spitfire cowl | tom_sandiego | Aircraft - General - Miscellaneous (FS/W) | 2 | Dec 03, 2009 09:34 AM |
| For Sale CMP Yak-54 140 size 72" | Backwing | Aircraft - Fuel - Airplanes (FS/W) | 2 | Sep 16, 2007 07:39 PM |
| For Sale New CMP Yak 54 with TT91 Four Stroke | Stewby | Aircraft - Fuel - Airplanes (FS/W) | 1 | Dec 20, 2005 04:04 PM |
| For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA | Stewby | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 19, 2005 02:10 PM |
